How to create the alarm clock in HASS?
Oh i change to
  - delay:
      seconds: 2
But it not a loop, i think it's come from new action for scipt (single, restart, parallel and Queued
I’m not suggesting you change to a 2-second delay only that you correct the delay you already have in your script because this is invalid:
delay: '[object Object]'
Regarding the mode option, if you do not include it in a script, according to the documentation, the script will default to using mode: single.
Oh i read infomations change in 0.113. It’s have advanced for coding (Included 4 mode for Automation & Action, and Somes changes in Automation, to fix code can run on 0.113. We need to fix:
In Automation (Change method to Call Script in action)
#(For 0.113 or later)
    - service: script.turn_on
      entity_id:
      - script.flash_gateway1
      - script.xiaomi_alarm1
Describe: In 0.112 or previous Version, we call script directly, like below (DONT DO BELOW CODE FOR 0.113 OR LATER)
Action:
    - service: script.xiaomi_alarm1
    - service: script.flash_gateway1
This mean, after run script.xiaomi_alarm1 done, it will do continue flash_gateway1.
But Script script.xiaomi_alarm1 is a infinity loops. It’s cant be done, and cant continue script flash_gateway1.
In new config we need to call it thourgh on service script turn on. It’s will run 2 scripts same time (not wait script 1 done (end) and will do script 2).
I don’t known 4 new mode for script and automation, but i try per mode one by one. And Parallel is work. And option max for Parralel to do maxium loops. I using 90 for sound and 1000 for light. I think it right for me. (depend on you)
In Script (Using Parallel mode)
xiaomi_alarm1:
  sequence:
  - data:
      gw_mac: ####
      ringtone_id: 13
      ringtone_vol: 50
    service: xiaomi_aqara.play_ringtone
  - delay:
      seconds: 6
  - service: script.xiaomi_alarm2
  mode: parallel
  max: 90
xiaomi_alarm2:
  sequence:
  - data:
      gw_mac: ####
      ringtone_id: 13
      ringtone_vol: 75
  - delay:
      seconds: 6
  mode: parallel
  max: 90
flash_gateway1:
  alias: Flash Gateway On Red
  sequence:
  - data:
      brightness: 255
      color_name: red
      entity_id: light.gateway_light_####
    service: light.turn_on
  - delay:
      milliseconds: 600
  - data:
    service: light.turn_off
  - service: script.flash_gateway2
  mode: parallel
  max: 1000
flash_gateway2:
  alias: Flash Gateway On Blue
  sequence:
  - data:
      brightness: 255
      color_name: blue
  - delay:
      milliseconds: 600
  - data:
  mode: parallel
  max: 1000
And now, it’s work. Thank you very much, @123
Hi, I try to implement your configuration but snoozing doesn’t seem to work. Can you please share you entire code please?
Thanks Chris.
I will post it after my school day, 3pm GMT +7, pls remind me ^^
Ok Thanks a lot.
This is my script, so many scripts, because i devided it to make another automation (sercurity alarm)
xiaomi_alarm3:
  sequence:
  - repeat:
      count: 180
      sequence:
      - data:
          gw_mac: 7C:49:EB:1B:AA:52
          ringtone_id: 13
          ringtone_vol: 90
      - delay:
          seconds: 6
  mode: restart
flash_gateway3:
  alias: Flash Gateway On Blue and Red
  sequence:
  - repeat:
      count: 600
      sequence:
      - data:
          brightness: 255
          color_name: blue
          entity_id: light.gateway_light_7c49eb1baa52
      - delay:
          seconds: 1
      - data:
          brightness: 255
          color_name: red
      - delay:
          seconds: 1
  mode: restart
alarm_off:
  alias: Alarm was disarmed
  sequence:
  - service: script.turn_off
      entity_id:
      - script.flash_gateway3
      - script.xiaomi_alarm3
green_light_safe:
  alias: Green light for safe
  sequence:
  - service: light.turn_on
      color_name: green
      brightness: 100
  - delay:
      seconds: 5
  - service: light.turn_off
alarm_off_greenlight:
  alias: Alarm was disarmed & Green light on
  sequence:
      entity_id:
      - script.alarm_off
      - script.green_light_safe
alarm_snooze:
  alias: Alarm was Snooze
  sequence:
  - service: script.alarm_off
      color_name: purple
      brightness: 100
  - delay:
      seconds: 5
  - delay:
      seconds: 300
    entity_id:
  - delay:
      seconds: 300
    entity_id:
    - script.alarm_off
And my automation. like above but custom script turn on to run 2 scripts.
    entity_id:
Great thanks. Maybe your lovelace?
