Sorry, I wasn’t suggesting your suggestion was bad, it just doesn’t work in my environment. Have a good one.
I did get the esp32 wroom to work with this configuration:
esphome:
friendly_name: lamp_esp32_dim_touch
esp32:
board: esp32dev
#framework:
# type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Lamp-Esp32-Dim-Touch"
# Enable Web server.
web_server:
port: 80
captive_portal:
# restart-button
button:
- platform: restart
output:
- platform: ac_dimmer
gate_pin: 21
zero_cross_pin:
number: 19
mode: INPUT_PULLUP
# input: true
inverted: yes
light:
- platform: monochromatic
output: dimmer1
name: esp32 Dimmerized Light
I then switched from using the LED ceiling light to just a standard socket dimmable bulb and sadly I see the flicker problem that is mentioned across the web. I’m going to pick up a higher quality dimmable LED bulb and see if it still flickers a lower power settings.
I decided to try using the 5v pin instead of the 3.3 pin to drive the dimmer. Upon doing this the performance running on the ESP 32 was similar to the ESP 8266. At 5v the flicker was significantly reduced when the light was not at full power. However the remaining flicker makes the light unexceptionable when dimmed.
I agree but then you have the scenario where if there is an issue with any motion detector etc., someone not familiar with the situation trying to turn the light on and actually turning it off, and it still won’t go on, etc. So - not ideal but may work for some people.
I agree, the WAF is important - particularly if you are in a situation like me where nyou wife doesn’t like it but tolerates it. Every once in a blue moon however, I do get the statement similar to “Hey that’s kind of cool.”
Hi, great work on this
Do you mind posting demo videos?
I’m leaning towards rotary encoder because my wife gets annoyed having to long press the wall switch to dim the smart lights
Once I try a couple of different LED bulbs to see if I can find a bulb that doesn’t flicker when dimmed I’ll try and capture and post a video.
Using the esp32 I did manage to get the lamp to work as a touch sensor. Some instructions were posted here. I picked up a GE 150W LED to give it a try. Sadly the flicker was terrible with the ESP32. I switched back to the esp8266 and the flicker was minimal with this bulb, however not perfect. The change in flicker indicates the ESP board has an impact on the signal being sent to the dimmer board. I’m not sure how to address this. I’ve order a few items to just try turning the lamp into a smart three way lamp, as I know the three way bulb works without flicker. The items are as follows:
Satco 3 way socket
DC 5V Relay Module 2-Channel Relay
ESP32-WROOM Development Board 2-channel WIFI Relay Module
The relay board and the ESP with relay are redundant. I hop to use the ESP with relay. The separate relay board is just a backup.
The touch sensor is supported natively by the ESP32, ESP32-S2, and ESP32-S3 chips so you’ll have to use one of those to do the touch detection.
I have put my project on hold; I was able to get the touch detection working well, and independently I was able to get the triggering of the lamp’s capacitive touch sensor working, but so far I haven’t figured out how to get the two to work concurrently. The problem I’m running into is that I’m connected to the lamp’s body to detect touches, and I’m also connecting the lamp’s body to a capacitor and a SPST switch (controlled by the ESP) and then to the input of the lamp’s capacitive touch sensor. So I’m getting a feedback loop where I’m both trying to detect touches and simulate touches simultaneously.
My next thought is to break open the lamp’s capacitive touch device to see if I can trigger it some way other than a change in capacitance. It will probably be a month or more before I pick this back up though.
Edit:
here’s what I’ve done so far, which doesn’t work. If you disconnect the black wire from the base of the lamp but leave purple connected, it detects touches perfectly. If you disconnect purple but leave black connected, it simulates touches and controls the dimmer perfectly. If you have both connected, it goes crazy. If you have neither connected, nothing works.
I’m using a triple 2-channel multiplexer chip because that’s just what I happened to have on hand. Any sort of SPST switch would work in its place.
