How to style a group/sensor?
I’m new to HASS and I made some experiment with groups and sensors. I cannot understand how to style my sensors UI to achieve something like this:
I succesfully create a group with two sensors inside, but the have only:
[icon][sensor name]…[value]
What if I want another line? Like:
[new line below with some data etc…]
You need to make sure all the sensors you put in the group have the correct name. I would check your sensors names and states by going to this page and look them up. Make sure you copy the name exactly into the group as if you get the name wrong its not an error, it just doesn’t show up. You can share your group configuration so we can see if it formatted correctly if the names appear correct.
One of my groups, correctly formatted, note the spacing.
  calendar:
      - sensor.offset
      - sensor.eventmessage
      - sensor.starttime
Sorry,I think I didn’t explain my issue very well :slight_smile:
In my group I have the two sensors I set (temp and humidity).
Now I would put under each sensor, the line with latest update, like in the image in my 1st post (the gray line with ‘9 minutes ago’ for example)
I think this comes from a very old version of Home-Assistant (0.2X.X or somthing like that), but I may be wrong. However, if that is the case you should be able to see when was the last update using templating and relative time (but it is a more advanced feature, not really straightforward for a newbie).
I found this which seems to add a lot of functionality to state cards. Probably not for newbies