I tried 123 code it works to start but not the snooze
My lovelace using HA-Card (Custom Component)
  - content: |
      # Alarm System
    style:
        ha-card {
          background-color: transparent !important;
          box-shadow: none !important;
      ha-markdown:
          h1 {
            font-size: 25px;
            font-weight: bold;
            text-align: center;
            letter-spacing: '-0.01em';
    type: markdown
  - entities:
      - entity: input_boolean.wakestatus_1
      - entity: sensor.time
        name: The Time Now
      - entity: sensor.wake_time_1
      - entity: input_number.wakehour_1
      - entity: input_number.wakeminutes_1
    show_header_toggle: false
    type: entities
  - cards:
      - entity: input_boolean.wakeweekday_sun_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_mon_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_tue_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_wed_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_thu_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_fri_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
      - entity: input_boolean.wakeweekday_sat_1
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
    type: horizontal-stack
  - cards:
      - entity: script.alarm_off_greenlight
        hold_action:
          action: toggle
        icon: 'mdi:alarm-off'
        icon_height: 50px
        show_icon: true
        show_name: true
        show_state: false
        tap_action:
          action: more-info
        type: button
      - entity: script.alarm_snooze
        hold_action:
          action: more-info
        icon: 'mdi:alarm-snooze'
        icon_height: 50px
        show_icon: true
        show_name: true
        show_state: false
        tap_action:
          action: toggle
        type: button
type: vertical-stack
I work with package. Here is my complete yaml
timer:
  wake_1:
    duration: '00:00:10'
input_boolean:
  wakeactivated_1:
    name: Alarm 1 Activated
    icon: mdi:alarm
  wakestatus_1:
    icon: mdi:alarm
  wakeweekday_sun_1:
    icon: mdi:calendar
  wakeweekday_mon_1:
    icon: mdi:calendar
  wakeweekday_tue_1:
    icon: mdi:calendar
  wakeweekday_wed_1:
    icon: mdi:calendar
  wakeweekday_thu_1:
    icon: mdi:calendar
  wakeweekday_fri_1:
    icon: mdi:calendar
  wakeweekday_sat_1:
    icon: mdi:calendar
input_number:
  wakehour_1:
    min: 00
    max: 23
    step: 1
    icon: mdi:alarm
  wakeminutes_1:
    min: 00
    max: 59
    step: 1
    sensors:
      wake_time_1:
        friendly_name: 'Wake Time 1'
        value_template: "{{'{:02d}:{:02d}'.format(states('input_number.wakehour_1') | int, states('input_number.wakeminutes_1') | int) }}"
script:
  xiaomi_alarm1:
    sequence:
    - data:
        gw_mac: 'macadress'
        ringtone_id: 13
        ringtone_vol: 50
    - delay:
        seconds: 6
    mode: parallel
    max: 10
  xiaomi_alarm2:
    sequence:
    - data:
        gw_mac: 'macadress'
        ringtone_id: 13
        ringtone_vol: 75
    - delay:
        seconds: 6
    mode: parallel
    max: 10
xiaomi_alarm3:
  sequence:
  - repeat:
      count: 180
      sequence:
      - data:
          gw_mac: 'macadress'
          ringtone_id: 13
          ringtone_vol: 40
      - delay:
          seconds: 6
  mode: restart
alarm_snooze:
  sequence:
  - service: script.alarmclock_off
  - delay:
      seconds: 300
    entity_id:
  - delay:
      seconds: 300
    entity_id:
    - script.alarmclock_off
alarmclock_off:
  sequence:
      entity_id:
automation:
  - id: 'wake_1_detect_time'
    alias: Wake 1
    description: 'Detect specified wake time'
      platform: template
      value_template: "{{ states('sensor.time') == states('sensor.wake_time_1') }}"
    condition:
     condition: template
     value_template: >
        {% set today = 'input_boolean.wakeweekday_' ~ now().strftime("%a") | lower ~ '_1' %}
        {{ is_state('input_boolean.wakestatus_1', 'on') and is_state(today, 'on') }}
      service: input_boolean.turn_on
      entity_id: input_boolean.wakeactivated_1
  - id: 'wake_1_alarm_activated'
    alias: 'Wake 1 Activated'
      platform: state
      to: 'on'
#    action:
#      service: timer.start
#      entity_id: timer.wake_1
      entity_id:
  - alias: 'Wake 1 Timer Started'
      platform: event
      event_type: timer.started
      event_data:
    condition:
      condition: state
      state: 'on'
      service: persistent_notification.create
      data_template:
        title: 'Wake 1 Activated'
        message: 'Wake 1 activated at: {{now()}}'
  - alias: 'Wake 1 Timer Finished'
      platform: event
      event_type: timer.finished
      event_data:
    condition:
      condition: state
      state: 'on'
      entity_id: timer.wake_1```
And Here is my lovelace card
cards:
  - entities:
    title: RƩveil
    type: entities
  - cards:
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
        hold_action:
          action: none
        icon_height: 40px
        show_icon: true
        show_name: true
        tap_action:
          action: toggle
        type: button
  - type: conditional
    conditions:
      - entity: input_boolean.wakeactivated_1
        state: 'on'
    card:
      type: button
      tap_action:
        action: toggle
      hold_action:
        action: more-info
      show_icon: true
      show_name: true
      show_state: false
      icon_height: 50px
EDIT Nevermind. :slight_smile: I Realised I shouldn’t edit the yaml like that, but instead click the ā€œAdd cardā€ button, and then choose to add a custom card manually. Thank yo for the code, works perfect! :smiley:
I really like the example you have here! I hope you can help me detect what I’ve done wrong though with regards to the lovelace card.
