Thanks for sharing, very nice.
With cover setup I mean using an entity of the ‘cover’ type to be able to for example halfway ‘open’, your method does.certainly also work
Ah ok. That would is a nice idea. Thanks!
Hi Guys,
I’ve tried to edit the code listed above to accommodate our 2 beds.
Controlling the lights and reading the status is working fine.
But when i try to control the movement my logs overflow with lines and no movement.
I did use the BT debug mode on my Android phone, and the app uses the same commands as in your scripts.
Could you help me fix the script?
Kind regards!
Logs overflow with lines??? You know the logs are real useful, right?.. They tell you what the problem/s are and if its in your config it even tells you what the line numbers are that have problems.
Maybe posting the logs is something you can do? Or if you’d like, we can all take turns giving you guesses and wasting a bunch of time!
Speaking of your script or your multiple scripts, that is probably the problem or part of the problem.
You got one to many script: there
script:
- id: control_bed_1
mode: restart #Makes sure only 1 execution in parallel and running is cancelled # IMPROVEIMPROVEIMPROVE SENT THE COMMAND VALUE AS PARAMETER! check wat het verwachte type is en wat ik voor type als parameter mee kan sturen
parameters:
section: int #1 head, 2 feet, 3 both
direction: int # 1 up, 0 down
#percentage? voor later
then:
- ble_client.ble_write: #send stop command
script:
- id: control_bed_2
parameters:
then:
service_uuid: ffe0
characteristic_uuid: ffe1
# List of bytes to write.
value: [0x40, 0x02, 0x73, 0x00, 0x00, 0x0b, 0x40]
Also, these lambdas with switch/case. You’re repeating the same condition check for all of them in both lambdas “if (direction == 1)” That’s a problem… I assume it’s supposed to be 1, 2, 3?
script:
- id: control_bed_2
parameters:
then:
service_uuid: ffe0
# Check what task to perform
- lambda: |-
switch (section) {
case 1: if (direction == 1) {
id(control_bed_head_up).execute();
return;
} else {
id(control_bed_head_down).execute();
return;
case 2: if (direction == 1){
id(control_bed_feet_up).execute();
return;
} else {
id(control_bed_feet_down).execute();
return;
case 3: if (direction == 1){
id(control_bed_both_up).execute();
return;
} else {
id(control_bed_both_down).execute();
return;
default: {
id(control_bed_stop_cmd).execute();
return;
script:
- id: control_bed_1
parameters:
then:
service_uuid: ffe0
- lambda: |-
switch (section) {
return;
} else {
return;
return;
} else {
return;
return;
} else {
return;
default: {
return;
You have to send and repeat a BLE service 100 times? Does it just move really slow or something?
- repeat:
count: 100
then:
Thanks for the reply, and sorry for not providing the logging and leaving you blindfolded…
I will try to make some changes and copy the logging if it doesn’t work.
As for the script section, do i remove the " script: " part and let bed1 & 2 be in the same script block? Or do i have to combine more lines?
And for the Lamdas im not sure, I did not invented this script, and do not have the knowledge to answer correctly. This will be something that the logging wil provide answers to.
Kind regards
Oh man! You’re asking quite a lot from me you know? I’m thinking that it’s only fair if I take the time to help you here, I should get to use the bed, kick my feet up and take a power nap at least.
I’ve removed the scripts: line and made the id’s in the script unique for both beds.
After uploading to the ESP32 and pressed head up in HomeAssistant i’ve got the following logs; (bed did not respond)
[12:19:54][D][button:010]: 'Bed1 head up' Pressed.
[12:19:54][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:55][D][main:383]: repeat head UP
[12:19:55][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:56][D][main:383]: repeat head UP
[12:19:56][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:57][D][main:383]: repeat head UP
[12:19:57][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:58][D][main:383]: repeat head UP
[12:19:58][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:59][D][main:383]: repeat head UP
[12:19:59][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:19:59][D][button:010]: 'Bed1 head up' Pressed.
