Trying to follow your code, but am getting the following error:
Invalid config for [rest]: [switch] is an invalid option for [rest]. Check: rest->rest->1->switch. (See /config/configuration.yaml, line 45).
and my code looks like this:
rest:
- resource: http://192.168.12.11/state.xml
scan_interval: 32
- name: Master Bedroom Chimney Fan
value_template: "{{ value_json['datavalues']['relay1state'] }}"
switch:
- name: "Master Bedroom Chimney Fan"
turn_on:
- service: rest_command.set_relay1state
relay1state: 1
- service: homeassistant.update_entity
entity_id: sensor.master_bedroom_chimney_fan
- delay: 00:00:15
turn_off:
relay1state: 0
- delay: 00:00:15
rest_command:
set_relay1state:
url: http://192.168.12.11/state.xml?relay1={{ relay1state }}
any ideas as to the error? I saw that you directly call CURL in the res_command, but I was trying to follow the API resources. Before I tried to integrate switch into restFul, the sensor portion was giving me the correct state of the relay so I know that part is fine.
