Resolved problem by purchasing a different zigbee remote and it works perfectly!
Colin
Colin
Ow, mind sharing which zigbee remote ??
I was able to get this working with zigbee2mqtt.
Add this to your main configuration.yaml
mqtt:
- name: "Miboxer_brightness"
state_topic: "zigbee2mqtt/MiBoxer"
value_template: >
{% if ( value_json | regex_search('action_level') ) %}
{{ value_json.action_level | int }}
{% else %}
{{ this.state | int }}
{% endif %}
- name: "MiBoxer_ColorTemp"
value_template: >
{% if ( value_json | regex_search('action_color_temperature') ) %}
{{ value_json.action_color_temperature | int }}
{% else %}
{% endif %}
- name: "MiBoxer_WheelHue"
value_template: >
{% if ( value_json | regex_search('move_to_hue_and_saturation') ) %}
{{ value_json.action_hue | int }}
{% else %}
{% endif %}
Then use this for a blueprint, everything works except the group keys 1-7
blueprint:
name: Synchronize MiBoxer Remote
description: Synchronize the sensors of MiBoxer FUT089Z Remote
domain: automation
input:
entity_1:
name: Select Miboxer Remote
selector:
entity:
multiple: false
entity_2:
selector:
entity:
multiple: false
entity_3:
name: Select Brightness Sensor
selector:
entity:
multiple: false
entity_4:
name: Select Color Temp Slider
selector:
entity:
multiple: false
entity_5:
name: Select Color Wheel
selector:
entity:
multiple: false
source_url: https://gist.github.com/fireboy1919/997c80db37de30da76f67c5daeaba27b
mode: restart
max_exceeded: silent
variables:
entity_1: !input entity_1
entity_2: !input entity_2
entity_3: !input entity_3
entity_4: !input entity_4
entity_5: !input entity_5
- platform: state
entity_id: !input entity_1
- platform: state
attribute: brightness
- platform: state
entity_id: !input entity_2
- platform: state
condition: []
- choose:
- conditions:
condition: template
value_template: '{{ is_state(trigger.to_state.entity_id, ''on'') }}'
sequence:
- service: light.turn_on
entity_id: '{% if trigger.from_state.entity_id == entity_1 %} {{ entity_2
}} {% else %} {{ entity_1 }} {% endif %}'
- conditions:
condition: template
value_template: '{{ is_state(trigger.to_state.entity_id, ''off'') }}'
sequence:
- service: light.turn_off
- conditions:
condition: template
value_template: '{{ is_state(trigger.to_state.entity_id, ''brightness_move_to_level'') }}'
sequence:
brightness: '{{ states(entity_3) | int }}'
- conditions:
condition: template
value_template: '{{ is_state(trigger.to_state.entity_id, ''color_temperature_move'') }}'
sequence:
color_temp: '{{ states(entity_4) | int }}'
- conditions:
condition: template
value_template: '{{ is_state(trigger.to_state.entity_id, ''move_to_hue_and_saturation'') }}'
sequence:
hs_color:
- '{{ states(entity_5) | int }}'
- 100
I didnât manage to receive any useful commands in Home Assistant, but I could bind my Hue (Zigbee/Bluetooth) lamps to both Home Assistant (SkyConnect) and the remote.
What I did:
Now my kids can control their light, while HA can control it too.
Hi, thanks for the clear steps.
However can you explain why you have to bind and then reset again the hue lamps with the Hue app first? Is this done just to reset the lamp in order to make it bind to HA?
If youâre not using HA but just the Hue app, would it be possible to bind the MiBoxer remote to a Hue lamp?
Pressing ON + OFF for over 5 seconds on the remote while the Hue app is looking for new devices (a dimmer switch with off button) doesnât work.
The Hue Infuse lamps donât respond to binding to the MiBoxer remote by pressing the â|â on the remote. My Lidl lamps, connected to the same Hue Bridge however DO bind this way. I donât understand why!?
Any thoughts?
Iâm sorry. I didnât get any notification, so I just see you questions now.
I donât have a Hue Bridge, so in my case, connecting the lamp to my phone is done with Bluetooth. But I guess the Lidl lamps donât use Bluetooth, so I guess there is a way of connecting zigbee directly to the bridge. I donât know why the MiBoxer doesnât connect.
For the other questions:
Hope this helps a bit.
