How to list all sensors with attribute = ‘battery_level’
Although they appear in Developer Tools/States, the script don’t work for them…
All of the temperature / humidity sensors
My battery state is not a sensor, but a attribute of a sensor. That’s why I didn’t work for you.
Maybe this is a solution: 🔋 Lovelace: Battery state card
Thank you. I’ll try to integrate it.
hi, how to fix this?
{{ states.sensor
  | selectattr('attributes.device_class', 'defined')
  | selectattr('attributes.device_class', 'eq', 'battery')
  | selectattr('state', 'lt', 25) # <- this will not work: TypeError: '<' not supported between instances of 'str' and 'int'
  | map(attribute='attributes.friendly_name' )
  | list }}
I think that some states are a ‘int’ and some ‘str’
Maybe you can use the auto-entities card.
even as this seems to be solved, you can use auto-entities card as @LocoLoco proposed.
On the card, you can use code like this:
type: custom:auto-entities
card:
  type: entities
filter:
  include:
    - entity_id: '*battery_level*'
  exclude: []
sort:
  method: entity_id
This an easier way for new and unexperienced users and every device with this battery entities will be added automatically.
