Is it though? Can you ping it? Does HA see it?
Sorry! My badā¦ After going to the integrations tab and Add pzem, I can see the sensors!
But the Esphome its still showing as OFFLINE
Glitch in the matrix.
Probably yeap!
But I still need to fix itā¦
Why? Its working isnāt it?
This is usually caused by mDNS not working. see https://esphome.io/guides/faq.html?highlight=mdns
Someone knows a complete and clear guide on how to do this
This once here is very clear imho:
What, read the documentation? Ridiculous.
Can you please help me in the conection of multiple pzem? How do you insert the adress, meaning how do I know what is the adress of each pzem?
Iām also looking for it! have you found more information?
Yes, it has ben pointed out. Please read the response.
Hi, someone managed to have PZEM-016 working with ESPHome? i mean with this mod: https://github.com/arendst/Tasmota/issues/3694#issuecomment-430400450
I saw that referred to in a thread somewhere on this forum, but the guy couldnāt get it to work. He strangely refused to use a convertor.
Some week ago i tried too a pzem-016 modified on a wemos d1 mini: it didnāt work. It works fine with pzem 004t v3. Same pzem-016 works fine with Tasmota. Strange thing is that 004t v3 and 016 uses the same modbus protocol and a modified 016 should be exactly the same as the 004t v3. When i will have time i will try again with a 485 to ttl converter (i have some)ā¦ Do you remember wher is that thread?
No but if I find it Iāll be back.
Hi Iām the author of the mod, I had it working using both Tasmota and ESPHome (lastest release). There is doc from ESPHome is not right, you should use stop_bits: 1 for PZEM-016
Try this
Hello friends I have read all message. I have tried monitoring pzem-004t.v3 throw a sonoff and a esp32 camā¦ And no successā¦
Please anyone can share a yaml file with full configuration for esphome.
I have configured uart with 1 and 2 stop bits, I am Using āpzemacā I have tried with 3v and with 5v so I am not sure if it is importantā¦
Please, anyone know how to solve it?
Donāt know how many times this needs to be posted: https://esphome.io/components/sensor/pzemac.html
