I think you can only pick one port per server. In other words, I don’t think you can add the same server multiple times with different ports.
And you are right, you cannot change the port from within an automation action.
Yup, i think i have it figured out now. Had the wrong port for novoserve.com I set them up in a automation. And i notice as well like you have that some servers just don’t respond well to regular downloads (minus the -R).
Also noticing a big difference in speeds during the evening for some of the European servers, which is understandable i suppose. Thanks for your help.
It’s interesting to note that when using a web card and using the proof.ovh.net site in there i get only up to 300Mbps max. But when i test it out myself in the homeassistant container to either of the above mentioned servers, i get up to 940Mbps easily. Not sure where the rub lies here. I thought it was docker, but clearly that’s not limiting it.
I’m glad it’s all sorted out.
As mentioned in post 8, you have to pick a server that has an -R in its option listed.
It seems host name should be quoted as string.
