Sounds similar to “no control over HA supervisor updates”. With exception that I never experienced W10 rebooting the machine (what you said was true for W7 though)
Anyway if you want use Windows as server OS, use dedicated edition instead one for desktops
Neither me or you were mentioning price. Instead you generalized usage of Windows while thinking about non-server edition (and probably Win7). TBH I was thinking about Windows Embedded (nowadays known as Windows IoT) but don’t know pricing and after quick glance I found no valuable information about. I even found a statement on some web pages “don’t use WIndows IoT for IoT”
So yeah… don’t use Windows for running HA
Do you have a suggestion, if one uses the GoogleBackupAddOn and don’t want to show the content of the Snapshot to Google first hand? I use this AddOn and password protect the files, so not everybody at Google can easily take a look…
I do know, that if one wants to get to the content, this kind of protection is easily hackable, but it’s at least something.
So im back after many many months now and want to get my automations back up and working as well as a pretty solid back up and restore solution.
I want everything to run locally as orginally stated above.
This time around though, im going to setup HA and test the backup and restore processes, BEFORE i go and setup all my automations and notifications and such. Ill setup a device and maybe add a addon and then test out the restoration.
Hardware setup this time, would be one of the following:
ODROID-N2+ Home Assistant Bundle from Ameridroid
or
Home Assistant Yellow
The hardest and worst part of my loss last year, is that i dont recall everything i had installed or setup, so i would literally be starting from scratch. I do know the one i had alot of time invested in was Node Red with alot of notifications and condition based events…
BUT this time ill focus on operational aspect first before jumping into the fun stuff.
So now my next question, based on what i have read, ODROID-N2 is out of stock. Is that something that can be bought in pieces and assembled since you cant get the complete unit/package right now? Anyone know?
New equipment has been shipped and arriving this Saturday. Besides having my mouse, keyboard and monitor ready to setup. Is there anything else hardware or software wise that i could get ready so i can focus on initial setup quickly this weekend?
Well got the equipement in last week, tried to setup this weekend and ran into my first problem, monitors that dont have HDMI connections, so i ordered HDMI to VGA and that didnt work, so ordered a HDMI to DVI and going to try that tonight… didnt have this problem when i had my HA on a Rpi before… i really dont want to buy a new monitor just to setup and configure my odroid.
The other concern i have is that since the first boot of the device was with a monitor that never showed anything, does anyone know if there is any chance i corrupted it be simply unplugging the power? I have no idea what happened or didnt happen during that first boot since i couldnt see anything
So got the odroid up and running and it found some devices already on my network, so before i start doing any more, i was looking to install samba, is this the correct thing to install for backups?
It’s definitely advisable to install the Samba add-on as that will give you the ability to create a share drive on your PC that directs to the HA config folder. The Samba add-on itself doesn’t provide any backup functionality but makes transferring files (such as your backup file) much easier.
There is a different add-on which will actually automate the backup and transfer (via Samba) if you want. There are other add-ons for automatic backups as well such as auto uploading to Google Drive or Dropbox.
I’d also recommend installing the SSH & terminal add-on which will help you remotely log in if things go pear -shaped.
Well i got the samba share working and can see the shares on the odroid device, but cant seem to get samba backup configured…
I have my host entered as the ip of the device
share, this one is not very clear, when i setup the samba share, there was nowhere that mentioned a “share” name, so my first attempt is using the IP address as well.
target dir = backup
username
password
keep local = all
keep remote = all
trigger time = 01:00
7 days a week
exclude add-ons = nothing
exclude folders = none
backup name = {type} Backup {version} {date}
workgroup = mynetwork name
the things i believe to be the problem are the “share name” and the 2 “exclude” settings, those 2 dont let me enter anything or save anything i am able to enter.