In the Overview of Home Assistant, I click to edit my dashboard, click the 3 dot dropdown menu, and then click: ā€œRaw configuration editorā€.
I then put your lovelace configuration card code at the bottom, but I cannot get it to show on the dashboard. Can you see what I’m doing wrong? This is my code:
title: Home
  - path: default_view
    title: Home
    badges: []
    cards:
      - type: entities
        entities:
          - entity: light.stuen_spots_zha_group_0x0002
          - entity: cover.gardin_balkon_window_covering
          - entity: cover.gardin_stue_window_covering
        title: Stuen
      - type: entities
        entities:
          - entity: light.loftlys_sovevarelset_level_light_color_on_off
          - entity: cover.gardin_1_window_covering
          - entity: cover.gardin_2_window_covering
          - entity: switch.ikea_of_sweden_tradfri_control_outlet_aeea6afe_on_off
          - entity: switch.ikea_of_sweden_tradfri_control_outlet_1c7f72fe_on_off
        title: SovevƦrelset
      - type: entities
        entities:
          - entity: light.loftlys_gangen_level_light_color_on_off
          - entity: binary_sensor.lumi_lumi_sensor_motion_aq2_ias_zone
          - entity: binary_sensor.lumi_lumi_sensor_motion_aq2_2ded4c05_ias_zone
        title: Gangen
      - type: entities
        entities:
          - entity: light.loftlys_hyggerummet_level_light_color_on_off
        title: Hyggerummet
      - type: entities
        entities:
          - entity: light.klaedeskabet_spots_zha_group_0x0006
        title: KlƦdeskabet
      - type: entities
        entities:
          - entity: light.loftlys_kontoret_level_light_color_on_off
        title: Kontoret
      - type: entities
        entities:
          - entity: light.loftlys_koekken_level_light_color_on_off
          - entity: cover.gardin_kokken_window_covering
        title: KĆøkkenet
cards:
  - type: entities
    entities:
    title: Alarm Clock 1
  - type: horizontal-stack
    cards:
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
      - type: button
        tap_action:
          action: toggle
        hold_action:
          action: none
        show_icon: true
        show_name: true
        icon_height: 40px
Hello thanks for this alarm i got i working and like so much that i will like more of them .
if i want this i 2 different cards ? can you help me what to change because copy them will
not work i changes i both alarms i tried to change some of the 1 to 2 but no luck ,as you can gues
i`m not a coder at all , can some one help ?
You need to duplicate the entities used in your existing, functional alarm clock in order to create a second, independent instance of the alarm clock. Changing the names of the duplicated entities (such as by changing _1 to _2) is definitely required. If it didn’t work then you must have either overlooked to rename one of the entities or within the automation itself. Review it carefully, check the automation’s trace for errors, check the log for errors and you’ll get it working eventually.
Hey! I used your code to trigger my irrigation system and it works like a charm… until I added a new sensor to my yaml and now yours seems to be problematic :frowning:
Error loading /config/configuration.yaml: while parsing a block collection in "/config/sensors.yaml", line 15, column 3 expected <block end>, but found '<block mapping start>' in "/config/sensors.yaml", line 27, column 4
I can only think (but I’m the first to admit that I don’t really know) that it has to do with the fsensor using a legacy nomenclature. Could definitely use help from anyone having a clue of what could be wrong here :frowning:
Thank you!
Here is my sensors.yaml starting line 15
platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
   sensors:
    wake_time_1:
Have you noticed that there are multiple, very obvious, indentation errors in the sensors.yaml you posted?
Is that literally how it appears or just due to a copy-paste error when you posted it on the forum?
Thanks for this @123, your instructions are really good.
I agree with you about using a single input_datetime but I haven’t been able to get it to work. I’m really bad at templates and haven’t worked out how to create a sensor for the input_datetime. How would you implement this?
Thanks!
I don’t recall an input_datetime entity in the example. Are you referring to the Template Sensor called sensor.wake_time_1?
You should know that the example was created over two years ago. A lot has changed since then and it’s highly likely there are now better ways to implement an alarm clock.
Apologies, I realised my question probably didn’t make sense…
What I meant by the input_datetime sensor is a replacement for the sensor.wake_time_1. So instead of using the sliders for the hour/ minutes I’d prefer entering the wake time using the number keys on the phone/PC. and what I don’t understand is how do I replace the hours/minutes with a manual time entry. Do I use a input_number helper? if yes I don’t know how to use the value_template to create the sensor.wake_time_1 or if I even need to?
Sorry, my yaml/ templating skills are poor and I haven’t been able to find another decent alarm clock :slight_smile:
I see. You want to modify the alarm clock’s design to use input_datetime instead of input_number.
Unfortunately I don’t have the time to adapt it to meet new requirements. Someone else will need to help you with it. Good luck.
