How to reduce your database size and extend the life of your SD card
You could use SQL to get the database size. It wouldn’t be exactly the same as disk allocation, but it should be close.
SELECT
    table_name AS `Table Name`,
	table_rows AS `Row Count`,
	ROUND(SUM(data_length)/(1024*1024*1024), 3) AS `Table Size [GB]`,
	ROUND(SUM(index_length)/(1024*1024*1024), 3) AS `Index Size [GB]`,
	ROUND(SUM(data_length+index_length)/(1024*1024*1024), 3) `Total Size [GB]`
FROM information_schema.TABLES
WHERE table_schema = 'homeassistant'
GROUP BY table_name
ORDER BY table_name
Above is for an installation on MariaDB. Adjust the database name (table_schema) as needed, or remove the WHERE clause entirely if all you have on that service is your Home Assistant schema.
You’d get something like the following (here produced using phpMyAdmin):
ha
