How to use PZEM004T Energy Monitor with esphome
The arduino R4 shows D0 and D1 as being TX/RX, but I’ve tried with other pins with no success.
Should I expect the TX LED of the pzem flash to blink when not connected, or nothing until connection is established?
The blue ones stay on constantly. The green one flashes every now and then.
Thanks, I only have one LED come up. Waiting for a UART TTL->USB cable tomorrow to try to diagnose with the PC.
Did you get the v4 working?
Hello, my pzem-004T v3 was working perfectly with Home Assistant. I updated esphome builder to 2025.08 and all the sensors were showing as unknown. I reverted to esphome builder version 2025.06 and the sensors are now giving correct readings. Could something have changed in the pzem-004t v3 configuration? help me. I have the following:
esphome:
  friendly_name: Consumo electrico esp32
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "My key"
ota:
  - platform: esphome
    password: "my pass"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Consumo-Electrico-Esp32"
    password: "my pass"
captive_portal:
uart:
  rx_pin: GPIO1 # cable verde
  tx_pin: GPIO3 # cable blanco
  baud_rate: 9600
  stop_bits: 1
# Configuracion PZEM-004T V3
modbus:
  - platform: pzemac
    current:
      name: "P Corriente"
    voltage:
    energy:
    power:
      name: "P Potencia"
    frequency:
      name: "P Frecuencia"
    power_factor:
      name: "P Factor de Potencia"
    update_interval: 1s
2025.10 (latest) integrated a change regarding pzem, but not marked as breaking :person_shrugging:
Logs from the not working setup would be fine :bulb:
Well done @nitin29 . Could you please explain the connections in your 2nd picture. I am planning to do something similar . Would like to monitor three phases along with inverter backed power supply running all the DC electronics and also be able to measure 0v ( monitor power outages) . Any suggestion is welcomed. Thanks.
hi,
I was having problems with my PZEM and ESPHome build from September 2025, and got no response, but just updated to 2025.11.2 and started working perfectly using your code. You may want to try it. Good luck!
wifi:
  ssid: !secret wifi_id
  password: !secret wifi_pw
  ap:
    ssid: $devicename
    password: "1122334455"
substitutions:
  devicename: 3phase-power-monitor
  friendly_name: Power Monitor
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: "1.0"
esp8266:
  board: esp01_1m
logger:
  baud_rate: 0        # free UART for PZEM
  level: DEBUG        # change to INFO later
wifi:
  ssid: "bespoq"
  password: "E1F01C3AEE"
  reboot_timeout: 15min
  power_save_mode: none
  ap:
    ssid: ${devicename}
ota:
  - platform: esphome
api:
web_server:
  port: 80
  version: 3
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
  import_full_config: true
time:
  - platform: homeassistant
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  stop_bits: 1
  parity: NONE
# Increased modbus timing to prevent bus contention
modbus:
  send_wait_time: 2000ms  # 2 seconds between requests
binary_sensor:
  - platform: status
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "${devicename} IP Address"
    ssid:
      name: "${devicename} Connected SSID"
    mac_address:
      name: "${devicename} MAC Address"
  - platform: wifi_signal
    name: "${devicename} WiFi Signal"
    update_interval: 60s
  - platform: uptime
  # --------- PHASE L1 ----------
  - platform: pzemac
    address: 1
    modbus_id: mod_bus_pzem
    update_interval: 90s  # Long interval, controlled by automation
    current:
    voltage:
    energy:
      device_class: energy
      state_class: total_increasing
      unit_of_measurement: "Wh"
    power:
      device_class: power
      state_class: measurement
    frequency:
    power_factor:
      name: "Power Factor L1"
  # --------- PHASE L2 ----------
  - platform: pzemac
    address: 2
    current:
    voltage:
    energy:
    power:
      device_class: power
    frequency:
    power_factor:
      name: "Power Factor L2"
  # --------- PHASE L3 ----------
  - platform: pzemac
    address: 3
    current:
    voltage:
    energy:
    power:
      device_class: power
    frequency:
    power_factor:
      name: "Power Factor L3"
  # --------- DAILY ENERGY PER PHASE (kWh) ----------
  - platform: total_daily_energy
    name: "Energy L1 Daily"
    power_id: power_l1
    unit_of_measurement: kWh
    accuracy_decimals: 3
    filters:
      - multiply: 0.001
    name: "Energy L2 Daily"
    power_id: power_l2
    filters:
      - multiply: 0.001
    name: "Energy L3 Daily"
    power_id: power_l3
    filters:
      - multiply: 0.001
  # --------- CALCULATED TOTAL SENSORS ----------
    device_class: power
    unit_of_measurement: W
    accuracy_decimals: 1
    update_interval: 30s
    lambda: |-
      float p1 = id(power_l1).state;
      float p2 = id(power_l2).state;
      float p3 = id(power_l3).state;
      if (isnan(p1) || isnan(p2) || isnan(p3)) {
        return NAN;
      return p1 + p2 + p3;
    lambda: |-
      float e1 = id(energy_l1).state;
      float e2 = id(energy_l2).state;
      float e3 = id(energy_l3).state;
