So I am trying to figure out how to capture all my energy usage with this and record it all in home assistant, what should I set as the settings and what do I add to the energy monitor part of home assistant?
If you search the forums for aeotec parameters there is a thread that tells you which paramaters are best to have on and what not for reporting… when I wake up I’ll see if I can find it… but it shouldn’t be hard to come across I think when I needed it it was only a few results down
ZwaveJS makes it easy to toggle on/off what reports to utilize.
This is the important one (kWh Whole HEM):
Either on parameter 101, 102, or 103.
Then set parameter 111, 112, or 113 to something like 300 seconds. This will be the interval of reporting, adjust to your liking, but don’t go below 30 seconds or you’ll have a bad time.
Oh, I thought it would be more complicated, cool.
