Hi !
Can you post an example, I’m new and I’m not able to do what’s described in the post.
Tom
Hi !
Tom
Hi Guys! Lurking here.
fan.set_speed is deprecated now - doesn’t exist anymore.
look here: Fan - Home Assistant (home-assistant.io)
Any idea on how to do this now?
Thank you!
@michaelarnauts apologies for poking directly. I see you did an amazing work with your lib for comfoconnect and it does have the boost mode implemented. Are you planning to get that functionality into hass anytime soon? thanks!
Boost is the same as high, except that it has an timeout. You can take a look at the rpm sensors and see it’s the same.
I have an updated component though, that can be installed trough HACS. It’s based on a new aiocomfoconnect library. You should be able to find a thread here on the forums about it.
Missed that HACS plugin. Works great, thank you very much!
What plugin did you set up?
