cat /sys/class/thermal/thermal_zone0/temp
For the GPU temperature this works:
- platform: command_line
name: GPU Temperature
command: "/opt/vc/bin/vcgencmd measure_temp"
unit_of_measurement: "°C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
but gives the following badly formatted output: temp=32.7'C °C
I tried this:
command: "/opt/vc/bin/vcgencmd measure_temp | cut -c 6- | head -z --bytes -3"
but it gives unknown
as the output.
Any idea how I can format this correctly?
Argh! So close:
command: "/opt/vc/bin/vcgencmd measure_temp | tr -d '[:alpha:]' | sed 's/[<>]//g'"
gives =33.8' °C
# CPU Temperature
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
I use this for teh CPU
maybe add a | replace("’", “”)
value_template: ‘{{ value | multiply(0.001) | round(1) | replace("’", “”) }}’
I’ve got the CPU temp fine using this:
I just cant work out how to remove the extra string bits this GPU temp command returns:
it outputs a string of the form:
temp=30.4'C
I just need to extract the floating point number from that.
value_template: ‘{{ value | multiply(0.001) | round(1) | replace(“’”, “”) | replace(“temp=", “”) }}’
Invalid config for [sensor.command_line]: invalid template (TemplateSyntaxError: unexpected char ‘“’ at 54) for dictionary value @ data[‘value_template’]. Got ‘‘{{ value | multiply(0.001) | round(1) | replace("’", “”) |replace(“temp=”, “”) }}’’.
See my edit. I had a “ before replace(Temp-=
Weird. I’m getting fancy double and single quotes when I copy and paste your example.
So I typed this out:
value_template: '{{ value | multiply(0.001) | round(1) | replace("'", "") | replace("temp=", "") }}'
But HA is still not happy.
Invalid config for [sensor.command_line]: invalid template (TemplateSyntaxError: unexpected char ‘“’ at 54) for dictionary value @ data[‘value_template’]. Got ‘‘{{ value | multiply(0.001) | round(1) | replace("’", “”) | replace(“temp=", “”) }}’’.
Sometimes the forum does funny things with single inverted commas… you see the logic of the replace command though. I’m using similar command line sensors and value templates without any issue…
I do see your logic. I’ve been stripping it down to test one thing at a time and it seems HA has a problem with this:
replace("'", "")
it throws this error right at the single quote:
expected <block end>, but found '<scalar>' in "/config/sensors.yaml", line 64, column 41
Oh wow. You have to escape a single quote with a single quote in YAML!
http://yaml.org/spec/current.html#id2534365 (look at Example 4.57. Single Quoted Quotes)
This works:
value_template: '{{ value | replace("temp=", "") | replace("''C", "") }}'
Thanks for putting me on the right track David.
Good Grief!!!
You’re Welcome.
This is how I rounded F to an integer and added an “F”
command: "cat /sys/class/thermal/thermal_zone0/temp | awk '{printf \"%.0fF\", ((($1*.001) * 9 / 5))+32}'"
all components listed under home-assistant.io/components will work with HassIO (unless there is something specifically noted as not compatible, but i dont think any exist like that, at least not that I have seen)
However after having a quick look at glances it appears you will need to SSH into HassIO and start the server which is a little more involved than most components. Shouldn’t be an issue, just give it a try.
so run another RPi for the Glances server…
@sapnho, f you don’t want to mess with glances have a look at this component.
Nothing more than yaml configuration required.
