OK cool that worked. Thank you so much this is great!! Not sure if I mentioned it or it has values to others but using a tool I used to use with Nagios called NSClient++ to pull monitoring stats off my computers and update them in HA. NSClient++ is a cross platform tool for retrieving stats from your computer and is scriptable.
I want to now use those values to alert and can do that, however now that I have:
How would I be able to create a card or something that shows how full the drive is and if it’s Good, Warning, or Critical? I can also use the other half of the results that are in percents.
Like in the Glance card, it looks like to set warning and critical thresholds and maximums you need to enter a physical number. Maybe different way to approach that?
Thanks.
JR
