camnop
(DCS)
August 7, 2021, 4:18am
124
I have five PZEM-004T ver. 3 and I’m trying to connect to Lilygo TTGO T-Internet-POE ESP32-WROOM.
I set each PZEM004v3 address individually with the Windows software, one connected at a time.
When I try to connect the fifth PZEM, no one works. When I try to connect four PZEM, they works at begin but after, only three works. Now I’m having only two PZEM working at same time.
Is my circuit bellow correct? Do I need to use a diode, resistor or something like that? Should I use 3V3 or 5V?
My power source is an AC-DC 5V 5A
My esp32:
My Code:
esphome:
platform: ESP32
board: esp32dev
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
ota:
password: "e25axxxxxxxxxxxxxxxxxa58"
web_server:
port: 80
dallas:
- pin: GPIO15
update_interval: 30s
uart:
rx_pin: GPIO35
tx_pin: GPIO14
baud_rate: 9600
#stop_bits: 1
#stop_bits: 2
#PZEM 004T V3 100A
- platform: pzemac
current:
name: "AAA - L1 - Current"
voltage:
name: "AAA - L1 - Voltage"
energy:
name: "AAA - L1 - Energy"
power:
name: "AAA - L1 - Power"
frequency:
name: "AAA - L1 - Frequency"
power_factor:
name: "AAA - L1 - Power Factor"
update_interval: 10s
address: 1
- platform: pzemac
current:
name: "AAA - L2 - Current"
voltage:
name: "AAA - L2 - Voltage"
energy:
name: "AAA - L2 - Energy"
power:
name: "AAA - L2 - Power"
frequency:
name: "AAA - L2 - Frequency"
power_factor:
name: "AAA - L2 - Power Factor"
address: 2
- platform: pzemac
current:
name: "AAA - L3 - Current"
voltage:
name: "AAA - L3 - Voltage"
energy:
name: "AAA - L3 - Energy"
power:
name: "AAA - L3 - Power"
frequency:
name: "AAA - L3 - Frequency"
power_factor:
name: "AAA - L3 - Power Factor"
address: 3
- platform: pzemac
current:
name: "BBB - L1 - Current"
voltage:
name: "BBB - L1 - Voltage"
energy:
name: "BBB - L1 - Energy"
power:
name: "BBB - L1 - Power"
frequency:
name: "BBB - L1 - Frequency"
power_factor:
name: "BBB - L1 - Power Factor"
address: 4
- platform: pzemac
current:
name: "BBB - L2 - Current"
voltage:
name: "BBB - L2 - Voltage"
energy:
name: "BBB - L2 - Energy"
power:
name: "BBB - L2 - Power"
frequency:
name: "BBB - L2 - Frequency"
power_factor:
name: "BBB - L2 - Power Factor"
address: 5
#HALL SENSOR
- platform: esp32_hall #GPIO 39 and 36
name: "ESP32 Hall Sensor"
4xvince
(Vincent)
August 11, 2021, 3:08pm
125
Yes if you connect multiples PZEM, you only need one with R4 and R9.
So you can simply removed R4 and R9 from all other PZEM.
(First schematic is correct)
4xvince
(Vincent)
August 11, 2021, 4:02pm
126
As I mentioned “The +5V pin of the 4 PZEM04 connected to the ESP8266 3V3.”
You really need to power the +5V pin of PZEM04 to a 3V3 source, as the input of the ESP32 is only compliant to 3.3V logic.
=> by connecting a +5V source you may have damage the D35 pin or/and the ESP32.
Another thing to check is the current capacity of the ESP
You have 5 PZEMs, and each consume near 2mA, then the ESP have to drive near 10mA
The ESP has a typical current capability of 28mA
(search IOL Electrical Characteristics)
=> It’s seams to be enough
is this not compatible with the new energy update? when trying to set up my pze does not show, does the yaml need tweaking?
hqsone
(Hqsone)
August 16, 2021, 5:39pm
128
Can ESPHOME + PZEM show full energy, not only active?
