If you want to “ensure” the switches are off, then you’re obligated to confirm they’re off. You can use a repeat like you did or a custom integration that’s designed to perform the same thing (I don’t have a link to it handy at the moment).
The alternative is to improve the reliability of your switches so you don’t need to double-check if they’re truly off.
Not exactly on topic here but if you are doing something that is not asycnchronous (waits for a success reply but might throw an exception or not success and make an automation fail), there is a “retry” HACS integration you might want to consider that is pretty handy - if you have something that is not reliable it is sometimes a handy workaround -
How about setting a flag when you have run this automation, and do something with timers that keep retrying until all are completed or sends you a notification if something does not turn off properly?
