Hi, Sorry for the late response, not been around for a while. Sure,
Decoder
* SenseCAP & TTN (new v3) Converter
* @since 3.0
* @return Object
* @param Boolean valid Indicates whether the payload is a valid payload.
* @param String err The reason for the payload to be invalid. 0 means valid, minus means invalid.
* @param String payload Hexadecimal string, to show the payload.
* @param Array messages One or more messages are parsed according to payload.
* type // Enum:
* // - "report_telemetry"
* // - "upload_battery"
* // - "upload_interval"
* // - "upload_version"
* // - "upload_sensor_id"
* // - "report_remove_sensor"
* // - "unknown_message"
* @sample-1
* var sample = Decoder(["00", "00", "00", "01", "01", "00", "01", "00", "07", "00", "64", "00", "3C", "00", "01", "20", "01", "00", "00", "00", "00", "28", "90"], null);
* valid: true,
* err: 0,
* payload: '0000000101000100070064003C00012001000000002890',
* messages: [
* { type: 'upload_version',
* hardwareVersion: '1.0',
* softwareVersion: '1.1' },
* { type: 'upload_battery', battery: 100 },
* { type: 'upload_interval', interval: 3600 },
* { type: 'report_remove_sensor', channel: 1 }
* @sample-2
* var sample = Decoder(["01", "01", "10", "98", "53", "00", "00", "01", "02", "10", "A8", "7A", "00", "00", "AF", "51"], null);
* valid: true,
* err: 0,
* payload: '01011098530000010210A87A0000AF51',
* messages: [
* { type: 'report_telemetry',
* measurementId: 4097,
* measurementValue: 21.4 },
* measurementId: 4098,
* measurementValue: 31.4 }
* @sample-3
* var sample = Decoder(["01", "01", "00", "01", "01", "00", "01", "01", "02", "00", "6A", "01", "00", "15", "01", "03", "00", "30", "F1", "F7", "2C", "01", "04", "00", "09", "0C", "13", "14", "01", "05", "00", "7F", "4D", "00", "00", "01", "06", "00", "00", "00", "00", "00", "4C", "BE"], null);
* valid: true,
* err: 0,
* payload: '010100010100010102006A01001501030030F1F72C010400090C13140105007F4D0000010600000000004CBE',
* messages: [
* { type: 'upload_sensor_id', sensorId: '30F1F72C6A010015', channel: 1 }
* Entry, decoder.js
function decodeUplink (input) {
var bytes = input['bytes'];
// // init
var bytesString = bytes2HexString(bytes)
.toLocaleUpperCase();
// var bytesString = input
var decoded = {
// valid
valid: true, err: 0, // bytes
payload: bytesString, // messages array
messages: []
// CRC check
if (!crc16Check(bytesString)) {
decoded['valid'] = false
decoded['err'] = -1 // "crc check fail."
return { data: decoded }
// Length Check
if ((((bytesString.length / 2) - 2) % 7) !== 0) {
decoded['err'] = -2 // "length check fail."
// Cache sensor id
var sensorEuiLowBytes
var sensorEuiHighBytes
// Handle each frame
var frameArray = divideBy7Bytes(bytesString)
for (var forFrame = 0; forFrame < frameArray.length; forFrame++) {
var frame = frameArray[forFrame]
// Extract key parameters
var channel = strTo10SysNub(frame.substring(0, 2))
var dataID = strTo10SysNub(frame.substring(2, 6))
var dataValue = frame.substring(6, 14)
var realDataValue = isSpecialDataId(dataID) ? ttnDataSpecialFormat(dataID, dataValue) : ttnDataFormat(dataValue)
if (checkDataIdIsMeasureUpload(dataID)) {
// if telemetry.
decoded.messages.push({
type: 'report_telemetry', measurementId: dataID, measurementValue: realDataValue
} else if (isSpecialDataId(dataID) || (dataID === 5) || (dataID === 6)) {
// if special order, except "report_sensor_id".
switch (dataID) {
case 0x00:
// node version
var versionData = sensorAttrForVersion(realDataValue)
type: 'upload_version', hardwareVersion: versionData.ver_hardware, softwareVersion: versionData.ver_software
break
case 1:
// sensor version
break
case 2:
// sensor eui, low bytes
sensorEuiLowBytes = realDataValue
break
case 3:
// sensor eui, high bytes
sensorEuiHighBytes = realDataValue
break
case 7:
// battery power && interval
type: 'upload_battery', battery: realDataValue.power
type: 'upload_interval', interval: parseInt(realDataValue.interval) * 60
break
case 9:
type: 'model_info',
detectionType: realDataValue.detectionType,
modelId: realDataValue.modelId,
modelVer: realDataValue.modelVer
break
case 0x120:
// remove sensor
break
default:
break
} else {
type: 'unknown_message', dataID: dataID, dataValue: dataValue
// if the complete id received, as "upload_sensor_id"
if (sensorEuiHighBytes && sensorEuiLowBytes) {
decoded.messages.unshift({
type: 'upload_sensor_id', channel: 1, sensorId: (sensorEuiHighBytes + sensorEuiLowBytes).toUpperCase()
// return
function crc16Check (data) {
return true
// util
function bytes2HexString (arrBytes) {
var str = ''
for (var i = 0; i < arrBytes.length; i++) {
var tmp
var num = arrBytes[i]
if (num < 0) {
tmp = (255 + num + 1).toString(16)
} else {
tmp = num.toString(16)
if (tmp.length === 1) {
tmp = '0' + tmp
str += tmp
return str
// util
function divideBy7Bytes (str) {
var frameArray = []
for (var i = 0; i < str.length - 4; i += 14) {
var data = str.substring(i, i + 14)
frameArray.push(data)
return frameArray
// util
function littleEndianTransform (data) {
var dataArray = []
for (var i = 0; i < data.length; i += 2) {
dataArray.push(data.substring(i, i + 2))
dataArray.reverse()
return dataArray
// util
function strTo10SysNub (str) {
var arr = littleEndianTransform(str)
return parseInt(arr.toString()
.replace(/,/g, ''), 16)
// util
function checkDataIdIsMeasureUpload (dataId) {
return parseInt(dataId) > 4096
// configurable.
