Hey, I wanted to share rupertas solution upgrade. The difference is that I’m able to distinguish between all states of the gate.
Make sure both Shelly channels are set as:
- Relay
- Settings → Button Type → Detached Switch
- Timer → Turn off after 0.5
- Power on default: Off
Wiring is the same on my Deimos Ultra BT A600:
Shelly->BFT
- VCC- > 51 (24V+)
- N → 50 (24V-)
- IN_1 → 20 (AUX0=6)
- IN_2- > 26 (AUX3=1)
- N/GND_1 → 60 (COM)
- N/GND_2 → 60 (COM)
- OUT1 → IC1 (IC1=0)
- OUT2 → IC2 (IC2=3)
BFT->BFT
- 51->27 (Power supply for 27th port)
The main difference is how I utilize AUX inputs:
The 20:AUX0=6
Aux logic= 6 - FLASHING LIGHT output.
Contact stays closed while leaves are operating
This one tells us if the gate is moving or stationary.
The 26: AUX3=1
Aux logic= 1 - SCA GATE OPEN LIGHT output.
Contact stays closed during opening and with the leaf open, intermittent during closing, and open with the leaf closed.
With these, we can get all the possible states, and the hardest part is that
In other words, it’s “blinking” or changing states every second or so.
Here’s the template I created to calculate all possible states:
- trigger:
- platform: homeassistant
event: start
- platform: state
entity_id: binary_sensor.gate_channel_2_input
to: "off"
for:
seconds: 4 # make this slightly longer than the lamp blink time
- platform: state
to: "on"
for:
- platform: state
to: # a null 'to' only triggers on all state changes, not attribute changes
- name: "Gate Open State"
icon: mdi:gate
state: >
{% if trigger.id == 'init' %}
{% if is_state('binary_sensor.gate_channel_1_input', 'on') %}
moving
{% elif is_state('binary_sensor.gate_channel_1_input', 'off') and is_state('binary_sensor.gate_channel_2_input', 'off') %}
closed
{% else %}
open
{% endif %}
{% elif trigger.id == 'closed' %}
closed
{% elif trigger.id == 'open' %}
open
{% elif trigger.id == 'closing' %}
closing
{% else %}
unknown
{% endif %}
- trigger:
event: start
- platform: state
entity_id: binary_sensor.gate_channel_1_input
to: "on"
for:
seconds: 4.5
- platform: state
to: "off"
for:
seconds: 4.5
- name: "Gate Move State"
icon: mdi:gate
state: >
moving
{% else%}
stationary
{% endif %}
{% elif trigger.id == 'moving' %}
moving
{% elif trigger.id == 'stationary' %}
stationary
{% else %}
unknown
{% endif %}
- sensor:
- name: "Gate Status"
icon: "mdi:gate"
state: >
{% if states('sensor.gate_open_state') == 'closed' %}
Closed
{% elif states('sensor.gate_move_state') == 'moving' and states('sensor.gate_open_state') == 'open' %}
Opening
{% elif states('sensor.gate_move_state') == 'stationary' and states('sensor.gate_open_state') == 'open' %}
Open
{% elif states('sensor.gate_move_state') == 'stationary' and states('sensor.gate_open_state') == 'closing' %}
Open
{% elif states('sensor.gate_move_state') == 'moving' and states('sensor.gate_open_state') == 'closing' %}
Closing
{% else %}
Unknown
{% endif %}
Then, using this, I created entity cards.
One for seeing both states:
type: entities
entities:
- entity: sensor.gate_move_state
secondary_info: last-updated
- entity: sensor.gate_open_state
name: Gate Open State
The other interface uses buttons with icons reflecting the gate state (Closed, Opening, Open, or Closing). The input command logic is a bit different here:
- IC1 = 0 serves as a toggle—Open, Close, or Stop—depending on the current state. Most of the time, I just want to open the gate, but occasionally, I use it to stop it mid-motion.
- IC2 = 3 is a dedicated Close command. I use this when I want to make sure the gate is closed, regardless of whether it’s currently open, opening, or even already closed—I just hit it to force it shut.
Here are the buttons:
type: vertical-stack
cards:
- type: custom:button-card
tap_action:
action: toggle
entity: switch.gate_channel_1
show_state: false
show_name: true
show_icon: true
icon: |
if (states['sensor.gate_status'].state === 'Closed') {
return 'mdi:gate';
} else if (states['sensor.gate_status'].state === 'Opening') {
return 'mdi:gate-arrow-left';
} else if (states['sensor.gate_status'].state === 'Open') {
return 'mdi:gate-open';
} else if (states['sensor.gate_status'].state === 'Closing') {
return 'mdi:gate-arrow-right';
// Default fallback icon if none of the above conditions match
return 'mdi:help-circle';
return states['sensor.gate_status'].state;
entity: switch.gate_channel_2
show_name: true
show_icon: true
tap_action:
action: toggle
icon: mdi:arrow-collapse-horizontal
styles:
card:
- height: 100px
- opacity: |
if (['closing', 'closed'].includes(states['sensor.gate_open_state'].state)) {
return '0.5'; // Semi-transparent to indicate disabled
return '1'; // Fully opaque when enabled
lock:
- pointer-events: none
state:
- value: "on"
styles:
card:
- pointer-events: |
return 'none'; // Disable button interaction
return 'auto'; // Enable button interaction
The final result looks like this:
