How to monitor Proxmox CPU temp
This was an awesome walk through!! One little amendment to this document to accommodate the newest version, the configuration.yaml should look like this:
command_line:
  - sensor:
      name: "Lenovo M720q CPU Temp"
      command: "ssh -i /config/id_rsa -o StrictHostKeyChecking=no username@proxmox_host_ip -t 'cat /sys/class/thermal/thermal_zone2/temp'"
      unit_of_measurement: "°C"
      scan_interval: 300
      value_template: "{{ (value | multiply(0.001)) | round(1) }}"
Hello so for me it says unknown i have a password for proxmox so where should i ad it maybe that is why it says unkown
Is there a way to check a specific VM/container for it’s stats?
potat0’s post shows how to get CPU, Ram and Disk from Proxmox, but this is the node’s stats rather than an individual VM
Thanks @Goofi , I’ve updated the post.
@callumw I know it’s not quite what you’re looking for but have a look at this grafana dashboard - Proxmox | Grafana Labs . Proxmox allows you to send metrics directly to InfluxDB using the built in metrics server functionality so you could use that and then view the stats in Grafana instead of home assistant.
Thanks for the suggestion.
I already have the SSH set up and am getting the CPU temps, so was hoping that the other data could be pulled out via a command to proxmox similar to the others.
The Grafana does look pretty cool, but it feels like an extra layer of complexity in order to have 2 wee dials show in our HA dashboard :slight_smile:
Here is my code
proxmox_command_sensors:
  command_line:
  - sensor:
      name: Proxmox CPU Temp
      command: "ssh -i /config/id_ed25519 -o StrictHostKeyChecking=no root@proxmox_host_ip -t 'sleep 2 && cat /sys/class/thermal/thermal_zone0/temp'"
      # If errors occur, make sure configuration file is encoded as UTF-8
      value_template: "{{ value | multiply(0.001) | round(0) }}"
      scan_interval: 120
  - sensor:
      name: Proxmox SSD sdb Temp
      command: ssh -i /config/id_ed25519 -o StrictHostKeyChecking=no root@proxmox_host_ip -t 'smartctl -a /dev/sdb | grep Temperature' | awk '{printf ("%.1f\n",$10)}'
      value_template: "{{ value | float/1  | round(1) }}"
      scan_interval: 120
  - sensor:
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t 'sleep 2 && top -d 0.5 -b -n2 | grep "Cpu(s)" | tail -n 1' | awk '{printf ("%.1f\n",$2 + $4)}'
      unit_of_measurement: '%'
      scan_interval: 120
  - sensor:
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t free -m | grep Mem | awk '{printf ("%.1f\n",$3*100/$2)}'
      scan_interval: 120
  - sensor:
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t free -m | grep Swap | awk '{printf ("%.1f\n",$3*100/$2)}'
      scan_interval: 120
  - sensor:
      name: Proxmox SSD Use
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t  df | grep pve-root | awk '{printf ("%.0f\n",$3*100/($3+$4))}'
      scan_interval: 120
  - sensor:
      name: Proxmox up Time
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t uptime -p
      scan_interval: 300
  - sensor:
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t uptime  | awk '{printf ("%.2f\n",$10)}'
      scan_interval: 120
  - sensor:
      name: Proxmox io delay
      command: ssh -o StrictHostKeyChecking=no -i /config/id_ed25519 root@proxmox_host_ip -t cat /proc/pressure/io | grep "some" | awk '{printf ("%s",$2)}'
      scan_interval: 120
      value_template: >-
        {{ value | replace("avg10=", "") |float }}
Maybe someone will improve or add.
Thanks, that worked perfectly on my Lenovo ThinkCentre M73 !
I am struggling with this (sorry).
I have managed to create the id_rsa file (and .pub) in the /config/.shh folder.
I receive ERROR: No identities found, which is backed up when I run ssh-copy-id root@proxmox-ip-address
This is backed up as it still prompts me to enter the password when I run the following :
ssh -i /config/.ssh/id_rsa root@proxmox-ip-address
Thank you
until yesterday this code gave me the correct temperature, after today’s update:
  • Core2025.3.2
  • Supervisor2025.03.2
    this doesn’t work anymore. Do you have any suggestions?
command_line:
  - sensor:
      name: 'Temperatura Cpu Proxmox'
      command: "ssh -i /config/id_rsa -o StrictHostKeyChecking=no [email protected] -t 'cat /sys/class/hwmon/hwmon2/temp1_input'"
      unit_of_measurement: '°C'
      scan_interval: 60
      value_template: '{{ (value | multiply(0.001)) | round(0) }}'
now i receive this error:
Warning: Permanently added ‘192.xxx.xxx.xxx’ (ED25519) to the list of known hosts.
cat: /sys/class/hwmon/hwmon2/temp1_input: No data available
Connection to 192.xxx.x.xxx closed.
search another number
for me, after some updates, thermal_zone3 moved to thermal_zone4
