I did not manage to set the microphone and turn on the satellite. I will try again later.
@randomuser123 maybe you have time to look too.
I found that the wyoming sattelite GUI installer uses alsa-utils for the microphone, which, from what I found, does not work on the Lenovo TSV tablet.
The GUI most likely calls the scripts in the scripts directory. I think we should first ensure that they all work without the GUI and then check how the GUI is calling the scripts because the GUI is another point of failure and hides important information that could be crucial in finding the source of a problem.
Got another response from the Termux devs. They have provided test builds that do not require memfd
: pulseaudio: disable memfd · termux/termux-packages@0ae3a72 · GitHub
Unfortunately, now I’m getting this error on my old devices with kernel 3.10:
$ pactl load-module module-sles-source
Failure: Module initialization failed
On my newer devices with kernel 4.4 I only get this error when I don’t grant the microphone recording permission to Termux:API.
