How to use utility meter based on a counter
I have a counter that every tick represents one 1L off consumed water. I’d like to use utility meters in order to count dalty, weekly, etc. consumption. But utility meter requires a sensor which a counter is not. Is there a way to do that?
Should’nt a counter be considered as a sensor as well?
Herebelow is the automation code to increment the counter at every tick
- id: 532445d2-a9a1-4a1d-9b6d-e7c14b82a666
  alias: Shelly Uni IN2
  description: ''
  - platform: state
    entity_id:
    - binary_sensor.shelly_uni_channel_2_input
    to : "off"
  condition: []
    service: counter.increment
      entity_id: counter.eau
  mode: queued
Try to use sensor template and add it to meter media.
Thank you for the hint
I have exact the same problem…
Can you give me your example code for sensor and automation…
Thank you…
I set up afterwards a template sensor as such:
template:
  - sensor:
      - name: eau
        unit_of_measurement: m³
        device_class: water
        state_class: total_increasing
        state: "{{states('compteur_eau') | multiply(0.001) }}
Then this new sensor can be added to the energy panel. Go to settings/dashboard
This was my solution…
Thank you anyway…
Hi @damu I see I had exactly the same question this weekend https://community.home-assistant.io/t/creating-daily-months-stats-from-counter-through-utility-meter/.
Being still pretty new to HA I do not understand your answer. Can you elaborate a bit?
Thanks!
