No problems here getting attributes from a switch in the templates tool. {{ states.switch.playstation4.attributes }}
returns {'icon': 'mdi:playstation', 'friendly_name': 'Playstation 4', 'assumed_state': False}
So it should work in the template sensor too.
@llingnau, maybe try: {{ states.switch.pc_power_24.attributes.current_power_w }} and see if it works.
Thanks all.
In my case I was trying to work out how to make a graph based on the current_power_w attribute of a smart outlet. I did it by adding the following to configuration.yaml:
# Sensors
# Weather prediction
- platform: yr
# Template to pull the power draw value from power outlet connected to Naim power amp
sensors:
naim_amp_current_power_w:
value_template: "{{ state_attr('switch.naim_amp','current_power_w') }}"
unit_of_measurement: W
device_class: power
sensor.naim_amp_current_power_w shows up as an entity now, which is easy to graph using the History Graph component.
