How to detect notifier error in HA logs?
This morning Telegram stopped working for a while.
As a result, I didn’t receive any notifications.
Checking HA logs I have seen some entries that could help to detect this failure and notify me with another system (html5, sms, etc)
Here is an entry with an error sending a notification:
Error sending message: Timed out. Args:…
Here is an entry from the security system sending an image:
Error sending file: Flood control exceeded. Retry in 458 seconds. Args:…
How could I detect these errors in the logs with an automation or with node-red?
You could use a file sensor to inspect your config/home-assistant.log file:
Or you could monitor log events with an automation:
automation:
  - alias: Telegram Errors
      platform: event
      event_type: system_log_event
      event_data:
        level: ERROR
      condition: template
      value_template: "{{ 'Error sending' in trigger.event.data.message[0] }}"
      service: notfy.by_another_method_than_telegram
      message: "{{ trigger.event.data.message }}"
Thanks, I’ll try to use the event
I’ve been struggling the configuration of my HA setup and finally I have reproduced the errors (blocking access to telegram servers in my firewall), the errors are being written to home-assistant.log and appearing in developer tools / log screen, identified as ERROR.
Nevertheless, I can’t receive any event from the system_log_event, neither with automations nor node-red.
This user had similar issues trying to catch system-log events:
Is there any known issue?
Solved: system_log has an option called “fire_event” and has to be set to true
