I got it working (but only 1 time) …
I could access the config page from my LAN, but after rebooting the Pi it seems to be stuck in a “restart job” loop
2022-03-16T11:47:02+01:00 systemd[1]: snap.zwavejs2mqtt.zwavejs2mqtt.service: Main process exited, code=exited, status=1/FAILURE
2022-03-16T11:47:02+01:00 systemd[1]: snap.zwavejs2mqtt.zwavejs2mqtt.service: Failed with result 'exit-code'.
2022-03-16T11:47:02+01:00 systemd[1]: snap.zwavejs2mqtt.zwavejs2mqtt.service: Consumed 12.708s CPU time.
2022-03-16T11:47:02+01:00 systemd[1]: snap.zwavejs2mqtt.zwavejs2mqtt.service: Scheduled restart job, restart counter is at 3.
2022-03-16T11:47:02+01:00 systemd[1]: Stopped Service for snap application zwavejs2mqtt.zwavejs2mqtt.
2022-03-16T11:47:02+01:00 systemd[1]: Started Service for snap application zwavejs2mqtt.zwavejs2mqtt.
2022-03-16T11:47:02+01:00 zwavejs2mqtt.zwavejs2mqtt[2402]: Missing plug: «serial-port»
2022-03-16T11:47:02+01:00 zwavejs2mqtt.zwavejs2mqtt[2363]: OPTIONAL plug
2022-03-16T11:47:02+01:00 zwavejs2mqtt.zwavejs2mqtt[2363]: Connect with: $ sudo snap connect zwavejs2mqtt:serial-port
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: 2022-03-16 11:47:12.854 INFO APP: Version: 6.4.1.db1571e
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: 2022-03-16 11:47:12.864 INFO APP: Application path:/snap/zwavejs2mqtt/330/lib/node_modules/zwavejs2mqtt/server
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: ______ _ ___ _ _
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: |___ / (_) |__ \ | | | |
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: / /_ ____ ___ _____ _ ___ ) |_ __ ___ __ _| |_| |_
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: / /\ \ /\ / / _` \ \ / / _ \ / __| / /| '_ ` _ \ / _` | __| __|
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: / /__\ V V / (_| |\ V / __/ \__ \/ /_| | | | | | (_| | |_| |_
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: /_____|\_/\_/ \__,_| \_/ \___| |___/____|_| |_| |_|\__, |\__|\__|
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: _/ | | |
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: |__/ |_|
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: 2022-03-16 11:47:12.929 WARN STORE: scenes.json not found
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: SyntaxError: /var/snap/zwavejs2mqtt/330/nodes.json: Unexpected end of JSON input
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: at JSON.parse (<anonymous>)
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: at _readFile (/snap/zwavejs2mqtt/330/lib/node_modules/zwavejs2mqtt/node_modules/jsonfile/index.js:25:16)
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: at StorageHelper._getFile (/snap/zwavejs2mqtt/330/lib/node_modules/zwavejs2mqtt/server/lib/jsonStore.js:51:20)
2022-03-16T11:47:12+01:00 zwavejs2mqtt.zwavejs2mqtt[2486]: at StorageHelper.init (/snap/zwavejs2mqtt/330/lib/node_modules/zwavejs2mqtt/server/lib/jsonStore.js:42:25)
what am I doing wrong ?
and also : how can I get it to completely start itself upon boot (e.g. in case of power failure) ?
I got it working using snap, following the instructions of Goncezilla Matt, …but only 1 time …
There is better ways to do this today.
How I do it, and recommend doing it is to buy and use a network based zigbee controller and then use the Z2M addon in Home-Assistant to connect to it.
Sorry my mistake but i’m trying to get a zwave AND a zigbee usb working on a pi and then send MQTT messages to the HA machine (so different machine)
At the moment all is looking good exept that zwave2mqtt is unabble to acces the serial port. Tried 0 and 1 but also the entire path /dev/serial/by-id/usb-0658_0200-if00 but problem remains.