I received the dual relay board that doesn’t have an integrated ESP. I ran a test with this board and esp32-wroom board. The code below appears to work. I say appears as I don’t have the new three way socket yet so I just watched the relay response. The lamp is converted to a touch lamp. The only issue is the touchpad code runs at boot, so every time the device reboots the light would be turned on to lowest power. Hopefully I can find a fix as I don’t want the lamps to be on after a power outage.
esphome:
esp32:
board: esp32dev
# Enable logging
logger:
api:
encryption:
ota:
password: !secret ota_secret
wifi:
ap:
web_server:
port: 80
captive_portal:
# restart-button
button:
- platform: restart
switch:
- platform: gpio
pin: 12
- platform: gpio
pin: 13
esp32_touch:
setup_mode: false
iir_filter: 10ms
binary_sensor:
- platform: esp32_touch
name: "ESP32 Touch Pad GPIO4"
pin: GPIO4
threshold: 320
filters:
# Small filter, to debounce the spurious events.
- delayed_on: 10ms
on_click:
- min_length: 10ms
max_length: 500ms
then:
if:
condition:
and:
- switch.is_off: low_level
- switch.is_off: high_level
then:
- switch.turn_on: low_level
- switch.turn_off: high_level
else:
- switch.turn_off: low_level
- min_length: 500ms
max_length: 10s
then:
if:
condition:
and:
then:
else:
if:
condition:
and:
- switch.is_on: low_level
then:
- switch.turn_on: high_level
else:
if:
condition:
and:
- switch.is_on: high_level
then:
else:
For purposes of reboots, on bootup you can check the last state from an input helper possibly (whihc would have to be updated as things change so it is ‘ready’ to be read at bootup - ?
Found a way to avoid processing the short event that happens at boot on the touch sensor. The implemented ignores short touches for 30s after boot.
esphome:
esp32:
board: esp32dev
# Enable logging
logger:
api:
encryption:
ota:
wifi:
ap:
web_server:
port: 80
captive_portal:
- platform: uptime
update_interval: 30s
# restart-button
button:
- platform: restart
switch:
- platform: gpio
pin: 12
- platform: gpio
pin: 13
esp32_touch:
setup_mode: false
iir_filter: 10ms
binary_sensor:
pin: GPIO4
threshold: 320
filters:
- delayed_on: 10ms
- delayed_off: 10ms
#on_press:
on_click:
- min_length: 10ms
max_length: 500ms
# Short touch to turn light on and off
then:
if:
# test to ignore random event on boot
condition:
- lambda: 'return id(time_since_boot).raw_state > 10;'
then:
if:
condition:
and:
# if light is off
then:
# then we turn it on
else:
# else it's on so we turn it off
- min_length: 500ms
max_length: 10s
# longer touch to change brightness
then:
if:
condition:
and:
# if light is off
then:
# set to lowest level
else:
if:
condition:
and:
# if at low bright
then:
# go to medium bright
else:
if:
condition:
and:
# if at medium bright
then:
# go to high bright
else:
# finally if at high bright go to low bright
Got my parts in and I’m happy to say it works. I still need to package the added electronics and install the thing in the lamp housing. At this point things look good. You can control the three light level and turn the thing on and off. I’m using the integrated esp32 with 2 relays and the light socket that I mentioned above. In the picture below the metal box is just a testing substitute for the lamp housing to act as the touch sensor.