Just use this with the pzem’s power sensor
I needed to add device_class: energy to the sensor to make it work with HA energy
4xvince
(Vincent)
September 11, 2021, 5:21pm
130
Hi, me for make the detection of PZEM in HA new energy feature,
i have just add in ESPhome the state_class: "measurement" for
my energy sensor like this :
- platform: pzemac
address: 1
current:
voltage:
energy:
This make it visible, but i need to wait for see analysed data in dashboard
As mentioned, I also use the utility_meter like this (in /config/configuration.yaml):
utility_meter:
general_daily_energy:
source: sensor.general_energy
cycle: daily
general_monthly_energy:
cycle: monthly
I was checking the connections on my board to convert it from 5V to 3.3V. I soldered a 1K resistor in parallel with R8 but I think the schematic above has a mistake. I think LED D3 is not connected on pin 1 of 817 but it’s connected on Rx pin (pin 2 of 817). Could anyone verify that?
cyberdie
(Cyberdie)
September 28, 2021, 12:24pm
132
I’ve the same problem. I receive the total amount of consumed energy and NOT the “instant” energy i consume every moment.
Are there any solution for this?
With the total, HA increases cost constantly and is not real cost…
This works for me in the HA Energy Dashboard:
- platform: pzemac
current:
unit_of_measurement: A
accuracy_decimals: 1
icon: mdi:flash-circle
voltage:
unit_of_measurement: V
power:
unit_of_measurement: kW
accuracy_decimals: 3
filters:
- multiply: 0.001
update_interval: 5s
- platform: total_daily_energy
name: Home Total Daily Energy
power_id: home_power
unit_of_measurement: kWh
icon: mdi:clock-alert
cyberdie
(Cyberdie)
September 30, 2021, 9:07am
134
Copied you config and still seeing the “acummulated” energy…
Any other hint?
Assume you are using the Home Total Daily Energy Sensor in the energy config, grid consumption ?
cyberdie
(Cyberdie)
September 30, 2021, 10:22am
136
Right.
power:
filters:
- multiply: 0.001
frequency:
name: "General Frequency"
power_factor:
name: "General Power Factor"
update_interval: 15s
name: General Total Daily Energy
nonome1
(Nonome1)
October 8, 2021, 8:10am
137
Hello, how do you manage to address numbers to PZEM 004T v3 you are with the software.
Pyy project is 2 pzem on wimos mini for monitoring the solar panel and energy consumed.
thx
lauriz
(Laurynas Laivys)
October 9, 2021, 9:55pm
138
Hello, I am trying to connect PZEM-004T V1.0 with NodeMCU.
However i can’t get any serial communication going, followed advices and i have this code:
esphome:
platform: ESP8266
board: esp01_1m
# Enable logging
logger:
level: VERY_VERBOSE
baud_rate: 0
api:
ota:
password: "xx"
wifi:
ssid: "xx"
password: "xx"
captive_portal:
switch:
- platform: gpio
pin: 12
- platform: gpio
pin: 14
- platform: gpio
pin: 13
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
stop_bits: 1
- platform: pzem004t
uart_id: uart_pz
current:
voltage:
power:
energy:
update_interval: 20s`
any ideas what i am doing wrong? RX of PZEM is connected to ESP8266 GPIO1 TX, and TX of PZEM to ESP8266 GPIO3 RX. Powered by 5V VU pin.
Here is my log:
INFO Reading configuration /config/esphome/vanvex2.yaml...
INFO Starting log output from vanvex2.local using esphome API
INFO Successfully connected to vanvex2.local
[23:56:47][I][app:102]: ESPHome version 2021.9.2 compiled on Oct 9 2021, 23:45:59
[23:56:47][C][wifi:501]: WiFi:
[23:56:47][C][wifi:361]: SSID: [redacted]
[23:56:47][C][wifi:362]: IP Address: 192.168.1.205
[23:56:47][C][wifi:364]: BSSID: [redacted]
[23:56:47][C][wifi:365]: Hostname: 'vanvex2'
[23:56:47][C][wifi:369]: Signal strength: -82 dB ▂▄▆█
[23:56:47][V][wifi:371]: Priority: 0.0
[23:56:47][C][wifi:373]: Channel: 1
[23:56:47][C][wifi:374]: Subnet: 255.255.255.0
[23:56:47][C][wifi:375]: Gateway: 192.168.1.1
[23:56:47][C][wifi:376]: DNS1: 192.168.1.1
[23:56:47][C][wifi:377]: DNS2: (IP unset)
[23:56:47][C][uart_esp8266:097]: UART Bus:
[23:56:47][C][uart_esp8266:099]: TX Pin: GPIO1
[23:56:47][C][uart_esp8266:102]: RX Pin: GPIO3
[23:56:47][C][uart_esp8266:103]: RX Buffer Size: 256
[23:56:47][C][uart_esp8266:105]: Baud Rate: 9600 baud
[23:56:47][C][uart_esp8266:106]: Data Bits: 8
[23:56:47][C][uart_esp8266:107]: Parity: NONE
[23:56:47][C][uart_esp8266:108]: Stop bits: 1
[23:56:47][C][uart_esp8266:110]: Using hardware serial interface.
