Spot the difference:
Thank you!!! That fixed it!
- binary_sensor:
- name: "Close to Home"
state: '{{ states("proximity.home")|int < states("input_number.close_to_home_trigger")|int }}'
- name: "Night Mode"
unique_id: night_mode
availability: '{{ not is_state("sensor.south_patio_illuminance_lux", "unavailable") }}'
state: '{{ states("sensor.south_patio_illuminance_lux")|float(default=0) < states("input_number.outside_lux_trigger_point")|float(default=0) }}'
delay_on: 00:02:00
delay_off: 00:01:00
- select:
- name: "Select Destination"
unique_id: select_destination
state: "{{ states('input_select.destination') }}"
options: "{{ state_attr('input_select.destination','options') }}"
select_option:
service: input_select.select_option
entity_id: input_select.destination
option: "{{ option }}"
- sensor:
- name: "Direction of Travel"
state: '{{ state_attr("proximity.home", "dir_of_travel") }}'
- name: "Monthly Energy Cost: Car Charger"
state: '{{ states("sensor.car_charging_step_1")|float(default=0) * states("input_number.bchydro_step_1_rate")|float(default=0) + states("sensor.car_charging_step_2")|float(default=0) * states("input_number.bchydro_step_2_rate")|float(default=0) }}'
device_class: monetary
unit_of_measurement: CAD
- trigger:
value_template: "{{ (now() + timedelta(days=1)).day == 1 and now().hour == 23 and now().minute == 59 }}"
- name: "Last Month Car Charging Total Energy Cost"
state: "{{ states('sensor.node_50_electric_consumed_kwh') }}"
- trigger:
- platform: time_pattern
seconds: "/5"
- name: "HASS Agent My PC Idle Time"
state: '{{ as_timestamp(utcnow()) - as_timestamp(states("sensor.lastactive")) }}'
unit_of_measurement: "Seconds"
This new sensor is working but since it’s value does not survive an HA restart, I am using MQTT to save it which is triggered by an automation…
- trigger:
- name: "Car Charging Monthly Energy Cost"
state: '{{ states("sensor.monthly_energy_cost_car_charger") }}'
alias: Car Charging Monthly Energy Cost
description: ''
- platform: state
entity_id:
- sensor.car_charging_monthly_energy_cost
condition: []
- service: mqtt.publish
topic: energy/sensor/car_charger_energy
payload_template: '{{ states("sensor.monthly_energy_cost_car_charger") }}'
mode: single
and use this sensor to display it…
- platform: mqtt
name: "Total Car Charger Energy"
state_topic: "energy/sensor/car_charger_energy"
Phase 2:
I want to save the monthly energy values as attributes like…
jan:
feb:
mar:
apr:
may:
jun:
jul:
aug:
sep:
oct:
nov:
dec:
I think I can use the same automation to publish it for the current month but the templating for the MQTT json attributes has me baffled as I have done very little with MQTT in general, and nothing at all in this manner…
First crack at a template:
'{\"{{ now().timestamp() | timestamp_custom('%B') }}\":\"211.5\"}'
But the publish is not right…