function isSpecialDataId (dataID) {
switch (dataID) {
case 0:
case 1:
case 2:
case 3:
case 4:
case 7:
case 9:
case 0x120:
return true
default:
return false
// configurable
function ttnDataSpecialFormat (dataId, str) {
var strReverse = littleEndianTransform(str)
if (dataId === 2 || dataId === 3) {
return strReverse.join('')
// handle unsigned number
var str2 = toBinary(strReverse)
var dataArray = []
switch (dataId) {
case 0: // DATA_BOARD_VERSION
case 1: // DATA_SENSOR_VERSION
// Using point segmentation
for (var k = 0; k < str2.length; k += 16) {
var tmp146 = str2.substring(k, k + 16)
tmp146 = (parseInt(tmp146.substring(0, 8), 2) || 0) + '.' + (parseInt(tmp146.substring(8, 16), 2) || 0)
dataArray.push(tmp146)
return dataArray.join(',')
case 4:
for (var i = 0; i < str2.length; i += 8) {
var item = parseInt(str2.substring(i, i + 8), 2)
if (item < 10) {
item = '0' + item.toString()
} else {
item = item.toString()
dataArray.push(item)
return dataArray.join('')
case 7:
// battery && interval
return {
interval: parseInt(str2.substr(0, 16), 2), power: parseInt(str2.substr(-16, 16), 2)
case 9:
let dataValue = {
detectionType: parseInt(str2.substring(0, 8), 2),
modelId: parseInt(str2.substring(8, 16), 2),
modelVer: parseInt(str2.substring(16, 24), 2)
// 01010000
return dataValue
// util
function ttnDataFormat (str) {
if (str2.substring(0, 1) === '1') {
var arr = str2.split('')
var reverseArr = []
for (var forArr = 0; forArr < arr.length; forArr++) {
var item = arr[forArr]
if (parseInt(item) === 1) {
reverseArr.push(0)
} else {
reverseArr.push(1)
str2 = parseInt(reverseArr.join(''), 2) + 1
return parseFloat('-' + str2 / 1000)
return parseInt(str2, 2) / 1000
// util
function sensorAttrForVersion (dataValue) {
var dataValueSplitArray = dataValue.split(',')
return {
ver_hardware: dataValueSplitArray[0], ver_software: dataValueSplitArray[1]
// util
function toBinary (arr) {
var binaryData = []
var data = parseInt(item, 16)
.toString(2)
var dataLength = data.length
if (data.length !== 8) {
for (var i = 0; i < 8 - dataLength; i++) {
data = '0' + data
binaryData.push(data)
return binaryData.toString()
.replace(/,/g, '')
// Samples
// var sample = Decoder(["00", "00", "00", "01", "01", "00", "01", "00", "07", "00", "64", "00", "3C", "00", "01", "20", "01", "00", "00", "00", "00", "28", "90"], null);
// var sample = Decoder(["01", "01", "10", "98", "53", "00", "00", "01", "02", "10", "A8", "7A", "00", "00", "AF", "51"], null);
// var sample = Decoder(["01", "01", "00", "01", "01", "00", "01", "01", "02", "00", "6A", "01", "00", "15", "01", "03", "00", "30", "F1", "F7", "2C", "01", "04", "00", "09", "0C", "13", "14", "01", "05", "00", "7F", "4D", "00", "00", "01", "06", "00", "00", "00", "00", "00", "4C", "BE"], null);
// console.log(sample);
and the config
- name: "S2104_Battery"
state_topic: "application/1/device/2cf7f1c053000714/event/up"
#value_template: "{{value_json.objectJSON.messages.battery }}"
json_attributes_topic: "application/1/device/2cf7f1c053000714/event/up"
json_attributes_template: "{{ (value_json.objectJSON | from_json).messages[0].battery }}"
- name: "S2104_Soil_Temp_4102"
json_attributes_template: "{{ ((value_json.objectJSON | from_json).messages | selectattr('measurementId','eq',4102) | list | first).measurementValue }}"
- name: "S2104_Soil_Moisture_4103"
json_attributes_template: "{{ ((value_json.objectJSON | from_json).messages | selectattr('measurementId','eq',4103) | list | first).measurementValue }}"
This is what it gives me
Hope that helps
