I only have one connected ‘[0]’ only. Based on the information you’ve shared I’d expect you also to have 0 or possibly 1
I’m able to control my bed, but it’s going wild when I press a button. It’s not stopping controlling the bed and with the ‘delay’ it’s shocking (start/stop/start/stop).
I have to unplug the ESP32 to get the bed under control. I thought I could just ‘hold’ the button to control it and when I let go it stops. Anyone any idea?
The/my original remote is sending commands multiple times per second. That’s why I send it every 300ms for 30 seconds.
I do recognize that when I first send ‘up’ and within the 30 seconds ‘down’ it will send up/down/up/down commands, which is not good… I still need to work on preventing that…
Is that what happened on your side?
I think that may be part of the issue indeed. Trying to thinker further on how to make this smooth.
Is there a way within ESPhome, like with the actual physical remote, to ‘on_hold’ the button and it stops when you release?
If you attach a button to ESPHome you can use Binary Sensor Component — ESPHome
I do not see how to do this with a button in home assistant
I noticed that most of the script (snippets) above work when there is a connection made manually by using the Octo app but after a (short) while the connection drops off. It seems like - when I look at the Octo app - there is no ‘binding’ saved by ESPHome
(Strangely, the light control continues to work though)
Anyone know how to store or save the binding?
I do not completely understand, do you use Octo app and HA in parallel?
Why would you need a binding? The ‘esp32_ble_tracker:’ keeps scanning periodically
If I understand you correctly, you first connect using the Octo app and then get things working in HA, and not without the use of the app?
I can control the light easily. (as some also stated) but when I send a command by either button/switch (template) - nothing happens. When I turn on the app - which is connected to my bed - the commands do work when I send a command by either button/switch in hassio.
The connection becomes active by the ble scan
Do you have the repeat active?
One time sending will not completely move the bed
Connection
I tested it again, when I turn on the app and control the bed my YAML-code works, until it loses connection when I close the app.
This is the code I’m currently trying out:
# Enable Bluetooth scanning for this ESP32
# BLE Tracker
esp32_ble_tracker:
# scan_parameters:
# interval: 40ms # Increase the interval to reduce scanning frequency
# window: 30ms # Shorten the window to limit the time spent scanning
# on_ble_advertise:
# - mac_address: xx:xx:xx:xx:xx:xx
# then:
# - lambda: |-
# ESP_LOGD("ble_adv", "Detected BLE device: %s", x.address_str().c_str());
# ESP_LOGD("ble_adv", " Name: %s", x.get_name().c_str());
# ESP_LOGD("ble_adv", " Service UUIDs:");
# for (auto uuid : x.get_service_uuids()) {
# ESP_LOGD("ble_adv", " - %s", uuid.to_string().c_str());
# ESP_LOGD("ble_adv", " Service Data:");
# for (auto data : x.get_service_datas()) {
# ESP_LOGD("ble_adv", " - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
# ESP_LOGD("ble_adv", " Manufacturer Data:");
# for (auto data : x.get_manufacturer_datas()) {
# BLE Client
ble_client:
on_connect:
then:
- logger.log: "Connected to the Bluetooth receiver"
- esp32_ble_tracker.stop_scan # Stop BLE scanning after connecting
on_disconnect:
then:
- logger.log: "Disconnected from the Bluetooth receiver"
- esp32_ble_tracker.start_scan # Re-enable BLE scanning when disconnected
auto_connect: true # Automatically try to reconnect if the connection is lost
binary_sensor:
- platform: gpio
pin:
number: GPIO12 # Replace with your actual GPIO pin number
mode: INPUT_PULLUP
name: "Control Bed Head Up Sensor"
on_press:
- script.execute: control_bed_head_up
on_release:
- script.execute: control_bed_stop_cmd
- platform: gpio
pin:
number: GPIO13 # Replace with your actual GPIO pin number
mode: INPUT_PULLUP
name: "Control Bed Head Down Sensor"
on_press:
- script.execute: control_bed_head_down
on_release:
- platform: status
name: "BLE Connection Status"
switch:
name: "Bed verlichting Peter"
icon: "mdi:lightbulb-outline"
optimistic: true
turn_on_action:
- ble_client.ble_write:
service_uuid: ffe0
characteristic_uuid: ffe1
value: [0x40, 0x20, 0x72, 0x00, 0x08, 0xde, 0x00, 0x01, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x40]
turn_off_action:
service_uuid: ffe0
value: [0x40, 0x20, 0x72, 0x00, 0x08, 0xdf, 0x00, 0x01, 0x02, 0x01, 0x01, 0x01, 0x01, 0x00, 0x40]
button:
name: "Bed Peter head up"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 # head
direction: 1 # up
name: "Bed Peter head down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 # head
direction: 0 # down
name: "Bed Peter head/feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x07, 0x06, 0x40]
name: "Bed Peter head/feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x06, 0x06, 0x40]
name: "Bed Peter feet up"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x09, 0x04, 0x40]
name: "Bed Peter feet down"
