As previous responses have noted, you are running into a scoping issue.
In automations, YAML variables can be defined multiple places, their scope depends on where they are defined.
trigger_variables:
var_1: true #script-wide (only Limited Templates and static values allowed)
value_template: "{{ states('binary_sensor.x') | bool == var_1 }}"
variables:
var_2: "{{ false }}" #script-wide but, if you have multiple triggers, this value applies only when this specific trigger initiates the automation
variables:
var_3: "{{ true }}" #script-wide
- variables:
var_4: "{{ true }}" #local to condition block
- variables:
var_5: "{{ true }}" #local to action block
- choose:
- conditions:
- condition: template
value_template: "{{ var_2 }}"
- variables:
var_6: "{{ false }}" #local to this Option of this Choose action
* Variables will be populated with values roughly in the order I have numbered above.
One workaround for variables inside repeat actions is to set the value to an appropriate Helper or Trigger-based template sensor through an action.
Example using OP's sample automation
alias: Benachrichtigung - Fenster geöffnet
description: ""
triggers:
- type: opened
device_id: xxx
entity_id: xxx
domain: binary_sensor
trigger: device
conditions: []
actions:
- action: input_boolean.turn_off
entity_id: input_boolean.fenster_notification_running
- repeat:
- variables:
test1: "{{ states('input_boolean.fenster_notification_running')|bool }}"
- if:
- condition: or
conditions:
- condition: numeric_state
entity_id: weather.home
attribute: temperature
enabled: false
above: input_number.contact_sensor_notification_disable_temperature
- condition: state
entity_id: input_boolean.contact_sensor_notification_disable_by_user
state: "on"
enabled: true
then: [] #You can't leave this blank and expect the automation to work reliably
else:
- device_id: xxx
domain: mobile_app
type: notify
title: "Fenster "
message: Wurde geöffnet
enabled: false
- action: notify.alexa_media_alexa_arbeitszimmer
data: {}
message: >-
Wert 1 {# The variable that follows is undefined #}{{contact_sensor_notification_disable_temperature_hint}},
Wert 2 {{ test1 }}
- action: input_boolean.turn_on
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
while:
- type: is_open
condition: device
device_id: xxx
entity_id: xxx
enabled: true
