Did you add your volume to /etc/fstab?
Here is my entry in fstab:
UUID=1f29691b-720e-4bac-8339-51723a93dbab /usr/share/hassio/media btrfs rw,exec,subvolid=2000 0 0
Thank you very much Dominik,
your solution works like a charm for me. Instead of a SMB-Share I use a external connected USB-Drive to my Pi 4, which I then mount via this created service into the homeassistant container.
As @onl1kairi mentioned, it helpted to change the “docker exec” parameter from “-it” to “-i” otherwise errors would occur during the service execution.
One interesting point tho:
I was afraid that the snapshot would backup the whole content of my “mounted” media folder and hence be very big. After starting a backup and then looking into it, everything was fine. The mounted device and its content did not get backed up, which is perfect for me
Best Regards & have a nice day,
forSince
I “fixed” this issue by adding the following two Crontabs for the root user (crontab -e
@reboot rm -r /usr/share/hassio/media
@reboot sleep 10 && rm -r /usr/share/hassio/media && ln -s /path/to/your/media /usr/share/hassio/media && docker restart homeassistant
(I’m running a supervised installation on Ubuntu 20.04, not sure if the @reboot
command also works like this in Crontabs on Debian)
I have HomeAssistant supervised install on RaspberryPy.
I execute
sudo docker exec -it homeassistant bash
and
mount -t cifs -o "domain=WORKGROUP,username=xxx,password=xxx" //192.168.1.xx/camera /media/camera
When I execute in docker
ls-l camera
I see files from NAS
When I execute same command inside HomeAssistant TerminalSSH addon i see only empty catalog
When I create file into docker, I see this one on NAS, but I can not see this file inside HomeAssistant.
And when I create file inside HA I can not see this file inside docker or inside NAS.
Where is my wrong?
Hi everybody,
trying to mount the folder, but I’m kinda lost. I’m not familiar with docker but the minimum.
I’ve mounted an SSD on the host (debian) on /media/plex and I’d like to see it by HA and Plex. I tryied to modify the /usr/sbin/hassio-supervisor adding a volume using -v, but it doesnt work, probably because it use “create” and not “run”? (just a speculation on my part).
Need some help, do a symbolic link to /usr/share/hassio/media/plex would work?