icon: "mdi:bed"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x08, 0x04, 0x40]
name: "Bed Peter end move"
icon: "mdi:stop-circle-outline"
on_press:
service_uuid: ffe0
value: [0x40, 0x02, 0x73, 0x00, 0x00, 0x0b, 0x40]
script:
- id: control_bed
mode: restart
parameters:
section: int # 1 head, 2 feet, 3 both
direction: int # 1 up, 0 down
then:
- ble_client.ble_write: # send stop command
service_uuid: ffe0
- lambda: |-
switch (section) {
case 1: if (direction == 1) {
id(control_bed_head_up).execute();
return;
} else {
id(control_bed_head_down).execute();
return;
case 2: if (direction == 1){
id(control_bed_feet_up).execute();
return;
} else {
id(control_bed_feet_down).execute();
return;
case 3: if (direction == 1){
id(control_bed_both_up).execute();
return;
} else {
id(control_bed_both_down).execute();
return;
default: {
id(control_bed_stop_cmd).execute();
return;
- id: control_bed_head_up
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x0b, 0x02, 0x40]
- delay: 300ms
- logger.log: "repeat head UP"
- id: control_bed_head_down
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x0a, 0x01, 0x40]
- delay: 300ms
- logger.log: "repeat head DOWN"
- id: control_bed_feet_up
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x08, 0x01, 0x40]
- delay: 300ms
- logger.log: "repeat feet UP"
- id: control_bed_feet_down
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x07, 0x01, 0x40]
- delay: 300ms
- logger.log: "repeat feet DOWN"
- id: control_bed_both_up
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x70, 0x00, 0x01, 0x0a, 0x01, 0x40]
- delay: 300ms
- logger.log: "repeat both UP"
- id: control_bed_both_down
mode: restart
then:
- repeat:
count: 100
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x09, 0x01, 0x40]
- delay: 300ms
- logger.log: "repeat both DOWN"
- id: control_bed_stop_cmd
mode: restart
then:
service_uuid: ffe0
- logger.log: "Bed stopped"
I expect you did fill the right MAC addresses?
I’m not sure what the effect of commenting the ble scan parameters is?
What do you see when the following part is not commented out? (The ble advertise part)
Do you see connection status in the logging?
Why do you stop ble scan upon first connect? If the connection gets lost it will not reconnect
The code above is pretty messy, I can share my cleaned-up version end of the week (please remind me if I forget)
He! Yes, I did fill in the right Mac address
I’ve been playing around with many ble configurations. Yes, I have adjusted that by commenting that out (stop ble scan).
Three hypotheses I have:
- You have to press the star2 connected twice to ‘pair’ or ‘add’ another remote. Both for the app and for the physcial remote. So maybe it has something to do with this.
- There is something wrong the yaml-code and to connect it needs some specific connection sequence
- The ESPHome’s command structure might not be perfectly matching what the bed expects. Maybe the app uses a slightly different format or timing for the commands.
I’ve updated my automation
- Adding second bed (including connection state monitor)
- General cleanup and fixing not working parts (I was only using the had movement part)
- Preventing issues by user sending parallel up-and down commands on the same part of the bed
- Mind head-up-movement for bed_Annick is limited in height
esphome:
friendly_name: esp-bedcontrol
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Bedcontrol Fallback Hotspot"
password: "xxxxxxxxxxxxxxxxxx"
captive_portal:
esp32_ble_tracker:
scan_parameters:
duration: 30s
#FOR DEBUG ONLY:
# on_ble_advertise:
# then:
# - lambda: |-
# ESP_LOGD("ble_adv", "New BLE device");
# ESP_LOGD("ble_adv", " address: %s", x.address_str().c_str());
# ESP_LOGD("ble_adv", " name: %s", x.get_name().c_str());
# ESP_LOGD("ble_adv", " Advertised service UUIDs:");
# ESP_LOGD("ble_adv", " Advertised service data:");
# ESP_LOGD("ble_adv", " Advertised manufacturer data:");
# on_ble_manufacturer_data_advertise:
# manufacturer_id: 0590
# then:
# - lambda: |-
# if (x[0] != 0x7b || x[1] != 0x61) return;
# int value = x[2] + (x[3] << 8);
# id(ble_sensor).publish_state(value);
# on_ble_service_data_advertise:
# service_uuid: 181A
# then:
# - lambda: 'id(ble_sensor).publish_state(x[0]);'
# on_scan_end:
# - then:
# - lambda: |-
# ESP_LOGD("ble_auto", "The scan has ended!");
#sensor:
# - platform: template
# name: "BLE Sensor"
# id: ble_sensor
binary_sensor:
name: "Bed Annick remote connection status"
name: "Bed Peter remote connection status"
ble_client:
on_connect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Connected to BLE device Annick");
- binary_sensor.template.publish:
state: True
on_disconnect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Disconnected from BLE device Annick");
state: False
on_connect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Connected to BLE device Peter");
state: True
on_disconnect:
then:
- lambda: |-
ESP_LOGD("ble_client_lambda", "Disconnected from BLE device Peter");
state: False
switch:
name: "Bed verlichting Annick"
optimistic: true
turn_on_action:
