Can you please include a line that creates a backup and that saves the last two known working backups also? I would also like all my apps to update too. Should there be an empty line at the end of the script? It also appears to have updated HA OS only and not HA core, after I ran the update. I think there needs to be a delay of several minutes between installing HA OS to give the update time to install, before updating the core.
I think you can either run it as a cron every Wednesday night and check if the update is n days old or run a save backup with that automation
service: update.install
backup: true
So like this?
alias: Automatic Updates
description: Automatically keep HA components updated
- platform: state
entity_id:
- update.home_assistant_core_update
- update.home_assistant_supervisor_update
- update.home_assistant_operating_system_update
to: "on"
- service: update.install
backup: true
entity_id:
data: {}
mode: single
I just updated my simple solution a few posts up to simplify the trigger/action and account for the fact that HAOS upgrades don’t support backup: True
Dear Fellow HA Worshippers/Regular Users/Other Users accidently reading this forum thread,
I work in IT operations for some years now with some experience in upgrading different systems - with both unattended (auto) and attended (manual) updates.
I have read through the thread and found multiple very good arguments. I also did see a very good/well written complain about the thread not going into the right direction.
I conclude the following:
In general I think We can all see the benefits and the downsides of the automatically installed upgrades. I am missing though the reason why people “religiously” opposing the idea of auto-update. Some posts have already hinted or mentioned the real issue. The issue is that they fear they will have more work supporting people (on this forum) with an enabled auto-update feature.
Why would they state this? Well if you think about it, the number of people regularly patching is most likely way lower then the number of people would use the auto-update. Based on this assumption the number of people creating posts would increase, because of the increased number issues presented as naturally people just leave the version as is.
To my knowledge it is not best practice to be always up-to-date, however it is also very bad practice to be far behind. In my opinion the .0-s should be skipped for most people (and should not even be available by default (only if beta is enabled)).
My recommendation is to be up-to-date starting .3 minor relases. Anything above that was safe so far (for myself at least). I would always skip .0, .1, .2.
As for the major releases there should be some alerts stating the conflict.
I manage several home assistants in different households and it takes way too much time (espcially if we include esphome upgrades as well), therefore I would very much welcome a feature like this. I would be happy, as these households are almost identical.
As previously mentioned I fully support this feature, but with some restrictions/considerations:
Upgrade order: I would create in the long run an order list. This list would determine the order of upgrades based on the actually available new packeges. Should Core be upgraded first or Zigbee2MQTT. This order list should be followed by all integrations. I am not sure if this can already be calculated by the dependencies specified in the integrations, but if not then this should be addressed.
Automatic backups: This is provided in the UI already (during manual upgrade), but with this new setting this should be continued to be provided
Update log: Update log should be clear. It should clearly state which integration is upgraded to which version and when
Linear upgrade: It must be ensured that only one integration is upgraded at a given time as based on mycurrent experience this is required
Notifications: The option for notification should be included as most of us hooked up some kind of messaging to the HA already.
In short the idea is great and I very much support it, but in order to make it available in the UI in a smart way, there might be some prerequisites.
Lastly looking at this thread I think it worth to mention that HA is really great software, but it lacks some features for real 24/7 operation.
I hope that in 2024 there will be some focus on unattended operation of HA (possibly even make it high available) as I think lot of people would benefit from this.
Merry Christmas
You can create an automation to update anything, in any order, with any output.
order doesn’t matter. You can build an automation to update in a specific order.
Integrations don’t have updates.
You can use log.log to in your automation, as well as persistent_notification.create.
Thank you! How would yo go about triggering the update only after midnight?
To be honest I am not sure how to combine the triggers. I know that a Time Trigger does exist, but I am going to have to defer to someone else on how to make an if (x && y) then z
type automation…
I am not sure if its best practice, but worst case you could create a boolean representing the combined state.
i do like the way of auto-updating. Like shown above. But is there a way to follow the idea of powerhosting to up-to-date starting with .3 minor relases?
Frank
Really appreciate luckman212 sharing his example. Unfortunately, it does not work in HA OS 11.4. Maybe it does work if we modify this portion?
backup: >
{{ trigger.to_state.entity_id != 'update.home_assistant_operating_system_update' }}
Either way, once I realized that the visual editor was powerful enough to keep me from digging too much into the syntax of writing the yaml from scratch, I created something similar from there with a few more conditions.
That doesn’t mean I wasn’t reading the documentation while I was creating it
As petro shared here it’s all clearly documented if you want to write your own automation, script, whatever.
My outcome
Continuing with the example given I was able to create a single automation combining Core, Supervisor, and OS.
- It assigns a Trigger ID to each of the 3 triggers to differentiate them for certain conditional checks.
- It checks to see if the Core update is >= yyyy.mm.3 which I felt was safe enough to automate on considering I could not find a single month in several years where a .3 or > version was released.
- It attempts to create backups only in the cases of Core & Supervisor updates.
The full YAML
- platform: state
entity_id:
to: "on"
- platform: state
entity_id:
to: "on"
- platform: state
entity_id:
to: "on"
condition:
- condition: trigger
id:
- "1"
- condition: template
value_template: >-
{{ state_attr('update.home_assistant_core_update',
'latest_version')|regex_match("^((2\d{3})\.([1-9]|1[012])\.([3-9]|[1-3]\d))$",
ignorecase=FALSE) }}
- if:
id:
- "1"
- "2"
then:
- if:
id:
- "1"
then:
entity_id: update.home_assistant_core_update
backup: true
else:
entity_id: update.home_assistant_supervisor_update
backup: true
else:
data: {}
entity_id: update.home_assistant_operating_system_update
mode: queued
I personally felt it would be a bit simpler, safer, and easier to manage things by keeping a separate automation for each item; one for Core, one for OS, one for Supervisor, etc. I felt the combined automation I ended up with was pointlessly over-complicated. So I broke it out into 3 individual automations.
It’s not like these are taxing the system in any way. They are simple trigger based automations.
HA Core version check
I tested my Template based condition for the Core version checking in real time under Developer tools → Template. You can paste the following in there yourself to see:
Latest available version of HA Core:
{{ state_attr('update.home_assistant_core_update', 'latest_version') }}
The latest version of HA Core is >= yyyy.mm.3
{{ state_attr('update.home_assistant_core_update', 'latest_version')|regex_match("^((2\d{3})\.([1-9]|1[012])\.([3-9]|[1-3]\d))$", ignorecase=FALSE) }}
For anyone asking to add their own conditions to how they want their own home assistant instance to automatically update; I highly recommend you use the visual editor under Settings → Automations and make a new automation from scratch.
Make it do whatever you want it to.
