I copy the database to my Mac and use DB browser for SQLite. Would that work for you?
Yep, that is what I did.
Still my DB hasn’t grown much.
I been running with 720 days for a month now and it only grew 2 MB.
Well I run other stuff such as pi hole, cloudflared etc. Containers are much easier to maintain imo.
I found out that many of my custom sensors caused an extreme amount of db entries. The reason is that any entity value change triggers the calculation of a custom sensor.
And as I was using three different entities to calculate a sum of them, it caused every 5 to 20 seconds a new db entry. Finally I solved this issue by adding a time_pattern trigger. By that the calculation isn’t triggered by the involved entities, instead its triggered by a fixed time interval. In my example every 5 minutes:
- trigger:
- platform: time_pattern
minutes: "/5"
- name: WP Energy Sum
unique_id: shelly3wp_energy
unit_of_measurement: 'kWh'
state: >-
{#- on reboot some sensors do not return a number (instead they return "unknown" or "unavailable") -#}
{%- if is_number(states("sensor.shelly3wp_channel_a_energy")) and is_number(states("sensor.shelly3wp_channel_b_energy")) and is_number(states("sensor.shelly3wp_channel_c_energy")) -%}
{{ (states("sensor.shelly3wp_channel_a_energy") | float + states("sensor.shelly3wp_channel_b_energy") | float + states("sensor.shelly3wp_channel_c_energy") | float) | round(2) }}
{%- else -%}
unavailable
{%- endif -%}
device_class: energy
state_class: total_increasing
The graph for example confirms the much rarer calculation:
Before:
After:
I never tested it, but it sounds like a possible friendly DoS attack if you use too many multiple hardware sensors in a custom sensor
Good point. My approach has been to exclude any new entities I create, unless it’s something I really need to keep. Thus any interim entities used just for a template, calculation or whatever, would be put on the “exclude” list immediately.
I like the analogy of a self-inflicted DOS attack. I think that that way Recorder is configured by default (keep everything) is setting new users up for exactly this kind of failure.
Why did you write a duplicate guide?
Just edit existing guides in future. Anyone can.
Hmm, The query doesn’t seem work SQLlite web 3.10.0
I’ve tried using these queries with SQLite 3.10.0 and I get a 400 Bad request error when executing. is anyone else seeing the same?
EDIT: Just found this mentioned here: Error "400: Bad Request" on all queries · Issue #281 · hassio-addons/addon-sqlite-web · GitHub
I made a Jupyter notebook which can be used to query the system from a backup of Home Assistant. Maybe somebody find it helpful.
In the Readme you can find out more about the process. If you store you backup on Google Drive it should be just 2 clicks via Google Colab.
Thanks @denilsonsa for the great work.
same here, but putting every part of the call into a single line seems to work for me.
Great work. Did you manipulated the backup file name or format in any way cause it looks like the script expects the naming to be different than standard backup naming, eg: Full Backup 2023-12-05 09:00:20.tar
I keep getting:
Logger: homeassistant.components.http.security_filter
Source: components/http/security_filter.py:66
Integration: HTTP (documentation, issues)
First occurred: 15:19:15 (8 occurrences)
Last logged: 16:25:57
Filtered a request with unsafe byte query string: /api/hassio_ingress/4na91HttrXMhiO4gszMnRJBZUmR7gruQGT1Dl1UWCws/states/query/?ordering=&export_ordering=&sql=SELECT%0D%0A++COUNT%28*%29+AS+cnt%2C%0D%0A++COUNT%28*%29+*+100+%2F+%28SELECT+COUNT%28*%29+FROM+states%29+AS+cnt_pct%2C%0D%0A++states_meta.entity_id%0D%0AFROM+states%0D%0AINNER+JOIN+states_meta+ON+states.metadata_id%3Dstates_meta.metadata_id%0D%0AGROUP+BY+states_meta.entity_id%0D%0AORDER+BY+cnt+ASC
