How to use value_template to extract data from the sensors command
I put in the line like below
      value_template: '{% set cut = value.split('nvme-pci-0100')[1] %}
                       {{ (cut|regex_findall("Composite:\s*\+?(\-?[\d\.]*)°"))[0] }}'
& it doesn’t allow to put in configuration.yaml, come out error
bad indentation of a mapping entry (532:50)
 532 |  ... e: '{% set cut = value.split('nvme-pci-0100')[1] %}
value_template: >
just try, seem like same error
This entity is no longer being provided by the command_line integration. If the entity is no longer in use, delete it in settings.
I see you’ve added a unique_id. See if you have a duplicate sensor with _2 on the end of the entity ID.
