I’m trying to find a workaround for the issue with rflink component.
I have an RF opening sensor that sends 'eurodomest_278429_01', 'command': 'on' or 'ev1527_087bd6_0e', 'command': 'on' when I open the door, and 'eurodomest_278429_00', 'command': 'off' or 'ev1527_087bd6_07', 'command': 'on' when I close it.
I created 4 switches to represent these in HA.
Ideally I want to have a switch that reflects the state of my door based on that mess because I need only one source of information, not 4.
I created an input_boolean and turn it on or off using automation on state change of these 4 switches.
The problem is rflink component changes state of corresponding switches automatically, but it is not enough because if the switch is already on and rflink receives another on command, my automation won’t work because there is no change of state (on->on). Same goes to situation with off->off.
So I hope that it is possible to listen to these rflink events and then change state of my input_boolean.
How can I do that?
Or any other ideas how to resolve my issue?
p.s I have a working solution, but it stops working properly if you open/close door within 1 second interval, that’s why I’m keep looking for a better one.
thanks for your help.
unfortunately, it seems like event_type is different in rflink case.
In debug log I can see messages like:
2018-04-06 01:02:10 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘eurodomest_278429_04’, ‘command’: ‘on’}
2018-04-06 01:02:10 DEBUG (MainThread) [homeassistant.components.rflink] passing event to [<Entity 1st floor window tampered detector: off>]
but even if I change event_type to command and replace event_data with id, it does bot trigger anything…
Sorry. I’m reading your original post and I’m getting a bit confused…
How many physical sensors do you actually have?
I’m guessing you want to catch their signal and have them displayed in HA.
If you have a single physical sensor, are you trying to say it sends a different message each time you open the door?
Can you share the code that you already have?
Currently I’m trying to set up one Kerui D026 door sensor.
Exactly it sends randomly one of the following two:
‘eurodomest_278429_01’, ‘command’: ‘on’
‘ev1527_087bd6_0e’, ‘command’: ‘on’
But opening is not a problem as I can define eurodomest_278429_01 as an rflink switch and ev1527_087bd6_0e ad its alias.
The problem is closing event because it’s impossible to alias these two as their states are completely opposite :
‘eurodomest_278429_00’, ‘command’: ‘off’
‘ev1527_087bd6_07’, ‘command’: ‘on’
And the event just does not reach my automation if the command and the corresponding switch’s states are the same
That’s basically the root of the problem. Here is the code to overcome it:
configuration.yaml
input_boolean:
1st_floor_window_detector:
name: “1st floor window detector”
initial: off
icon: mdi:door
As you can see, it requires plenty of effort to make one sensor to work properly.
I have to mention that without those 1s delays the automation would work strangely or even fail to work because when in response to an event from my sensor I immediately change state of its HA representative switch back (I need to do that otherwise I would not receive any further state changes), rflink component sends a comment back to the sensor and immediately receives (a copy of?) the original event, which turns the HA switch back etc… But if I add a little delay, it works as expected.
And this solution has has a flaw - if one opens and closes the door within that delay, the right state of those 3 HA switches becomes inconsistent and would not reflect the actual state anymore. I can add another automation to call that set_up_rf_detectors once a hour or whatever, but it’s still far from ideal.
That’s why I wanted to receive original events and handle my input_boolean.1st_floor_window_detector appropriately.
Thanks.
For starters it looks like the Kerui isn’t being correctly decoded, check this thread
Also looks like there are actually 2 sensors in the D026: open/close and tamper.
Anyhow, since you managed to do most of the work, we’re almost there with what you’ve done, until a fix is provided.
This is what I would do for now:
You don’t need to display these additional sensors, just display that last one
That should make it easier to do your automations now.
Think the code indentation is correct, I’ve not tested in my setup, but bear this in mind if you get errors
looked into rflink.py and finally got the answer.
first of all, you need to configure the switch to fire events like this
- platform: rflink
devices:
eurodomest_278429_01:
aliases: ev1527_087bd6_0e
name: “1st floor window opened detector”
fire_event: true
then you need to add the following automation:
- id: catch_rflink_event
hide_entity: true
- platform: event
event_type: button_pressed
event_data:
entity_id: switch.1st_floor_window_opened_detector
I’m currently in the process of merging three separate automations into one with conditional service_template, it does not let me do the following (errors or doesn’t work):
- id: catch_1st_floor_window_detectors_event
hide_entity: true
- platform: event
event_data:
- platform: event
event_data:
entity_id: switch.1st_floor_window_closed_detector_1
- platform: event
event_data:
entity_id: switch.1st_floor_window_closed_detector_2
service_template: >
{% if {{ trigger.event.data[‘entity_id’] == ‘switch.1st_floor_window_opened_detector’ }} %}
input_boolean.turn_on
input_boolean.turn_off
entity_id: input_boolean.1st_floor_window_detector
Update: almost there, just a couple of niggles to resolve, anyone?
I received a couple of the KERUI D026 sensors in today’s mail.
They work with the Sonoff RF bridge. I see 3 separate Data strings being transmitted and I expect to see a 4th one on low battery - I’ll hook one up to my variable power supply later and check it out.
My initial testing is with node-red - simply an MQTT input node connected to a debug output, the MQTT node is subscribed to +/sonoffbr/+ to monitor all the bridge traffic.
The JSON object from the bridge shows 3 different data strings. 1 for tamper, 1 for magnet close (closed) and a third for magnet away (open) these are consistent for each action.
What firmware do you use? I used RF bridge with Espurna, but it was unstable so I switched to Arduino Mega/RFLink connected to RPi via USB to avoid potential connection issues.
I didn’t see anything like that, only 3 states. Oh well…
Please let me know when you have some results.
I’m pretty happy with my current setup, will see how it goes.
Will publish my final config later.
that’s great news. need to try it as well to set up mine properly
but is it still capable to send an open/close signal when its battery level is say, 5V?
I’ve got a Kerui D026 sensor and want to connect it to home assistant. I can read the rf code from the D026 using rpi_rf on my home assistant pi with a heterodyne antenna. How do I set-up HA to use this code to tell me when the door is open, closed, tampered with, or low on battery? Thanks!
Provided your ha can communicate with it, what I normally do is enable discovery, get the sensor to send data (open close door) and the sensor normally shows up. Then I get the code from the discovery and manually add it in my config
If you have set automatic_add: false, you can also set rflink logger to info to view the events. This can be done without restarting, from services view, calling to logger.set_level with Service Data like:
When sniffing the sensor signals with Rflink, I could see the sensor uses protocol ev1527 although HA Rflink logger could see Eurodomest protocol.
I set up everything (ON, OFF; Battery with ev1527)
