How to keep your recorder database size under control
If you copy it over, be sure to shut down HA first or you’ll probably end up with a partial copy.
  1. shutdown ha
  2. make sure the wal and shm files are cleaned up to verify its not still accessing the db
# ls -l home-assistant_v2.db*
-rwxr-xr-x    1 root     root     876187648 Feb 13 23:00 home-assistant_v2.db
-rwxr-xr-x    1 root     root         65536 Feb 13 23:00 home-assistant_v2.db-shm
-rwxr-xr-x    1 root     root      21980232 Feb 13 23:00 home-assistant_v2.db-wal
  1. Copy the db to your local
  2. vacuum it to recover space.
SQLite version 3.38.5 2022-05-06 15:25:27
Enter ".help" for usage hints.
sqlite> vacuum;
  1. Copy it back to your instance
  2. start HA
That helped, thanks bdraco!
it trimmed 1/3 of the size. I’m at 44GB now.
I think it won’t be enough, I have 30GB free now so I’ll need to find a more aggressive way. Is there anything I can do to signal to the DB to mark more as trashed, and then repeat the trick of vacuum in a 2nd computer?
If you are looking for a quick fix, you could stop, download again, delete the contents of the states table, vaccum again, and put it back up, than restart. That will allow you to keep the stats and you’ll only loose shorter term history.
delete from states;
Oh, that’s exactly what I need. I’m considering moving to MySQL to avoid this requirement of having twice the space available for the purge step. (Purge is vacuum, right?)
The vacuum only happens monthly Recorder - Home Assistant
Any database engine you pick should have 125% of the database size available for temp tables, rebuilds, etc to be safe. MySQL will not save you from that, and its usually not worth the price of admission unless you have a specific need as you are signing up to be the DBA for your instance.
Here is the states query updated to 2023.4.x for SQLite.
The attributes and entity_id are deduplicated so they only are stored once now which makes the attributes bytes calculation misleading.
SELECT
  COUNT(state_id) AS cnt,
  COUNT(state_id) * 100 / (
    SELECT
      COUNT(state_id)
    FROM
      states
  ) AS cnt_pct,
  SUM(
    LENGTH(state_attributes.shared_attrs)
  ) AS bytes,
  SUM(
  ) * 100 / (
    SELECT
      SUM(
    FROM
      states
  ) AS bytes_pct,
  states_meta.entity_id
FROM
  states
LEFT JOIN state_attributes ON (states.attributes_id=state_attributes.attributes_id)
LEFT JOIN states_meta ON (states.metadata_id=states_meta.metadata_id)
GROUP BY
  states.metadata_id
ORDER BY
  cnt DESC
This didn’t work for me, I got the following error:
ERROR 1242 (21000): Subquery returns more than 1 row
same issue…
same issue
It looks like we have a solution here:
Just the SQL
SELECT
  COUNT(*) AS cnt,
  COUNT(*) * 100 / (SELECT COUNT(*) FROM states) AS cnt_pct,
FROM states
GROUP BY entity_id
ORDER BY cnt DESC;
Really works. Thank you @crazyasyou
Interesting, it didn’t work for me. I use the default SQLite database and the SQLite DB Browser. I get this when I enter the SQL from @crazyasyou’s post, above:
Execution finished with errors.
Result: ambiguous column name: entity_id
At line 1:
However, it appears to work when I specify the table name for entity_id in the GROUP BY statement:
SELECT
  COUNT(*) AS cnt,
FROM states
GROUP BY states_meta.entity_id
ORDER BY cnt DESC;
I haven’t really had time to look into how accurate the results are. So far the new database schema, along with my aggressive excludes in configuration.yaml, have kept my database size reasonable.
Hello, I was wondering what’s the use case for recording events. I already excluded all frequent events from the recorder, but maybe I should exclude them all? Is there an UI or an API that can query the recorded events and show them or do something about them? Or is the only way to access them a manual sql query on the backend db? Is the history tab able to show recorded events? Thanks!
Hello, thanks a lot for these info…
I installed SQLite Web, and succeed to view the size of each table (first SQL query)…
But whe I type the second one (Viewing events usage), (and same for states usage), I only get this message :
Am I doing something wrong?
No, you’re not. When I wrote this guide, those queries were valid for that specific Home Assistant version. Over time, the database evolved, and thus the queries on my initial post aren’t working anymore. Unfortunately, I haven’t had time to revisit this post and update the queries. Please see the other messages on this topic for newer queries, contributed by other people.
I have modified the SQL queries from the original post so they work on homeassistant 2023.4.6 and later.
Modified query for states:
SELECT
  COUNT(*) AS cnt,
FROM states
INNER JOIN states_meta ON states.metadata_id=states_meta.metadata_id
ORDER BY cnt DESC
Modified query for Events:
SELECT
  COUNT(*) as cnt,
  COUNT(*) * 100 / (SELECT COUNT(*) FROM events) AS cnt_pct,
  event_types.event_type
FROM events
INNER JOIN event_types ON events.event_type_id = event_types.event_type_id
GROUP BY event_types.event_type
ORDER BY cnt DESC
Very good! thanks
Thanks a lot, it was a great support, the only solution I knew was to delete the database.
playing with recorder & the services is very helpfull !
How to show the state_attributes in order?