Filtered a request with unsafe byte query string: /api/hassio_ingress/4na91HttrXMhiO4gszMnRJBZUmR7gruQGT1Dl1UWCws/states/query/?ordering=&export_ordering=&sql=SELECT+%0D%0A++++entity_id%2C%0D%0A++++COUNT%28*%29+AS+cnt%0D%0AFROM+states%0D%0AGROUP+BY%0D%0A++++entity_id%0D%0AORDER+BY%0D%0A++++COUNT%28*%29+DESC%3B
Filtered a request with unsafe byte query string: /api/hassio_ingress/4na91HttrXMhiO4gszMnRJBZUmR7gruQGT1Dl1UWCws/states/query/?ordering=&export_ordering=&sql=SELECT%0D%0A++states_meta.entity_id%2C%0D%0A++count%28*%29+cnt%0D%0AFROM%0D%0A++states%0D%0A++LEFT+JOIN+states_meta+ON+%28%0D%0A++++states.metadata_id+%3D+states_meta.metadata_id%0D%0A++%29%0D%0AGROUP+BY%0D%0A++states_meta.entity_id%0D%0AORDER+BY%0D%0A++cnt+DESC%3B
Filtered a request with unsafe byte query string: /api/hassio_ingress/4na91HttrXMhiO4gszMnRJBZUmR7gruQGT1Dl1UWCws/states/query/?ordering=&export_ordering=&sql=SELECT%0D%0A++statistics_meta.statistic_id%2C%0D%0A++count%28*%29+cnt%0D%0AFROM%0D%0A++statistics%0D%0A++LEFT+JOIN+statistics_meta+ON+%28%0D%0A++++statistics.metadata_id+%3D+statistics_meta.id%0D%0A++%29%0D%0AGROUP+BY%0D%0A++statistics_meta.statistic_id%0D%0AORDER+BY%0D%0A++cnt+DESC%3B
Filtered a request with unsafe byte query string: /api/hassio_ingress/4na91HttrXMhiO4gszMnRJBZUmR7gruQGT1Dl1UWCws/events/query/?ordering=&export_ordering=&sql=SELECT%0D%0A++COUNT%28*%29+as+cnt%2C%0D%0A++COUNT%28*%29+*+100+%2F+%28SELECT+COUNT%28*%29+FROM+events%29+AS+cnt_pct%2C%0D%0A++event_types.event_type%0D%0AFROM+events%0D%0AINNER+JOIN+event_types+ON+events.event_type_id+%3D+event_types.event_type_id%0D%0AGROUP+BY+event_types.event_type%0D%0AORDER+BY+cnt+ASC
The secret: “It seems that the queries have to be all on one line, then they work”
Can you rewrite them and share them, so us that not strong in SQL also can use them
I used these settings for about 5 months:
recorder:
#How many seconds to wait before writing data to db, default is 1 second.
commit_interval: 32
#How many days to keep the data before purging it, default 10 days.
purge_keep_days: 720
auto_purge: true
auto_repack: true
And my DB grew to about 770MB.
Now I wanted to reduce it to 60 days:
recorder:
commit_interval: 32
purge_keep_days: 60
auto_purge: true
auto_repack: true
However, after running this a couple of days, my db size is not decreasing. Why is it not purged?
The purge is not run daily. I read somewhere (probably this thread) that it’s only once a month, or is it once a week?
Anyway, you can do the purge from within HA. Developer Tools / Services / Recorder: Purge.
NOTE: Be sure to select the check box for Repack and turn on the slider switch that’s hidden way over on the right. I have no idea why you have to select this option twice, but that’s how it is.
Give it a few minutes to work and you should see your db size diminish. BTW, 770M is low, given your 720 days purge setting. With the default of 10 days mine would jump up to 3G in no time. I had to ruthlessly exclude everything I could and shorten the purge setting to make it manageable. Of course there have been some improvements since then, so maybe what you’re seeing is more typical now.
Purge is ran every night. Purge does not reduce the size, it removes the data. The allocated memory stays the same.
Repack (which is what reduces your database size) runs every second sunday of the month. Also, repack is not instant, it takes hours or days in some cases.
Thanks both of you. Then I will just wait and see, no rush. Yes its quite öow for me. Since I use a NUC and 120GB SSD I have plenty of space I don’t worry about tear.
Yeah, that’s all I do. Just wait. IMO it’s pointless to run all these purge/repack services so many people do. It serves very little purpose because memory is cheap and it just bogs down your system when it’s repacking.
