nope, same error.
Is this code need some modifications to work properly?
I copied it as it is and pasted into automations.yaml file and I checked its inclusion into configuration.yaml
nope, same error.
Iâm not sure what to say. So you have the IFTTT integration set up? And you used that with your IFTTT setup?
and then you set it up like this
How to get IFTTT working with new auth.
So nothing is happening at all?
Ok, actually trying again from IFTTT I get 301 error. I enabled an apache proxy by following this guide to redirect hs traffic on a specific domain like myhome.domain.com and secure it with cloudflare.
Do you have something like this?
Sorry, honestly, I have a super simple setup. Just followed the instructions and it worked for me. I dont have any redirects or anything like that.
Thanks for your patience, I was using http instead of https, DOH!
In any case your code was a missing piece in my config, big thank you
Do you know if this is mandatory to activate the API component with this in the configuration.yaml to make the IFTTT integration work ?
api:
ifttt:
key: key_here
I found the answer: NO you donât need the API component activated to make this work.
Hello Folks,
Iâm going crazy with this setupâŚ
My setup :
https://xxxx.duckdns.org:8123/api/webhook/xxxxx0f06dcf14492a8125908780b7b0a954243dxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
My problem is that I can not get to work with IFTTT.
This is how my applet looks :
Body : { "action": "call_service", "service": "vacuum.start", "entity_id": "vacuum.xiaomi_vacuum_cleaner" }
If i access the URL from web browser I get this :
Hope to get some help on this issue, thanks
Have you added the required automation in your HA configuration?
You then need to consume that incoming information with the following automation:
automation:
platform: event
event_type: ifttt_webhook_received
event_data:
action: call_service
service_template: '{{ trigger.event.data.service }}'
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
Also Iâm having an issue with this not workingâŚ
For example sent a POST to https://xxx.duckdns.org:8123/api/webhook/xxx as JSON { âactionâ: âcall_serviceâ, âserviceâ: âlight.turn_offâ, âentity_idâ: âlight.all_lightsâ } and response is â200 OKâ but nothing happens
same thing is happening to me i just noticed. but only on the ones where i want to create a phrase and have it send a webhook. other things sending webhooks works.
Didnât work for me, nothing is happening
Sticking to legacy api for nowâŚ
Which direction, IFTTT to HA or vice-versa?
Did you make sure your base_url is set correctly in configuration.yaml? Then did you save the webhook url that appeared when you created the IFTTT integration in HA? As far as I can tell, it appears once only, and then itâs gone if you donât copy and save it. Doing a POST to that url from IFTTT works to trigger an IFTTT event.
need help.
{ "action": "call_service", "service": "input_select.select_option", "entity_id": "input_select.b43_state", "option": "one" }
i tried listening ifttt_webhook_received and HA receives the payload but it doesnât change the input select optionâŚ
Sound like your webhook in IFTTT may be wrong?
Here is mine for turning on an input boolean
{ "action": "call_service", "service": "input_boolean.turn_on", "entity_id":"input_boolean.paul_in_bed" }
Edit, nevermind, I misread, thought it was input bool, not input select.
Here is the listened event:
Evento 0 generato 10:00:
"event_type": "ifttt_webhook_received",
"data": {
"option": "One",
"webhook_id": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx04b5c95876e27e47d7ef7ecfd2"
"origin": "LOCAL",
"time_fired": "2019-11-30T09:00:49.981199+00:00",
"context": {
"id": "xxxxxxxxxxxx854fea881bacbed48a4ab3",
"parent_id": null,
"user_id": null
Is the name of your input select
input_select.b43_state ?
Or is it
input_select.b43 ?
It looks like you have everything correct on the IFTTT side as far as it is talking to HA, so I would check your IFTTT automation and the inputs
yes I confirm itâs âinput_select.b43_stateâ
Here is the automation Iâm using:
- id: '1575036072589'
alias: IFTTT to HA
- event_data:
platform: event
condition: []
- data_template:
Hereâs mine
- alias: IFTTT Automation Handler
- platform: event
event_data:
- service_template: '{{ trigger.event.data.service }}'
data_template:
Looks about the same. I know this is a dumb question, but itâs happened to me a few times. Is the automation âonâ
I copied your automation and tried out, here is what I get from logs:
Error while executing automation automation.ifttt_automation_handler. Invalid data for call_service at pos 1: required key not provided @ data['option']
uff!