[12:19:59][D][script:077]: Script 'control_bed_1_head_up' restarting (mode: restart)
[12:20:00][D][main:383]: repeat head UP
[12:20:00][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:01][D][main:383]: repeat head UP
[12:20:01][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:02][D][main:383]: repeat head UP
[12:20:02][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:03][D][main:383]: repeat head UP
[12:20:03][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:04][D][main:383]: repeat head UP
[12:20:04][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:05][D][main:383]: repeat head UP
[12:20:05][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:06][D][main:383]: repeat head UP
[12:20:06][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:07][D][main:383]: repeat head UP
[12:20:07][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:08][D][main:383]: repeat head UP
[12:20:08][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:09][D][main:383]: repeat head UP
[12:20:09][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:10][D][main:383]: repeat head UP
[12:20:10][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:11][D][main:383]: repeat head UP
[12:20:11][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:12][D][main:383]: repeat head UP
[12:20:12][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:13][D][main:383]: repeat head UP
[12:20:13][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:14][D][main:383]: repeat head UP
[12:20:14][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:15][D][main:383]: repeat head UP
[12:20:15][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:16][D][main:383]: repeat head UP
[12:20:16][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:17][D][main:383]: repeat head UP
[12:20:17][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:18][D][main:383]: repeat head UP
[12:20:18][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:19][D][main:383]: repeat head UP
[12:20:19][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:20][D][main:383]: repeat head UP
[12:20:20][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:21][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:21][D][main:383]: repeat head UP
[12:20:22][D][main:383]: repeat head UP
[12:20:22][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:23][D][main:383]: repeat head UP
[12:20:23][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:24][D][main:383]: repeat head UP
[12:20:24][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:25][D][main:383]: repeat head UP
[12:20:25][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:25][D][button:010]: 'Bed1 end move' Pressed.
[12:20:26][D][main:383]: repeat head UP
[12:20:26][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:27][D][main:383]: repeat head UP
[12:20:27][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:28][D][main:383]: repeat head UP
[12:20:28][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
[12:20:29][D][main:383]: repeat head UP
[12:20:29][D][ble_client.automation:026]: Write type: ESP_GATT_WRITE_TYPE_RSP
And no problem for using the bed to watch a TV show.
But when we kill the lights, the TV should turn off and the bed should go in a horizontal possition (thats the end goal, lights and tv is allready sorted out, the beds should be added when this script is working.)
Yes, it’s just like everything else, button, switch, sensor… you define 1 button component and then under that first “button:” you just put them in a row just like you did already.
button:
- platform: template # **Button 1**
name: "Bed1 head up"
icon: "mdi:bed"
on_press:
# Calling a script with parameters
- script.execute:
id: control_bed_1 #rc2bed1?
section: 1 #head
direction: 1 #up
- platform: template # **Button 2**
name: "Bed1 head down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 0 #down
- platform: template # **Button 3**
name: "Bed1 head/feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x07, 0x06, 0x40]
- platform: template # **Button 4**
name: "Bed1 head/feet down"
icon: "mdi:bed"
on_press:
So, you have these Buttons and this one for example. When it’s pressed ( on_press:) it triggers a script to execute (- script.execute:) with this ID ( id: control_bed_1 #rc2bed1?) and these Parameters
section: 1 #head
direction: 1 #up
button:
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 1 #up
So, we go to that script that the button executes ( id: control_bed_1 #rc2bed1?)
Here’s the first part of it. It also has 2 Parameters and these are the same ones your button uses. When you push that button, the script is executed with those 2 Parameters (Section: 1, Direction: 1) which will also be the values that the script uses when it runs, 1 and 1.
script:
- id: control_bed_1
parameters:
then:
Then the script checks the lambda where you have 3 Cases(options) to “switch” between, hence the name, “Switch-Case” Here though, I’m not 100% sure if this syntax is correct though. In a nutshell what’s going on. It starts at case: 1 and checks to see if it is True or False. Does Parameter: direction = 1 ?
You’re button assigned these numbers(integers/int)
- script.execute:
section: 1 #head
direction: 1 #up
So, Case: 1 is True. direction == 1 and the command underneath it get’s triggered. “id(control_bed_head_up).execute();” If direction did not = 1 then the ‘else’ part underneath would be triggered and this script would start, id(control_bed_head_down).execute();
- lambda: |-
switch (section) {
return;
} else {
return;
The problem is. the Case 1,2,3 you have are only checking the value(int), to see if direction = 1. "case 2: if (direction == 1), case 3: if (direction == 1). I assume they are supposed to be something like this. The problem though is you have a bunch of combinations that could be possible for Section and Direction and it just needs gone through and matched up so that if for example Direction == 1 and Section == 1 then,
switch (direction) {
AND
switch (section) {
case 1: if (section == 0) {
return;
equals the bed operation you want to happen…
- lambda: |-
case 1: if (direction == 0) {
return;
} else {
return;
return;
} else {
return;
case 3: if (direction == 2){
return;
} else {
return;
default: {
return;
You have a second lambda that is supposed to be checking the second Parameter: section(int) and it’s checking Paremter: direction(int) just like the other one. I assume it’s supposed to be something like this.
