I now use MQTT to post sensor updates for those that I can’t integrate with HA, but if you don’t want/can’t use MQTT you can simply post data straight into HA.
Check this post that I wrote a while back that should get you started
the main area for you to look at is
def HA_API_State(Device_Id, Value, Unit):
url = "http://192.168.0.24:8123/api/states/" + str(Device_Id) + "?api_password=SECRET"
data={"state":"" + str(Value) + "", "attributes": {"unit_of_measurement": "" + str(Unit) + ""}}
headers = {'Content-type':'application/json', 'Accept-Encoding': 'text/plain', 'Accept': 'text/plain'}
r = requests.post(url, data=json.dumps(data), headers=headers)
c = r.content
result = simplejson.loads(c)
Check REST API | Home Assistant Developer Docs for more info
