It is correct JSON but HA might not parse it as a JSON-object. Try:
{{ (state_attr('sensor.hikconnect_call_status', 'data')|from_json).callStatus }}
Iâve had a play and eventually succeeded in the template editor. I think itâs an issue with a mixture of strings and strings-interpreted-as-objectsâŚ
{% set a = {"data":"{\t\"apiId\":\t1,\t\"callStatus\":\t2,\t\"verFlag\":\t1,\t\"callerInfo\":\t{\t\t\"buildingNo\":\t1,\t\t\"floorNo\":\t0,\t\t\"zoneNo\":\t1,\t\t\"unitNo\":\t1,\t\t\"devNo\":\t0,\t\t\"devType\":\t1,\t\t\"lockNum\":\t1\t},\t\"rc\":\t1}","meta":{"code":200,"message":"ćä˝ćĺ","moreInfo":null}} %}
{{ ((a.data)|from_json).callStatus }} <-- this gives 2
{{ ((a.data)|from_json).callerInfo.zoneNo }} <-- this gives 1
indeed, now its working
how do you guys now this?
Experience, good documentation and playing in the template editor. It took a few goes, and I spent some time trying to get rid of the tab characters which wasnât needed. I ended up with more than ten steps to get to the result, and then worked backwards to eliminate unnecessary ones.
@septillion got there first, though .
guys, one more question/issue
so i have a rest sensor, that logs me in each day on the server; to get the sessionid, that works :
this one command gives me the session id in the template editor , that works too , so far so good
{{ state_attr('sensor.hikconnect_login', 'loginSession').sessionId }}
if i use that command now as a header for my next sensor, that nees polling every 5 sec, to get other data , it doesnt work
- platform: rest
scan_interval: 5
resource: "https://apiieu.hik-connect.com/v3/calling/listByUser?leastTime=&msgStatus=-1&pageSize=1"
headers:
sessionId: "{{ state_attr('sensor.hikconnect_login', 'loginSession').sessionId }}"
method: GET
value_template: "Hikvision Last Calltime"
json_attributes_path: "$.data[0]"
json_attributes:
- callingTime
i get this error then :
2021-05-02 10:05:20 WARNING (MainThread) [homeassistant.components.rest.sensor] JSON result was not a dictionary or list with 0th element a dictionary
if i make the sessionid static , like below, then the sensor works :
so whats the issue? why cant i use it there as variable? why does it work when i put it static?
- platform: rest
scan_interval: 5
headers:
#sessionId: "{{ state_attr('sensor.hikconnect_login', 'loginSession').sessionId }}"
sessionId: eyJhbGciOiJIUzM4NCJ9.eyJhdWQiOiJjZDBmZDgxMjc0YWxxxxxxxx
method: GET
json_attributes:
- callingTime
you can only template value_template.
any idea how i can fi this or workaround it? also note , the sessionid is longer then 255 chars, so i need attributes :s
You have to hardcode the sessionId or make a custom integration.
crap, i am not a good developer
the sessionid changes every day, so i cant hardcode it right?
you can, but youâd need to change it every day and restart.
hmm , not an ideal solution
why arenât you just using the integration for hikvision?
EDIT: Nevermind, not the same as hik-connect.
yeah, this is indeed verry new, i simulated the hikconnect app with fiddler , and then using the same login sessions and get the status of my video intercom, like last calls , callstatus, door open eventsâŚ
@petro, i am now using a command line sensor, no issues anymore with templating, one last thing, since you are the template export
How can i use this as a value template? The problem is that if i use it know, it cant be rendered, since the hikconnect_login sensor is not ready yet⌠approx after 5 sec after a restart of HA
{{ (state_attr('sensor.hikconnect_callstatus', 'data')|from_json).callStatus }}
Also i receive once on startup this error below, also quite normal, since the template is not ready yet, any idea how i can fix that, so my logbook doesnt contain a warning?
2021-05-03 14:55:51 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'None' has no attribute 'sessionId' when rendering '--header "sessionId: {{ state_attr('sensor.hikconnect_login', 'loginSession').sessionId }}" "https://apiieu.hik-connect.com/v3/devconfig/v1/call/Qxxxxx/status"'
- platform: command_line
command: >
curl
"https://apiieu.hik-connect.com/v3/devconfig/v1/call/Q02xxxx/status"
scan_interval: 5
value_template: "Callstatus"
json_attributes:
- data
