I have made wide use of the availability: template. That way, the sensor state is unavailable rather than HA throwing template warnings/errors into my logs, which usually occurs during startup as various components are initializing. This particular one though was throwing a template error at startup, sometimes two 5 seconds apart and was bugging me as I had an availability template for the MQTT sensor and even tried adding utcnow() != 'unknown' but it turned out I simply needed to default the as_timestamp() function…
- trigger:
- platform: time_pattern
seconds: "/5"
- name: "HASS Agent My PC Idle Time"
# availability: '{{ utcnow() != "unknown" and states("sensor.lastactive") != "unknown" }}'
# state: '{{ as_timestamp(utcnow()) - as_timestamp(states("sensor.lastactive"))|float(default=0) }}'
state: '{{ as_timestamp(utcnow(),0) - as_timestamp(states("sensor.lastactive"),0) }}'
unit_of_measurement: "Seconds"