In home assistance the device looks like this:
The esphome code is:
esphome:
friendly_name: fr brian side lamp
esp32:
board: esp32dev
#framework:
# type: arduino
# Enable logging
logger:
api:
encryption:
ota:
wifi:
ap:
ssid: "FR-Lamp-Touch"
web_server:
port: 80
captive_portal:
# hack so the touch sensor doesn't kick off at power on
- platform: uptime
esp32_touch:
setup_mode: False
iir_filter: 10ms
binary_sensor:
#pin: GPIO33
pin: GPIO32
threshold: 290
filters:
- delayed_on: 10ms
- delayed_off: 10ms
#on_press:
on_click:
- min_length: 10ms
max_length: 500ms
then:
if:
condition:
then:
- button.press: pwr_btn
- min_length: 500ms
max_length: 10s
then:
- button.press: cycle_brightness
select:
optimistic: true
options:
- "off"
- "low"
- "med"
- "high"
initial_option: "off"
# set_action:
# - logger.log:
# format: "Chosen option: %s"
# args: ["x.c_str()"]
on_value:
then:
- lambda: |-
if (id(modus_mode).active_index() == 0) {
id(low_level).turn_off();
id(high_level).turn_off();
} else if (id(modus_mode).active_index() == 1) {
id(low_level).turn_on();
} else if (id(modus_mode).active_index() == 2) {
id(high_level).turn_on();
} else if (id(modus_mode).active_index() == 3) {
# restart-button
button:
- platform: restart
on_press:
then:
if:
condition:
and:
# if light is off
then:
- select.set:
option: "low"
else:
- select.set:
option: "off"
name: cycle brightness
on_press:
then:
if:
condition:
and:
# if light is off
then:
- select.set:
option: "low"
else:
if:
condition:
and:
# if at low bright
then:
- select.set:
option: "med"
else:
if:
condition:
and:
then:
# go to high bright
- select.set:
option: "high"
else:
- select.set:
option: "low"
switch:
- platform: gpio
pin: 16
#inverted: true
- platform: gpio
pin: 17
Will need to figure out a way to have a nice control inside of HA. Should be something like a ceiling fan control. If anyone has knowledge on how to do the HA side please provide some suggestions.
Burning the code to the integrated esp32/relay board required me to use the offline esphome code. The GUI version failed to establish communications with the device. Once I get the build finished in the lamp with the electronics protected I’ll write everything up as a share your project item.
Someone asked for a video of the device working. I tried to add one but it doesn’t appear this forum allows the posting of videos. So if you still want a video just let me know where you want it posted.
enjoy.
Just installed everything in the lamp. Used 18 gauge x 3 strands wire that I got from home depot for $.75 per foot between the 3 way socket to the electronics. The electronics are in a small box outside the lamp. For power I have a USB adaptor providing 5V and the old plug providing 110 to the electronics box. Coming out the other side is the 18x3 gauge wire and a much thinner wire connected to the lamp as the touch sensor. Glad to say I now I have smart 3 bulb lamp that can be enabled by touch or from HA. Still need to work the presentation on the HA side to provide a better way to select brightness. Right now just using the power button in HA to turn lamp on and off.
I would set up the esp code to present a monochromatic light as the only external device, and everything else would be internal only. That would result a light with a dimmer slider in home assistant. You can set up the code so that it turns on the low element between 0-33%, the high element between 33-66%, and both elements between 66-100%. When you touch the lamp you can set the brightness internally to 33, 66, or 100 and that will update the slider in HA. You’ll need to use gamma_correct: 1
to get the percentages to work correctly.
This is fantastic, keep going!
With regards To your ceiling fan comment I have a pull chain ceiling fan with three speeds and I would love it if it could be controlled by the chain or by Home Assistant - both - seamlessly as can be done for example with a Shelley relay and a wall switch set as edge. (Foe example, if you use the chain to make it medium speed then HA knows that - and if you make it medium speed through HA then the chain switch “knows” that and another pull of the chain would make it go corectrly to the next speed expected…
I did enter a question about that on this forumn some time ago, but got a kooky answer that I should use three relays - one for each speed… LOL
Have you looked at the SONOFF iFan04-L. I’ve used them on ceiling fans. If you can fit it under the cover they work well. I used some heavy duty tie wraps to hold them in place. The chain doesn’t work but you can use the remote instead of the chain. The ones I have I flashed with TASMOTA.
Just did the clean up job on the lamp. Here’s the final product.
Going to write it up and then I’ll drop a link here to cross reference it.
I got it worked out and will post an update shortly. The updated is the second configuration in this post.