service_uuid: ffe0
# List of bytes to write.
turn_off_action:
service_uuid: ffe0
optimistic: true
turn_on_action:
service_uuid: ffe0
turn_off_action:
service_uuid: ffe0
button:
name: "Bed Annick head up"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 1 #up
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 1 #up
name: "Bed Annick head down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 0 #down
icon: "mdi:bed"
on_press:
- script.execute:
section: 1 #head
direction: 0 #down
name: "Bed Annick head/feet up"
icon: "mdi:bed"
on_press:
- script.execute:
section: 3 #head/feet
direction: 1 #up
icon: "mdi:bed"
on_press:
- script.execute:
direction: 1 #up
name: "Bed Annick head/feet down"
icon: "mdi:bed"
on_press:
- script.execute:
direction: 0 #down
icon: "mdi:bed"
on_press:
- script.execute:
direction: 0 #down
name: "Bed Annick feet up"
icon: "mdi:bed"
on_press:
- script.execute:
section: 2 #feet
direction: 1 #down
icon: "mdi:bed"
on_press:
- script.execute:
section: 2 #feet
direction: 1 #down
name: "Bed Annick feet down"
icon: "mdi:bed"
on_press:
- script.execute:
section: 2 #feet
direction: 0 #down
icon: "mdi:bed"
on_press:
- script.execute:
section: 2 #feet
direction: 0 #down
name: "Bed Annick end move"
on_press:
- logger.log: "Stopping all commands for bed Annick"
- script.execute: control_bed_annick_stop_cmd
on_press:
- logger.log: "Stopping all commands for bed Peter"
- script.execute: control_bed_peter_stop_cmd
script:
- id: control_bed_annick
mode: restart
parameters:
section: int #1 head, 2 feet, 3 both
then:
- ble_client.ble_write: #send stop command
service_uuid: ffe0
# Check what task to perform
- lambda: |-
switch (section) {
id(control_bed_annick_head_up).execute();
return;
} else {
id(control_bed_annick_head_down).execute();
return;
id(control_bed_annick_feet_up).execute();
return;
} else {
id(control_bed_annick_feet_down).execute();
return;
id(control_bed_annick_both_up).execute();
return;
} else {
id(control_bed_annick_both_down).execute();
return;
default: {
id(control_bed_annick_stop_cmd).execute();
return;
- id: control_bed_peter
mode: restart
parameters:
#percentage? voor later is nu op lager niceau opgelost
then:
service_uuid: ffe0
- lambda: |-
switch (section) {
id(control_bed_peter_head_up).execute();
return;
} else {
id(control_bed_peter_head_down).execute();
return;
id(control_bed_peter_feet_up).execute();
return;
} else {
id(control_bed_peter_feet_down).execute();
return;
id(control_bed_peter_both_up).execute();
return;
} else {
id(control_bed_peter_both_down).execute();
return;
default: {
id(control_bed_peter_stop_cmd).execute();
return;
- id: control_bed_annick_head_up
mode: single
then:
- script.stop: control_bed_annick_both_down
- script.stop: control_bed_annick_both_up
- script.stop: control_bed_annick_feet_down
- script.stop: control_bed_annick_feet_up
- script.stop: control_bed_annick_head_down
#- script.stop: control_bed_annick_head_up
- repeat:
count: 30 #this is not fully up(!)
