GitHub - TazzerMAN/increase_swap_addon: This add-on increases the swap space on your system initially created for Rasberry Pi. plugin may help, easy way of increasing swap
@deniselenok, you’ll get surprised to discover that add-on was created in this very topic
Check this post.
does anyone know about limitations of this workaround with newest versions of HA OS and HA Core?
I’m doing some test with a fresh new HA install, I’ve updated everything so HA OS is v13.1 and Core is v2024.9.1
I’ve updated the init command with the last version of the first post, setting a 2 GB swap file, but after RPi restart I still get a mere 200 MB of swap file.
This was instead working properly up until HA OS 7.5.
@Vinz87 I just upgraded and tested the OP line and it worked as expected. Go to the SSH add-on and see what the log says. Feel free to paste it in your response.
I have this configuration:
username: root
password: ""
authorized_keys:
REDACTED
sftp: true
compatibility_mode: false
allow_agent_forwarding: false
allow_remote_port_forwarding: false
allow_tcp_forwarding: false
init_commands:
if [ ! -f /backup/_swap.swap ]; then fallocate -l 2G /backup/_swap.swap &&
mkswap /backup/_swap.swap && chmod 0600 /backup/_swap.swap && swapon
/backup/_swap.swap && echo SWAP_NEW_FILE_CREATED_USED ; elif [[ !
$(dmesg|grep _swap.swap) = *swap\ on* ]] ; then swapon /backup/_swap.swap &&
echo SWAP_USING_OLD_FILE ; else swapoff /backup/_swap.swap && swapon
/backup/_swap.swap && echo SWAP_FINAL_ELSE_STATEMENT ; fi
however my swap file dimensions are still ~140 MB
Protection Mode is disabled
This are the versions of my setup:
- Core 2024.9.1
- Supervisor 2024.08.0
- Operating System 13.1
- Frontend 20240906.0
Am I missing something?
also, where do the debug echo lines are printed?
That’s not the log from the add-on… You’re on the configuration tab but hit the log tab of that add-on.
I would also just wipe this add-on and re-install from scratch. After doing so, test one item at a time like your credentials before moving onto the INIT_COMMAND
I’m seeing this in my logs and are having some issues with my HA restarting, could this be the cause of that?
2024-09-11 10:19:49.947 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:19:52.359 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:19:57.413 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2024-09-11 10:19:57.561 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
2024-09-11 10:19:58.066 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:19:58.103 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:19:58.601 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-09-11 10:20:00.397 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:00.928 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt_user'
2024-09-11 10:20:00.934 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
2024-09-11 10:20:02.595 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
2024-09-11 10:20:05.871 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:05.890 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:07.330 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:11.922 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:11.941 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:13.503 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:18.149 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:18.169 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:19.782 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:21.523 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2024-09-11 10:20:21.524 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-09-11 10:20:23.841 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-09-11 10:20:23.869 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-09-11 10:20:25.150 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:25.171 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:26.960 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:31.831 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:31.852 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:34.060 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:38.950 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:38.970 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:40.843 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:45.964 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:45.983 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:47.591 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:20:52.635 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:20:52.657 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:20:55.386 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:21:00.395 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Increase Swap is stopped, restarting...
2024-09-11 10:21:00.415 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_27a7e4aa_increase_swap_addon application
2024-09-11 10:21:01.692 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on 27a7e4aa/aarch64-addon-increase_swap_addon with version 1.1.3
2024-09-11 10:21:06.095 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-2215' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1429> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
File "/usr/src/supervisor/supervisor/addons/addon.py", line 1443, in watchdog_container
await self._restart_after_problem(event.state)
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 290, in wrapper
raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
yes, without init_commands the add-on works as intended, I can access with SSH as expected.
However, in the Supervisor log I get this warning:
2024-09-11 18:37:13.523 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping addon_a0d7b954_ssh application
2024-09-11 18:38:00.743 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2024-09-11 18:38:09.218 WARNING (MainThread) [supervisor.addons.options] Unknown option 'init_commands' for Advanced SSH & Web Terminal (a0d7b954_ssh)
2024-09-11 18:38:09.599 WARNING (MainThread) [supervisor.docker.addon] Advanced SSH & Web Terminal running with disabled protected mode!
2024-09-11 18:38:09.603 WARNING (MainThread) [supervisor.addons.options] Unknown option 'init_commands' for Advanced SSH & Web Terminal (a0d7b954_ssh)
The add-on version has been updated to v19.0.0.
And this is the add-on log in which I don’t see anything strange:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Advanced SSH & Web Terminal
A supercharged SSH & Web Terminal access to your Home Assistant instance
Add-on version: 19.0.0
You are running the latest version of this add-on.
System: Home Assistant OS 13.1 (armv7 / raspberrypi3)
Home Assistant Core: 2024.9.1
Home Assistant Supervisor: 2024.08.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
[18:38:49] INFO: Docker support has been enabled.
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-mosquitto successfully started
s6-rc: info: service init-docker successfully started
[18:38:50] WARNING:
[18:38:50] WARNING: Logging in with "root" as the username,
[18:38:50] WARNING: is security wise a bad idea!
[18:38:50] WARNING:
[18:38:50] WARNING: Most attacks against SSH are attempts to login
[18:38:50] WARNING: using the "root" username.
[18:38:50] WARNING:
[18:38:50] WARNING:
[18:38:50] WARNING: Logging in with a SSH password is security wise, a bad idea!
[18:38:50] WARNING: Please, consider using a public/private key pair.
[18:38:50] WARNING: What is this? https://kb.iu.edu/d/aews
[18:38:50] WARNING:
[18:38:51] NOTICE: SFTP access is enabled
s6-rc: info: service init-ssh successfully started
s6-rc: info: service init-user: starting
[18:38:52] NOTICE: Session sharing has been disabled!
s6-rc: info: service init-user successfully started
s6-rc: info: service ttyd: starting
s6-rc: info: service sshd: starting
s6-rc: info: service ttyd successfully started
s6-rc: info: service sshd successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[18:38:52] INFO: Starting the ttyd daemon...
[18:38:52] INFO: Starting the SSH daemon...
Server listening on 0.0.0.0 port 222.
Server listening on :: port 222.
So its the add-on that’s messing with you rather than my command. I would recommend uninstalling it then reinstalling per the instructions in the OP. Ive never seen this issue of init_commands not being respected.
I think I solved installing this other add-on suggested by @deniselenok
I had to retry installing it a couple of times, I think because of not enough free RAM to compile it, but now I have:
- Increase Swap add-on runs correctly just once at restart, and I see a 2 GB swap file
- Advanced SSH & Web Terminal add-on runs without init_commands providing SSH access
