How to select other sources in the Soundtouch configuration?
I think the next thing to try would be to “Enable debug logging” under the soundtouchplus integration settings (http://homeassistantvm:8123/config/integrations/integration/soundtouchplus). Click the “Enable debug logging” to start logging. While it is logging, select the Spotify source to play a few seconds of a song, then switch the source back to TV to play a few seconds of audio from the TV. It’s critical for the logging output to change the source completely, so that it logs the differences. After that, you can click on the “Enable debug logging” to stop logging. When you do this, Home Assistant should prompt you to save the logging output file.
Save the file to your local computer and open it up to take a look at the contents. I need to see what all of the NowPlayingStatus: source= lines say, specifically the ones for the actual source change.
For example, here is some debug log entries from my ST-300:
2023-10-30 13:08:34.827 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] SoundTouchClient configuration object: 'NowPlayingStatus: source="PRODUCT" playStatus="PLAY_STATE" ContentItem: source="PRODUCT" sourceAccount="TV" isPresetable="false" favoriteEnabled="false"'
2023-10-30 13:08:35.077 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] SoundTouchClient configuration object: 'NowPlayingStatus: source="PRODUCT" playStatus="PLAY_STATE" ContentItem: source="PRODUCT" sourceAccount="TV" isPresetable="false" favoriteEnabled="false"'
2023-10-30 13:08:55.776 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] SoundTouchClient configuration object: 'NowPlayingStatus: source="STANDBY" ContentItem: source="STANDBY" isPresetable="false" favoriteEnabled="false"'
2023-10-30 13:08:55.898 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] SoundTouchClient configuration object: 'NowPlayingStatus: source="STANDBY" ContentItem: source="STANDBY" isPresetable="false" favoriteEnabled="false"'
What I am looking for is how the source= and sourceAccount= values change.
I tried a few times, once I even logged for a few minutes but seems like there is no change
2023-10-31 10:35:49.409 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:35:49.409 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:49.409 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:49.409 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:52.517 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:35:52.517 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:52.517 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:52.517 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.568 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:35:54.568 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.568 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.568 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.740 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:35:54.740 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.740 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:35:54.740 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.615 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:36:19.615 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.615 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.615 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.673 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:36:19.673 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.673 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.673 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.698 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:36:19.698 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.698 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:36:19.698 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.171 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:02.171 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.171 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.171 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.655 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:02.655 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.655 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.655 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.969 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:02.969 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.969 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:02.969 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.223 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:03.223 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.223 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.223 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.491 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:03.491 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.491 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.491 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.731 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:03.731 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.731 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.731 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.782 DEBUG (SoundTouchWSNotifyThread) [custom_components.soundtouchplus.media_player] 'Trash': update method
2023-10-31 10:37:03.782 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting NowPlayingStatus configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.782 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Volume configuration for SoundTouch device: 'Trash'
2023-10-31 10:37:03.782 DEBUG (SoundTouchWSNotifyThread) [bosesoundtouchapi.soundtouchclient] Getting Zone configuration for SoundTouch device: 'Trash'
That’s really odd - it almost seems like the ST-520 does not support websocket notifications, as all I am seeing in the file is the ‘update’ polling output.
Can you issue the following command from a web browser to check the device capabilities:
http://x.x.x.x:8090/capabilities
From that output, do you see a wsapiproxy= value? something like this:
<wsapiproxy>true</wsapiproxy>
When looking at your media player in Home Assistant UI that is associated with the SoundTouchPlus device, do you see the volume slider move when you turn the volume up or down using the ST-520 remote?
The answer is yes to both.
I do see wsaproxy being true and the slider adjusts as I change the volume with the remote
Ok, so that tells me that you are receiving updates from the ST-520 to the integration (e.g. HA media player volume sliders move when you press volume up on the remote, wsapiproxy=true, etc). If that is the case, then you should be receiving NowPlaying updates as well.
Prior to doing any further debugging, go ahead and update to the latest version of the SoundTouchPlus component (v1.0.4). To do this, click on “Settings” menu. You should see an entry at the top that says an update is available for SoundTouchPlus integration. If not, try uninstalling the SoundTouchPlus, then reinstall it from HACS. You will need to restart HA after the SoundTouchPlus update as well.
To confirm, do you have the SoundTouchPlus player mapped to a mini-media player on a UI dashboard? If not, you might want to define a temp dashboard that uses the media-player. Here’s some YAML for that if you need it:
type: entities
entities:
  - type: custom:mini-media-player
    group: true
    entity: media_player.trash_2
    toggle_power: false
    artwork: full-cover
    artwork_border: true
    power_color: true
    show_source: true
    expanded: true
    speaker_group:
      platform: media_player
      sync_volume: true
      show_group_count: true
      icon: mdi:link
      entities:
        - entity_id: media_player.bose_soundtouch_300
          name: Link HearthRoom ST 300
state_color: true
Once that is done, do the following:
  1. enable logging for the SoundTouchPlus component.
  2. restart Home Assistant and wait for it to fully start up.
  3. switch the source on the ST-520 to play any other source besides your TV, and let it play for a couple of minutes.
  4. press the volume up and down buttons on the ST-520 remote, and see if the volume slider moves on the HA UI dashboard media player that references the SoundTouchPlus integration.
  5. switch the source on the ST-520 to your TV and let it play for a couple of minutes.
  6. switch the source on the ST-520 to play any other source besides your TV, and let it play for a couple of minutes.
  7. disable logging for the SoundTouchPlus component, and download the log file to your computer.
If you don’t mind, PM me the log file so I can take a look at it.
If you don’t want to do that I understand as it may contain personal info; in that case, view the log file and search for all lines that contain “ContentItem:”. Those entries have to be showing up in the log somewhere that show the source and sourceAccount values that are changing.
If this doesn’t work, then the next ask would be for a SmartInspect debug log file. This would involve adding a “smartinspect.cfg” file to your config folder and performing the above steps again. It generates more detailed information than the HA logger. But let’s try the above first.
Thanks for your patience; debugging remotely is tough, but hopefully we can get it figured out.
Hi @ jakubsz123 - just checking in to see where we are at on the ST-520 source switching issue. Please let me know when you get a chance.
Thanks.
thlucas,
How do I install the Media Library Browser for Home Assistant. I installed your SoundTouch Plus and I like it.
Frank