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat head UP Annick"
- id: control_bed_peter_head_up
mode: single
then:
- script.stop: control_bed_peter_both_down
- script.stop: control_bed_peter_both_up
- script.stop: control_bed_peter_feet_down
- script.stop: control_bed_peter_feet_up
- script.stop: control_bed_peter_head_down
#- script.stop: control_bed_peter_head_up
- repeat:
count: 100 # 70 is typically enough
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat head UP Peter"
- id: control_bed_annick_head_down
mode: single
then:
#- script.stop: control_bed_annick_head_down
- repeat:
then:
service_uuid: ffe0
value: [0x40, 0x02, 0x71, 0x00, 0x01, 0x0a, 0x02, 0x40]
- delay: 300ms
- logger.log: "repeat head DOWN Annick"
- id: control_bed_peter_head_down
mode: single
then:
#- script.stop: control_bed_peter_head_down
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat head DOWN Peter"
- id: control_bed_annick_feet_up
mode: single
then:
#- script.stop: control_bed_annick_feet_up
- repeat:
count: 100 # 40 is typically enough
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet up Annick"
- id: control_bed_peter_feet_up
mode: single
then:
#- script.stop: control_bed_peter_feet_up
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet up Peter"
- id: control_bed_annick_feet_down
mode: single
then:
#- script.stop: control_bed_annick_feet_down
- repeat:
count: 100 # 50 is typically enough
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet down Annick"
- id: control_bed_peter_feet_down
mode: single
then:
#- script.stop: control_bed_peter_feet_down
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat feet down Peter"
- id: control_bed_annick_both_up
mode: single
then:
#- script.stop: control_bed_annick_both_up
- repeat:
count: 30
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both up Annick"
- id: control_bed_peter_both_up
mode: single
then:
#- script.stop: control_bed_peter_both_up
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both up Peter"
- id: control_bed_annick_both_down
mode: single
then:
#- script.stop: control_bed_annick_both_down
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both down Annick"
- id: control_bed_peter_both_down
mode: single
then:
#- script.stop: control_bed_peter_both_down
- repeat:
then:
service_uuid: ffe0
- delay: 300ms
- logger.log: "repeat both down Peter"
- id: control_bed_annick_stop_cmd
mode: single
then:
- id: control_bed_peter_stop_cmd
mode: single
then:
# - ble_client.ble_write:
# id: rc2bedpeter
# service_uuid: ffe0
# characteristic_uuid: ffe1
# # List of bytes to write.
# value: [0x40, 0x02, 0x73, 0x00, 0x00, 0x0b, 0x40]
Thank you for sharing! I tested it (and only used one of the 2 beds )
The code acts the same. Here’s a snipped of my log:
[14:00:53][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[14:00:53][D][esp32.preferences:114]: Saving 1 preferences to flash...
[14:00:53][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[14:00:53][D][main:239]: repeat head UP Annick
[14:00:53][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_WRITE_CHAR_EVT
[14:00:54][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_WRITE_CHAR_EVT
[14:00:54][D][main:239]: repeat head UP Annick
[14:00:55][D][main:239]: repeat head UP Annick
[14:00:55][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_WRITE_CHAR_EVT
The light works but the commands don’t do anything
When I turn on the app and make a connection, the ESPHOME code works:
[14:17:56][I][esp32_ble_client:067]: [0] [F6:21:DD:DD:6F:19] 0x01 Attempting BLE connection
[14:17:57][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_CONNECT_EVT
[14:17:57][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_OPEN_EVT
[14:17:57][D][esp32_ble_tracker:270]: Starting scan...
[14:18:01][D][esp32_ble_client:306]: [0] [F6:21:DD:DD:6F:19] Event 46
[14:18:01][D][esp32_ble_client:110]: [0] [F6:21:DD:DD:6F:19] ESP_GATTC_SEARCH_CMPL_EVT
[14:18:01][I][esp32_ble_client:227]: [0] [F6:21:DD:DD:6F:19] Connected
Almost as if it just doesn’t (want) to connect before.
How do I force a connection?
The BLE scan results in a connection. B.t.w., In HA you should now also be able to see the connection state.
Logging seems all fine as far as I can conclude.
I think I have the Octobox Octo-Box - Octo (octo-actuators.de) (or maybe an older generation of this).
Possibly you have a different type of controller requiring different commands for the bed movement. Only way to know for sure is to log the bluetooth communication between the app on your phone and the bed itself to find out the actual commands sent. An instruction like this Bluetooth packet capture with Wireshark on Android | NowSecure can help
I used PacketLogger, it does the same trick.
What I did is to see what happens when I open the octo app without sending commands myself.
It seems it’s sending some commands (see the values in the screenshot). I tried to reproduce within ESPHome by trying to automatically sending the same commands but I’m not getting a connection. Maybe someone else can crack this, I’m out of ideas.
