yeah, but from your log, you have a problem with your script. Seems to me like the script fires, doesn’t complete, so it never gets to the automation.turn_off
try leaving your script out of it for testing.
Unfortunately neither works:
- id: 'testoff'
- platform: time
at: '16:10:00'
# - service: script.turn_on
# entity_id: script.hue_w_gedimmt_1
- service: homeassistant.turn_off
entity_id: automation.bewegung_w
- id: 'testoff'
- platform: time
at: '16:13:00'
- service: automation.turn_off
You have something else going on.
I use the automation turn off/on every day. When my wife and I leave, it arms the door and window sensors automation notifications that I have set up.
It works 100% every day.
Did you found a solution for this? I am struggeling with the same problem. Everything in a list of actions is working except the automation.turn_on/off…
I use homeassistant.turn_x
all the time, and it works fine. for example:
initial_state: 'on'
alias: 'Dark TV on'
- service: homeassistant.turn_on
entity_id: automation.lounge_in_daylight_2
If it’s not working for you, then the chances are you’ve got an error in your automation - please share it.
Okay, found my misstake, i used the wrong entity_id.
Test Automation to turn on/off:
- id: 'TestAutomation01'
alias: Test-Automation 01
NOT working:
- service: automation.turn_on
entity_id: automation.TestAutomation01
NOT working:
entity_id: 'automation.Test-Automation 01'
WORKING:
entity_id: automation.TestAutomation_01
No, I did not find a solution so far.
It would be extremely nice if HA would provide specific hints what’s wrong…
try to add directly automation on frontend (lovelace is mine, it works
or under switch ,
Thanks tayfunulu,
A cold restart of my Pi solved the issue!
In my Hass.io, the service
automation.turn_off
will turn off my automation but will not stop the execution until it completes. Once turned off, it won’t run until turned on again.
Sure, turning an automation off means it won’t trigger anymore. If it already has been triggered and is still running you should be able to use homeassistant.turn_off
to cancel the running automation.
Thanks @cgtobi
I did see that post but it didn’t work for me running Hass.io 88.1. Like you said, I can turn off the automation and it won’t run again until it is turned on again. But it failed to stop it’s execution or abort in the middle of the sequence.
You might add a couple of conditions into your action part, that way you can check states of whatever might interrupt your automation.