- id: control_bed_2
parameters:
then:
service_uuid: ffe0
- lambda: |-
switch (section) {
return;
} else {
return;
case 2: if (section == 1){
return;
} else {
return;
case 3: if (section == 2){
return;
} else {
return;
default: {
return;
You need to put the MAC addresses in there. X’s and Y’s won’t do the trick.
ble_client:
- mac_address: xx:xx:xx:xx:xx:xx
on_connect:
- mac_address: yy:yy:yy:yy:yy:yy
on_connect:
then:
Have you made any progress or updates?
Will try to convert your tips in to the code now.
Update you shortly
The MAC addresses are altered just for posting here.
In theory i think i know what you mean by using a lambda for the section and another for the direction. But i copied the initial script from _pm @ oct 30 '23 and thought i only had to implement a second bed to it.
The solutions you are providing indicate that the script of _pm never worked in the first place, so that is a bit odd, yet possible.
The second lambda was introduced by copying the first bed, changing the IDs to bed2…
The repeat 100 was implemented to continue the motion, only a single press would move the bed just a few millimeters.
Whats the best approach here? Save the current code, start over with the initial code from _pm and try to make it work for 1 bed, and then incorporate the second bed?
After looking at the lambda’s, I think I was partially wrong. There is a lot going on in that config and takes some time to get your head wrapped around everything. Before getting deeper into the lambdas, I think it’s best if we get the board connecting first, then you can try the buttons and see how close or how far off they are from what is expected then go from there. Can you post the top part of the config that deals with Wifi, esp32 board type, api, etc. etc. Also, was there anymore in the logs that you didn’t copy?
Go ahead and leave the code as it is for now, except the second ‘script:’ go ahead and just remove that part, the rest is ok for now.
script: **# <-------- Only remove "script:"**
- id: control_bed_2
parameters:
You are 100% sure that you have the correct MAC addresses in the config? You know a MAC address isn’t sensitive information, no one is going to hack your bank account and change your Netflix password from seeing the MAC address. BT devices are openly sending out their MAC and other service and manufacturer uuid’s to anyone or any device in the area and doing right now in the background as we speak. Hide your bank account number, not necessarily your MAC.
The connection to the beds are working, i can toggle the lights and see the connection status.
There where not any other log entries regarding the bed control.
Here is the complete code:
esphome:
platform: ESP32
board: pico32
wifi:
ssid: "xxx"
password: "xxx"
manual_ip:
static_ip: xxx
gateway: xxx
subnet: xxx
# Enable logging
logger:
# Enable Home Assistant API
api:
reboot_timeout: 60min
password: "xxx"
ota:
password: "xxx"
# Sync time with HA
time:
- platform: homeassistant
# Enable Bluetooth scanning for this ESP32
esp32_ble_tracker:
# General
- platform: uptime
name: "bt-gw1 - Uptime Sensor"
- platform: wifi_signal
name: "bt-gw1 - WiFi Signal"
update_interval: 60s
binary_sensor:
name: "Bed HdV remote connection status"
name: "Bed LdV remote connection status"
ble_client:
- mac_address: E2:29:0A:3F:0F:0C
on_connect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Connected to BLE device");
- binary_sensor.template.publish:
state: True
on_disconnect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Disconnected from BLE device");
state: False
- mac_address: E8:9C:B2:04:26:BC
on_connect:
then:
- lambda: |-
state: True
on_disconnect:
then:
- lambda: |-
state: False
switch:
name: "Bed verlichting HdV"
icon: "mdi:lightbulb-outline"
optimistic: true
turn_on_action:
service_uuid: ffe0
value: [0x40, 0x20, 0x72, 0x00, 0x08, 0xde, 0x00, 0x01, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x40]
turn_off_action:
service_uuid: ffe0
value: [0x40, 0x20, 0x72, 0x00, 0x08, 0xdf, 0x00, 0x01, 0x02, 0x01, 0x01, 0x01, 0x01, 0x00, 0x40]
name: "Bed verlichting LdV"
optimistic: true
turn_on_action:
service_uuid: ffe0
turn_off_action:
service_uuid: ffe0
button:
name: "Bed hdv head up"
icon: "mdi:bed"
on_press:
- script.execute:
id: control_bed_hdv #rc2bedhdv?
