Yes! Seems like login Happened!
But not working yet.
Now I get:
stdout: ""
stderr: "bash: line 1: poweroff: command not found"
returncode: 127
In config.yaml i have:
shell_command:
shutdown_tnas: ssh -i /config/.ssh/id_ed25519 -o 'StrictHostKeyChecking=no' -p 9222 [email protected] poweroff
Try using the full path, like /sbin/poweroff or something like that⌠To find where is the command, use âwhich poweroffâ from an interactive ssh session of the NAS.
You may also want to SSH from the HA CLI and run âwhoamiâ to make sure itâs logging you in as the correct user.
Guys, it worked!
I donât really know how to thank you for all the help you gave me and patience you showed.
I donât even really know which reply to mark as solution.
Thanks forever and ever and ever and everâŚ
P.s.
To be thorough, in case anyone else will ever need this, NAS warned me that âshutdownâ should be used instead of âpoweroffâ
Finally the solution was brought by @FriedCheese and @blackfede. Thanks, you made this a great day.
To summarize:
Install and activate ssh on both HA and NAS.
Access HA cli and generate keys with
ssh-keygen
donât set passphrase and when prompted for file path:
Type: /config/.ssh/id_rsa.pub
Copy the generated keys to NAS using:
ssh-copy-id -i /config/.ssh/id_rsa.pub user@NAS_IP
using your credentials.
Run:
chmod 600 /config/.ssh/id_rsaâ
Create a shell_command entry in config.yaml:
shell_command:
shutdown_nas: ssh -i /config/.ssh/id_rsa -o 'StrictHostKeyChecking=no' -p 9222 user@NAS_IP /sbin/shutdown
- Restart HA
Now you should be able to call a service called: shutdown_nas
This way, I got rid of the need for a smart UPS.
Please correct me if I badly reported something.
If you encounter an issue, since I mistook almost everything could be mistaken, youâll likely find the brief solution among replies, so take time to and care of reading.
Woo! Iâm glad it worked!
Thanks to you and @FriedCheese