[23:56:47][C][switch.gpio:048]: GPIO Switch 'Vanvex_button_temp'
[23:56:47][C][switch.gpio:049]: Pin: GPIO12 (Mode: OUTPUT)
[23:56:47][C][switch.gpio:071]: Restore Mode: Restore (Defaults to OFF)
[23:56:47][C][switch.gpio:048]: GPIO Switch 'Vanvex_button_down'
[23:56:47][C][switch.gpio:049]: Pin: GPIO14 (Mode: OUTPUT)
[23:56:47][C][switch.gpio:048]: GPIO Switch 'Vanvex_button_up'
[23:56:47][C][switch.gpio:049]: Pin: GPIO13 (Mode: OUTPUT)
[23:56:47][C][logger:193]: Logger:
[23:56:47][C][logger:194]: Level: VERY_VERBOSE
[23:56:47][C][logger:195]: Log Baud Rate: 0
[23:56:47][C][logger:196]: Hardware UART: UART0
[23:56:47][C][pzem004t:110]: PZEM004T:
[23:56:47][C][pzem004t:111]: Voltage 'Vanvex Voltage'
[23:56:47][C][pzem004t:111]: Device Class: 'voltage'
[23:56:47][C][pzem004t:111]: State Class: 'measurement'
[23:56:47][C][pzem004t:111]: Unit of Measurement: 'V'
[23:56:47][C][pzem004t:111]: Accuracy Decimals: 1
[23:56:47][C][pzem004t:112]: Current 'Vanvex Current'
[23:56:47][C][pzem004t:112]: Device Class: 'current'
[23:56:47][C][pzem004t:112]: State Class: 'measurement'
[23:56:47][C][pzem004t:112]: Unit of Measurement: 'A'
[23:56:47][C][pzem004t:112]: Accuracy Decimals: 2
[23:56:47][C][pzem004t:113]: Power 'Vanvex Power'
[23:56:47][C][pzem004t:113]: Device Class: 'power'
[23:56:47][C][pzem004t:113]: State Class: 'measurement'
[23:56:47][C][pzem004t:113]: Unit of Measurement: 'W'
[23:56:47][C][pzem004t:113]: Accuracy Decimals: 0
[23:56:47][C][captive_portal:148]: Captive Portal:
[23:56:47][C][ota:029]: Over-The-Air Updates:
[23:56:47][C][ota:030]: Address: vanvex2.local:8266
[23:56:47][C][ota:032]: Using Password.
[23:56:47][C][api:135]: API Server:
[23:56:47][C][api:136]: Address: vanvex2.local:6053
[23:56:54][VV][scheduler:151]: Running interval 'update' with interval=20000 last_execution=602645 (now=622646)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b10110000 (0xB0)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b11000000 (0xC0)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b10101000 (0xA8)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b00000001 (0x01)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b00000000 (0x00)
[23:56:54][VV][uart_esp8266:133]: Wrote 0b00011010 (0x1A)
[23:57:02][VV][api.service:327]: on_ping_request: PingRequest {}
[23:57:02][VV][api.service:043]: send_ping_response: PingResponse {}
sender
October 10, 2021, 4:47am
139
Try reversing tx rx one time
lauriz
(Laurynas Laivys)
October 10, 2021, 9:04am
140
Tried that in software but didn’t work
Is it a v3 nodemcu ? If not you’ll need an external 5v
Also, try not using D3, it’s GPIO0 I think
lauriz
(Laurynas Laivys)
October 10, 2021, 9:22am
142
It is NodeMCU V3. GPIO1 should be TX and GPIO3 should be RX on this board. I literally tried every combination of step bits and RX/RX, tried software serial on D1/D2… Even tried to flash tasmota, but then flash size is only 1MB and in tasmota lite there is no PZEM configuration module.
I made sure that PZEM receives 5.146V, and RX/TX are inversed as they should be.
I tried another PZEM-004T board, did not help. Tried inversing RX/TX in hardware, did not help
In my working config I use:
uart:
tx_pin: TX
rx_pin: RX
baud_rate: 9600
stop_bits: 1
Maybe try that or:
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
stop_bits: 1
