andytrx
(Andy Hamdorf)
July 25, 2021, 5:05am
21
FIXED
Sorry
My error with the binary_sensor.level’s that I did not share with you in the start.
I was blinded to this silly error.
Thank you for you patients.
sensors:
water_tank_level_store_2:
friendly_name: 'Water Tank Level Store 2'
unit_of_measurement: '%'
value_template: >
{% set level = states('sensor.water_tank_level') | int %}
{% if is_state('switch.water_relay', 'on') %}
{% if is_state('binary_sensor.level_5', 'off') %}
100
{% elif is_state('binary_sensor.level_4', 'off') %}
75
{% elif is_state('binary_sensor.level_3', 'off') %}
50
{% elif is_state('binary_sensor.level_2', 'off') %}
25
{% else %}
0
{% endif %}
{% else %}
{{ states('sensor.water_tank_level_store_2') }}
{% endif %}
tom_l
July 25, 2021, 5:06am
22
I can’t tell what the error was as you have not formatted your post correctly.
andytrx
(Andy Hamdorf)
July 25, 2021, 5:07am
23
how do you format the code ?
tom_l
July 25, 2021, 5:08am
24
Three backticks ``` above and below your pasted code (on their own line).
Or highlight the whole config section and press the <\>
button at the top of your post edit window.
tom_l
July 25, 2021, 5:11am
25
You got it. And I see your mistake now.
Ok, so there is an issue with the new template format. I’ll have a look and see if anything like this has been reported.
andytrx
(Andy Hamdorf)
July 25, 2021, 5:13am
26
From the ESP Home I get the data like this
# Level 1 = Less Than 1/4 Tank
# Level 2 = 1/4 Full
# Level 3 = 1/2 Full
# Level 4 = 3/4 Full
# Level 5 = Full
#sensor:
# - platform: template
# name: "water_tank_level_store"
# id: water_tank_level_store
binary_sensor:
- platform: gpio
pin: D2
device_class: opening
- platform: gpio
pin: D7
- platform: gpio
pin: D5
- platform: gpio
pin: D6
switch:
- platform: gpio
pin:
number: D1
inverted: False
#mode: INPUT_PULLUP
Then in the Sensor.yaml file I have this
sensors:
value_template: >
100
75
50
25
{% else %}
0
{% endif %}
{% else %}
{% endif %}
tom_l
July 25, 2021, 5:22am
27
You know you could do all this in ESPHome?
andytrx
(Andy Hamdorf)
July 25, 2021, 5:36am
28
Yes, I do now.
I have being doing some other things in ESPhome since I created this.
I have discovered I can do a lot in ESPHome.
Thanks for the pointer. I appreciate it.
Sometimes it take a nudge from someone with more experience for us to look more deeply into other devices.
I may push all of this processing into ESPHome
Your gem for me was the last line
{% else %}
{% endif %}
I never thought to add this. Thanks
