How to make a dumb 3 way bulb lamp smart
I’ve been working on getting things smaller for you. Here are the items I put into this lamp.
  • M5Stamp ESP32S3 Module - I used this one but would suggest using this alternative with pins. The one I used does not come with pins and if you’re not an experts with the soldering iron it’s near impossible to get things connected.
  • SunFounder 2 Channel DC 5V Relay - This is the smallest I could find. If anyone has seen something smaller, please let me know.
  • A small box. Wish I had a 3D printer to make something just right. I had to cut out some plastic that reduced the space in the box. As you can see below this is a tight fit.
  • 18 Guage 3 conductor wire - After ordering this I found 25ft at Lowes for $11.
Two wire connectors. I couldn’t get two of the new ones I listed in the first post inside the box with everything. Fortunately I had an alternative that was slightly narrower to make everything fit.
Here’s the open box loaded:
Here’s everything buttoned up:
And here it sits in it’s normal place:
There was sensitivity with the touch sensor with this lamp. I’m wondering if the issue is my shoddy connections, because there are no pins on the esp32. I order a few of the second M5Stamp with the pins to see if it works better, like it did in the standard bulb lamp I built. To deal with the sensitivity I had to use the code I worked out earlier. Here is the code I used in lamp:
esphome:
  friendly_name: "master-bed-touch-lamp"
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
  level: INFO
#  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Master-Touch-Lamp"
# Enable Web server.
web_server:
  port: 80
captive_portal:
  # hack so the touch sensor doesn't kick off at power on
  - platform: uptime
    update_interval: 30s
  #Readings calculated from espTouch sensors
#    name: "Handle Touch"
    internal: True
    update_interval: 333ms # a third of a second between check of touch
    accuracy_decimals: 0
    lambda: |-
      static uint32_t touch_cnt;
      static uint32_t prev_val;
      static uint16_t first_time = 1;
      static uint16_t start_up_delay = 30; // about 10 seconds - 30*333ms
      uint32_t cur_val;
      cur_val = ((uint32_t) id(touch_sensor)->get_value());
      if( first_time ){
        start_up_delay -= 1;
        if( start_up_delay <= 0){
          ESP_LOGI("custom", "Initial touch value, cur is: %d", cur_val);
          first_time = 0;
          touch_cnt = 0;
        else
          ESP_LOGI("custom", "Establishing initial touch sensor value, cur is: %d", cur_val);
      else if( !touch_cnt && (cur_val > (prev_val + 25000))){
        ESP_LOGI("custom", "initial touch, value increased from %d to %d", prev_val, cur_val);
        touch_cnt = 1;
      else if( touch_cnt > 0 ){
        if( cur_val < (prev_val - 25000)){
          ESP_LOGI("custom", "done touch %d, value decreased from %d to %d", touch_cnt, prev_val, cur_val);
          if( touch_cnt > 10)
            ESP_LOGI("custom", "ignore touch");
          else if (touch_cnt > 2)
            ESP_LOGI("custom", "change brightness");
            id(brightness_step).press();
          else
            ESP_LOGI("custom", "push power button");
            id(power).toggle();
          touch_cnt = 0;
          // force skipping a couple after we handle a touch
          start_up_delay = 2;
          first_time = 1;
        else
          if( touch_cnt < 30){
            touch_cnt += 1;
            ESP_LOGD("custom", "multi touch %d, value %d to %d", touch_cnt, prev_val, cur_val);
          else {
            ESP_LOGD("custom", "Reset touch because count too high %d, value %d to %d", touch_cnt, prev_val, cur_val);
            touch_cnt = 0;
            start_up_delay = 2;
            first_time = 1;
      prev_val = cur_val;
      return ((uint32_t) id(touch_sensor)->get_value());
esp32_touch:
  setup_mode: False
  measurement_duration: 0.25ms
#  low_voltage_reference: 0.5V
#  high_voltage_reference: 2.4V
#  voltage_attenuation: 1V
binary_sensor:
  - platform: esp32_touch
#    name: "esp32 touch sensor"
    #pin: GPIO32
    pin: GPIO5
    threshold: 10
    filters:
      # Small filter, to debounce the spurious events.
      - delayed_on: 10ms
      - delayed_off: 10ms
button:
  # button to cycle brightness
    on_press:
      then:
        if:
            and:
              # if light is off
              - switch.is_off: low_level
              - switch.is_off: high_level
          then:
            # set to lowest level
            - light.turn_on:
                brightness: 33%
          else:
            if:
                and:
                  # if at low bright
                  - switch.is_on: low_level
              then:
                # go to medium bright
                - light.turn_on:
                    brightness: 66%
              else:
                if:
                    and:
                      # if at medium bright
                      - switch.is_on: high_level
                  then:
                    # go to high bright
                    - light.turn_on:
                        brightness: 100%
                  else:
                    # finally if at high bright go to low bright
                    - light.turn_on:
                        brightness: 33%
  # restart-button
  - platform: restart
switch:
  - platform: gpio
    #name: "low_level_filament"
    pin: GPIO7
    inverted: true
    internal: True
  - platform: gpio
    #name: "high_level_filament"
    pin: GPIO9
    inverted: true
    internal: True
    #name: power
    internal: True
    restore_mode: RESTORE_DEFAULT_OFF
    lambda: |-
      if (id(low_level).state || id(high_level).state) {
        return true;
      } else {
        return false;
    turn_on_action:
      - light.turn_on:
          brightness: 33%
      #- switch.turn_on:
    turn_off_action:
      - light.turn_off:
output:
    type: float
    write_action:
#      - lambda: |-
#          ESP_LOGI("custom", "Write action state = %f", state);
      - if:
            lambda: return ((state > 0) && (state < .34));
          then:
            - switch.turn_on: low_level
            - switch.turn_off: high_level
          else:
            - if:
                  lambda: return ((state >= .34) && (state < .67));
                then:
#                  - lambda: |-
#                      ESP_LOGI("custom", "Low level state = %f", state);
                  - switch.turn_off: low_level
                  - switch.turn_on: high_level
                else:
                  - if:
                        lambda: return ((state >= .67) && (state <= 1));
                      then:
#                        - lambda: |-
                      else:
                        - if:
                              lambda: return ((state == 0) );
                            then:
#                              - lambda: |-
#                                  ESP_LOGI("custom", "Turn light off = %f", state);
light:
  - platform: monochromatic
    output: output_comp
    gamma_correct: 1
    default_transition_length: 10ms
Hopefully this packaging will address the WAF. This is my third post in a row on this thread so I will not be able to post again unless someone else response on the thread. Once I get the other M5SampS3 controllers I’ll provide an update.
