Happy to say your code compiled without errors but not working.
the Flapper never moved no matter what i changed in the the UI
are you able to measure the output on the pins of the ESP? do you see any voltage on them? it should flip flop between the forward and reverse pins, the other pin (EN) should sit at around half the supply voltage
im also a little confused as to why there is no slider for the flap power too…