      if (isnan(e1) || isnan(e2) || isnan(e3)) {
        return NAN;
      float total_wh = e1 + e2 + e3;
      return total_wh * 0.001;
    name: "Total Daily Energy"
    lambda: |-
      float e1 = id(energy_l1_daily).state;
      float e2 = id(energy_l2_daily).state;
      float e3 = id(energy_l3_daily).state;
        return NAN;
      return e1 + e2 + e3;
button:
  - platform: restart
    name: "Reset Energy L1"
    on_press:
      then:
        - pzemac.reset_energy: pzemac1
    name: "Reset Energy L2"
    on_press:
      then:
        - pzemac.reset_energy: pzemac2
    name: "Reset Energy L3"
    on_press:
      then:
        - pzemac.reset_energy: pzemac3
# SEQUENTIAL POLLING - Critical fix for bus contention
# Poll Phase 1 every 30 seconds
interval:
  - interval: 30s
    then:
      - component.update: pzemac1
# Poll Phase 2 every 30 seconds, but offset by 10 seconds
  - interval: 10s
    then:
      - delay: 10s
      - component.update: pzemac2
# Poll Phase 3 every 30 seconds, but offset by 20 seconds
  - interval: 20s
    then:
      - delay: 20s
      - component.update: pzemac3
Have assigned unique ID’s for all 3 PZEMs
Individually, I’m able to read them in their respective IDs
But when connected altogether, they are not working
One observation from PZEM LED status is that all PZEMs transmit together, same with receiving too
Hardware Setup
Wemos D1 Mini
PZEMs are directly connected to TX-RX (parallel connection with no pullup resistor or diode)
Any support will be invaluable :slight_smile:
When you say “parallel connection with no pullup resistor or diode”, I assume you mean you haven’t added anything.
Each Rx and Tx line on each PZEM board has a pull-up resistor and an LED.
If you wire them all directly in parallel then:
The Tx from the MCU will be driving 3 PZEM Rx lines at the same time: about 21mA
And the Tx line of each PZEM will be trying to drive the MCU pull-up, it’s pull-up and LED AND the other two Tx lines as well!: > 21mA
From what I could find, the max output current of the Tx pin on the D1 Mini is 12mA.
So the MCU can’t Tx to all three at the same time without adding a transistor or removing pull-ups from the 2 of the PZEM boards. (If they are in parallel then you only need one pull-up, not three in parallel, same for LEDs.)
The CT817 opto on the PZEM can handle 50mA, so for 3 PZEMs in parallel it should be ok.
I am running 9 in parallel from a ESP8266 NodeMCU with these mods…
  • Pull-up resistors and LEDs removed from all but one PZEM
  • A BC557 PNP transistor to boost the Tx line current
esphome:
  friendly_name: switchboard
esp8266:
  board: esp01_1m
# Disable UART logging as it interferes with pzem)
logger:
  baud_rate: 0
  level: NONE
api:
  encryption:
    key: "-some-big-encryption-key-here-"
ota:
  - platform: esphome
    password: !secret ota_password
  - platform: web_server
wifi:
  ssid: !secret my_wifi_ssid
  password: !secret my_wifi_pwd
  ap:
    ssid: $friendly_name
    password: !secret ap_password
#  manual_ip:
#    static_ip: 192.168.0.150
#    gateway: 192.168.0.1
#    subnet: 255.255.255.0
captive_portal:
web_server:
mdns:
uart:
  - id: com1
    tx_pin: GPIO1
    rx_pin: GPIO3
    baud_rate: 9600
    data_bits: 8
    stop_bits: 1
    parity: NONE
modbus:
  - id: mod_bus_pzem1
    send_wait_time: 250ms
    uart_id: com1
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    update_interval: never
    address: 1
    modbus_id: mod_bus_pzem1
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 2
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 3
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 4
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 5
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 6
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 7
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 8
  - platform: pzemac
    current:
    voltage:
    energy:
    power:
    address: 9
interval:
  - interval: 10s
    then:
      - delay: 500ms
      - lambda: "id(CB1).update();"
      - delay: 500ms
      - lambda: "id(CB2).update();"
      - delay: 500ms
      - lambda: "id(CB3).update();"
      - delay: 500ms
      - lambda: "id(CB4).update();"
      - delay: 500ms
      - lambda: "id(CB5).update();"
      - delay: 500ms
      - lambda: "id(CB6).update();"
      - delay: 500ms
      - lambda: "id(CB7).update();"
      - delay: 500ms
      - lambda: "id(CB8).update();"
      - delay: 500ms
      - lambda: "id(CB9).update();"
I am trying to use this to monitor power that’s on a vehicle’s shore power inlet.
That means that sometimes there is no AC power to the pzem and sometimes there is. I’m using a optoisolator with a big voltage divider to be able to know if/when power is coming in to shore power but I’m trying to figure out how to handle this on the esp32/esphome side of things since it seems like the pzem just doesn’t do anything at all without some AC-side power.
I was really hoping it could report 0V so I could get a consistent data feed but it doesn’t seem like that’s possible. Has anyone else done anything like this? Thanks!
Same problem
