Pretty well.
/r and /n are shorthand for carriage return and line feed (newline).
At least one of them is probably in your data stream terminating a line of data.
Pretty well.
I’ve tried both using the example from the docs (removed the case/break).
Would the UARTDebug string show it? As I see nothing for each line, just random ones.
The sensor datasheet shows response examples with delcared length return values. Would that negate a carriage return?
Post your whole YAML, not just the extracts. Don’t forget to remove any ids like wifi details.
Maybe forget about doing this on on ESPHome and go for a Pi Zero? The manufacture has already supplied Python scripts that do what you want. You just need to add some MQTT script to get the data to wherever you want it.
My bad, I’ll post the full yaml tomorrow.
As for the python scripts, I did see that. My intentions were to leverage my last experience with ESPHome directly controlling WLED without HA for faster response times. While permitting the option to include HA and features such as OTA. The last being of particular value. If a full Pi is the answer then I would reluctantly go there. Albeit I’d likely try MicroPython first. The size of the sensor/MCU packaging is a consideration here.
As promised, yaml below. More sample data and observations.
Observations:
newline
or carriage return
in the datastream. This makes the sample .h provided in the Custom UART Text Sensor not a copy/paste affair.ESPHome yaml below (have skipped all the normal api/wifi things…)
esphome:
platform: ESP32
board: esp32dev
includes:
- kld7_uart_sensor.h
on_boot:
priority: -100
then:
- uart.write: [0x49,0x4E,0x49,0x54,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00] # perform kld7 INIT
# Enable logging
logger:
uart:
tx_pin: GPIO19
rx_pin: GPIO18
baud_rate: 115200
parity: even
debug:
direction: BOTH
# direction: RX
dummy_receiver: false
after:
delimiter: "RESP\x01\x00\x00\x00\x00"
bytes: 25
timeout: 80ms
# - lambda: UARTDebug::log_hex(direction, bytes, ':');
- lambda: UARTDebug::log_string(direction, bytes);
# - lambda: UARTDebug::log_int(direction, bytes, ',');
# - lambda: UARTDebug::log_binary(direction, bytes, ';');
binary_sensor:
- platform: gpio
pin:
number: GPIO23
mode: INPUT_PULLDOWN
on_state:
then:
while:
- binary_sensor.is_on: kld7_detection
then:
- uart.write: [0x47,0x4E,0x46,0x44,0x04,0x00,0x00,0x00,0x08,0x00,0x00,0x00] # Get TDAT
- delay: 100ms
text_sensor:
- platform: custom
lambda: |-
auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
App.register_component(my_custom_sensor);
return {my_custom_sensor};
text_sensors:
Here is sample data returned from the radar
[12:50:24][D][uart_debug:158]: >>> "GNFD\x04\x00\x00\x00\b\x00\x00\x00"
[12:50:24][D][uart_debug:158]: <<< "RESP\x01\x00\x00\x00\x00"
[12:50:24][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00u\x00\xDC\xFF\t\xFB\x16"
[12:50:24][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00s\x00\xD1\xFF\xB1\xF9\x1F\x16"
[12:50:24][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00q\x00\xCE\xFF\xC0\xF8\x91\x15"
[12:50:24][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00p\x00\xEA\xFFY\xF84\x16"
[12:50:25][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00r\x00\x12\x00\xC2\xF6%\x15"
[12:50:25][D][uart_debug:158]: >>> "GNFD\x04\x00\x00\x00\b\x00\x00\x00"
[12:50:25][D][uart_debug:158]: <<< "RESP\x01\x00\x00\x00\x00"
[12:50:25][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00q\x00\x06\x00\x1E\xF7\xC1\x13"
[12:50:25][D][uart_debug:158]: <<< "TDAT\b\x00\x00\x00n\x00\xD5\xFF\x14\xF8\x94\x14"
What I think I have to do it is try and incorporate the following steps in cpp functions
as a StartMarkerI’m probably late to the thread, but in home assistant you can use a template to get the data you want. So if you can just get the hex codes as a binary string as the state you can use a template sensor to filter the data.