section: 1 #head
direction: 1 #up
name: "Bed hdv head down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 0 #down
name: "Bed hdv head/feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
name: "Bed hdv head/feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x06, 0x06, 0x40]
name: "Bed hdv feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x09, 0x04, 0x40]
name: "Bed hdv feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x08, 0x04, 0x40]
name: "Bed hdv end move"
icon: "mdi:stop-circle-outline"
on_press:
service_uuid: ffe0
name: "Bed ldv head up"
icon: "mdi:bed"
on_press:
- script.execute:
id: control_bed_ldv #rc2bedldv?
section: 1 #head
direction: 1 #up
name: "Bed ldv head down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 0 #down
name: "Bed ldv head/feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
name: "Bed ldv head/feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
name: "Bed ldv feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
name: "Bed ldv feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
name: "Bed ldv end move"
on_press:
service_uuid: ffe0
script:
- id: control_bed_hdv
parameters:
then:
service_uuid: ffe0
- lambda: |-
switch (section) {
id(control_bed_hdv_head_up).execute();
return;
} else {
id(control_bed_hdv_head_down).execute();
return;
id(control_bed_hdv_feet_up).execute();
return;
} else {
id(control_bed_hdv_feet_down).execute();
return;
id(control_bed_hdv_both_up).execute();
return;
} else {
id(control_bed_hdv_both_down).execute();
return;
default: {
id(control_bed_hdv_stop_cmd).execute();
return;
- id: control_bed_hdv_head_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x0b, 0x02, 0x40]
- delay: 300ms
- logger.log: "repeat head UP"
- id: control_bed_hdv_head_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x0a, 0x02, 0x40]
- delay: 300ms
- logger.log: "repeat head DOWN"
- id: control_bed_hdv_feet_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet up"
- id: control_bed_hdv_feet_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet down"
- id: control_bed_hdv_both_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both up"
- id: control_bed_hdv_both_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both down"
- id: control_bed_hdv_stop_cmd
then:
service_uuid: ffe0
- id: control_bed_ldv
parameters:
then:
service_uuid: ffe0
- lambda: |-
switch (section) {
id(control_bed_ldv_head_up).execute();
return;
} else {
id(control_bed_ldv_head_down).execute();
return;
id(control_bed_ldv_feet_up).execute();
return;
} else {
id(control_bed_ldv_feet_down).execute();
return;
id(control_bed_ldv_both_up).execute();
return;
} else {
id(control_bed_ldv_both_down).execute();
return;
default: {
id(control_bed_ldv_stop_cmd).execute();
return;
- id: control_bed_ldv_head_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_head_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_feet_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_feet_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_both_up
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_both_down
then:
- repeat:
count: 100
then:
service_uuid: ffe0
- delay: 300ms
- id: control_bed_ldv_stop_cmd
then:
service_uuid: ffe0
Oohh!! Payday!
ble_client:
LOL, I’m kidding.
So, this was unexpected and i didn’t realize you were using a pico32. Most likely it doesn’t matter but, if you’re using less common Dev boards, it’s arguably information that you should make known to people when they are helping with troubleshooting. Some boards have known “quirks” or broader issues in certain areas and the board is an important detail. This is the board you’re using, correct?
DARN! Did i forgot to remove the MAC addresses??
Im using this board;
https://www.tinytronics.nl/nl/development-boards/microcontroller-boards/met-wi-fi/m5stack-atom-lite-esp32-development-board
I’m eating good tonight, no McDonalds 1$ menu now that i’ve got that MAC. lol.
So, Did you do “auto detect” and that’s the board it selected? or where did that board selection come from? I’ve used esp32 NodeMCU and D1 mini or esp8266 boards pretty much exclusively the last few years so i’m not super familiar with your board but, I’d think the board in your config should be one of these M5Stack boards and not a Pico32.
esphome:
platform: ESP32
board: pico32
I’m just trying to make sure you have the right board setup and eliminate that as a current or future problem.
