I installed node-red on home assistant os as an add-on after the automation created in node-red is very slow. I looked in node-red’s log and it shows the following message:
61 packages are looking for funding
run npm fund for details
7 vulnerabilities (5 moderate, 2 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues (including breaking changes), run:
npm audit fix --force
I received a similar message after updating to 18.0.1. The add-on will not start, not even in safe mode. Rolling back to a backup (earlier version of the add-on) solved the issue.
I’ve attempted to update the add-on again just more and it won’t start:
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 18.0.1
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (amd64 / qemux86-64)
Home Assistant Core: 2024.6.4
Home Assistant Supervisor: 2024.06.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to INFO
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 319 packages in 7s
11 packages are looking for funding
run `npm fund` for details
35 vulnerabilities (17 moderate, 15 high, 3 critical)
npm audit fix
To address all issues possible (including breaking changes), run:
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
npm notice
npm notice New minor version of npm available! 10.7.0 -> 10.8.1
npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.8.1
npm notice To update run: npm install -g [email protected]
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[02:55:41] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
/opt/node_modules/@node-red/util/lib/util.js:772
SyntaxError: Unexpected token ')'
at internalCompileFunction (node:internal/vm:76:18)
at wrapSafe (node:internal/modules/cjs/loader:1283:20)
at Module._compile (node:internal/modules/cjs/loader:1328:27)
at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
at Module.load (node:internal/modules/cjs/loader:1203:32)
at Module._load (node:internal/modules/cjs/loader:1019:12)
at Module.require (node:internal/modules/cjs/loader:1231:19)
at require (node:internal/modules/helpers:177:18)
at Object.<anonymous> (/opt/node_modules/@node-red/util/index.js:19:14)
at Module._compile (node:internal/modules/cjs/loader:1364:14)
Node.js v18.20.3
[02:55:42] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[02:55:42] INFO: Service NGINX exited with code 256 (by signal 15)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
For me, it appears to be an issue with this version.