I think there is still the problem of having no newline/carriage_return. Since the assumption here is that the text_sensor publishes a value to HA and it only does so when it see’s a regular \n or \r which don’t exist in the data
Which brings up the second conflict, which I haven’t mentioned to date. I don’t actually want HA to be required. Yes obviously I am using ESPHome now, to develop, since I don’t write cpp. But I want to be able to move “off network” and have the radar be standalone until brought back. It will feed WLED via HTTP calls (maybe via UDP calls in the future).
The ultimate goal where is [standalone ESPHome radar data] → [WLED] where HA is only needed to OTA.
I think at this point I have come to realize that my question isn’t actually about ESPHome and I need to move to the Arduino forum.
Quick one as I’m AFK for a few days, but if you look at your debug definition, you have a delimiter string that is a substitute for /r /n. Plug that into the example and go from there.
Yes I’ve tried that with no success. I suspect that the ESPHome interface between the yaml and Arduino layers performs some level of interpretation as that syntax doesn’t work in the cpp .h file.
Looking at the python example mentioned earlier, struct
is doing all the work to translate into a bytearray (eg. No “RESP” chars).
Having successfully used the python library I may cave and go RPi Zero W just to get things working.
I think I have perhaps distilled the problem definition into, “how do you rewrite struct in C++?”
Have you looked at the python implementation here? A driver for the K-LD7 radar module — kld7 0.1.1 documentation
The API is also documented here A driver for the K-LD7 radar module — kld7 0.1.1 documentation
Perhaps micropython or circuitpython would be a good way to get this onto a microcontroller?
Sorry, that’s the one using struct I was looking at.
It’s funny because I first got started in MCU’s last year by using MicroPython. It was never the most reliable for me and then I found HA + ESPHome which has been great.
I think I’ll take baby steps. Get full OS + Python a go with that module. Then see if that repo can be massaged to work in MicroPython.
I just started to use circuitpython for a little project, and it has been excellent, but as I say it was a very little project.
CircuitPython is great too.
My challenge was dropping off wifi after a day or two. Which may have changed in the past year. I guess I’ll find out!
Massaged the python library into CircuitPython on an ESP32-S2 sending data to WLED via UDP Sync. Maybe one day I’ll know enough C++ to get it working in ESPHome.
Pretty basic POC using radar distance tracking: Radar tracking - Album on Imgur
Dunno if it would help but have you tinkered with some of the other debug options?
Stuff like this…
uart:
- id: uart_bus2
tx_pin: GPIO17
rx_pin: GPIO16
debug:
direction: BOTH
dummy_receiver: true
after:
bytes: 4
Thanks for the suggestion. The sensor in question does not use line/carriage returns of any sort. After further testing I can confirm that fixed size byte arrays are indeed what are used. Got it working with MicroPython and have yet to loop back to decipher the hex data in cpp. Thx!
I’m having kind of a similar issue, as discussed in https://community.home-assistant.io/t/intercept-echo-filter-modbus-communications-from-1-uart-hub-to-another-vs-pool-pump-solar-speed-override-project/340383. Hope I’m not hijacking.
At this point I’m trying to understand how to actually consume the data that is coming in over UART/Modbus. It’s being written into the log just fine but exactly how do I get to it in a usable form? Been reading up on C++ a bit to try to understand stuff on the documentation pages but I think I need a little more advice. Thanks!
I’d presume that the external component publishes something to be used. Haven’t checked the git repo. Are there examples?
I’ll try and take a look when I can, perhaps it could help me as well. I’ve been playing with Arduino Serial examples. Suspect theses are two different issues as I am guessing the component you have found does the parsing.
I’ve gotten to the point where I can send hex data from my PC to the ESPHome node via RS485 and have that data logged by ESPHome as raw hex as well as ASCII characters. I can also send either predefined raw hex bytes via UART/RS485 or predefined hex commands (with automatically generated CRC bytes) via Modbus/RS485. So I just need to be able to read and filter incoming hex so I can pass it out again over the second physical UART/RS485 interface, substituting my custom commands for the filtered-out commands.
