Hi all,
As I’m having a dynamic energy-contract, I’ve configured HA to switch on a few devices during the cheapest hour of the day.
For this, I use two helpers and three binary sensors. Naming is self-explanatory, I have split my yaml up for ease of use and readability:
config/binary_sensors/smartenergy.yaml:
sensors:
smartelec_lowest_hour:
friendly_name: "Lowest hour"
value_template: "{{ states('sensor.smartelec_current_marketprice') == states('sensor.smartelec_lowest_today_marketprice') }}"
sensors:
smartelec_below_treshold:
friendly_name: "Price below treshold"
value_template: "{{ states('sensor.smartelec_current_marketprice') < states('input_number.smartelec_treshold_marketprice') }}"
sensors:
smartelec_active:
friendly_name: "Smart active"
value_template: >
{%- if is_state('input_boolean.smartelec_both', 'on') -%}
{{- is_state('binary_sensor.smartelec_below_treshold','on') and is_state('binary_sensor.smartelec_lowest_hour', 'on') -}}
{%- else -%}
{{- is_state('binary_sensor.smartelec_below_treshold','on') or is_state('binary_sensor.smartelec_lowest_hour', 'on') -}}
{%- endif -%}
smartelec_both is off, smart_elec_treshold_marketprice is set to 0. This will cause the smartelec_active to be on if the current hour has the lowest price of the day, or if the current price is negative (this happens!)
Below is the relevant sensor config (a have a few more, but not relevant for this problem).
config/sensors/smartenergy.yaml:
- platform: command_line
command: >
curl
-X POST
-H 'Content-Type: application/json'
-H 'User-Agent: Mozilla/5.0'
-d '{"query":"query MarketPrices($startDate: Date!, $endDate: Date!) {marketPricesElectricity(startDate: $startDate, endDate: $endDate) { till from marketPrice priceIncludingMarkup}}",
"variables":{"startDate":"{{ as_timestamp(now()) | timestamp_custom('%Y-%m-%d') }}","endDate":"{{ as_timestamp(now() + timedelta(days=2)) | timestamp_custom('%Y-%m-%d') }}"}}'
https://frank-graphql-prod.graphcdn.app
name: Smart Electricity
json_attributes:
- data
value_template: "OK"
sensors:
smartelec_current_marketprice:
friendly_name: Current energy marketprice
unit_of_measurement: "EUR"
value_template: "{{ states.sensor.smart_electricity.attributes.data.marketPricesElectricity[now().hour].marketPrice }}"
sensors:
smartelec_lowest_today_marketprice:
friendly_name: Lowest energy price today
value_template: >
{%- set today = now().strftime('%Y-%m-%d') -%}
{%- set lowest = state_attr('sensor.smart_electricity','data').marketPricesElectricity | selectattr('from','match',today) | map(attribute='marketPrice') | list | min | round(5) -%}
{{- lowest -}}
I stitch everything together with automations (cleaned up the mail message, as it is not relevant to this issue):
config/automations.yaml
- id: '1652464429778'
alias: Retrieve Energy Prices
description: ''
- platform: time_pattern
minutes: '0'
hours: /4
condition: []
data: {}
entity_id:
- sensor.smart_electricity
- sensor.smart_gas
- service: notify.wiwo_smtp
target: [email protected]
message: 'Retrieved energy prices !!
title: Energy pricing {{ now().strftime("%Y/%m/%d %H:%M") }}
html: "<table border=\"1\">\n <tr><th colspan=\"4\">Pricing</th></tr>\n\
\ \n {% for item in state_attr('sensor.smart_electricity','data').marketPricesElectricity\
\ %} \n <tr>\n <td>{{ item.from }}</td>\n <td>{{ item.till }}</td>\n \
\ <td>{{ item.marketPrice }} €</td>\n <td>{{ item.priceIncludingMarkup\
\ }} €</td>\n </tr>\n {% endfor %}\n</table> \n"
- id: '1652953357220'
alias: Switch smart energy ON
description: ''
- platform: state
entity_id:
- binary_sensor.smartelec_active
to: 'on'
condition: []
- service: scene.turn_on
entity_id: scene.smartelec_scene_usage_on
metadata: {}
- id: '1652953413164'
alias: Switch smart energy OFF
description: ''
- platform: state
entity_id:
to: 'off'
condition: []
entity_id: scene.smart_energy_off
metadata: {}
The problem is, that scene.smart_energy_on is turned on unexpectedly. I can find this happens because binary_sensor.smartelec_active is switched on. Today this happened on 05:56:41. scene.smart_energy_off is activated at 05:57:36
As far as I can tell, all this depends on the cli-sensor, which will run once every four hours (hours=/4, minutes=0). This sensor should only change during that update cycle.
The question is, why this binary_sensor.smartelec_active became active at this time, and how to debug this.
Regards,
Marcel
