@petro but thats the just the thing, something changed caused what was working 2 weeks ago setting it through MQTT like you showed me; isnt working now.
So now I CAN set partials through the service call. Heres a working flow where I can set the dimmer bar to either red fast blink or green pulse. I had to add the 500ms triggers between each one or else sometimes not all 4 would get set. For example, it would change to pulse, but still be red instead of green.
[{"id":"dc1548ad.4a9b68","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"d7127d68.6b7a9","type":"change","z":"dc1548ad.4a9b68","name":"Set color","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"255","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":501,"y":162,"wires":[["85478289.2e904","f331b6bc.c62958"]]},{"id":"eb86bdc1.1794a","type":"change","z":"dc1548ad.4a9b68","name":"Set effect","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0x7f000000","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":511,"y":369,"wires":[["85478289.2e904"]]},{"id":"2a98b42c.ee3d2c","type":"inject","z":"dc1548ad.4a9b68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":304,"y":162,"wires":[["d7127d68.6b7a9"]]},{"id":"85478289.2e904","type":"api-call-service","z":"dc1548ad.4a9b68","name":"Office","server":"456659de.370498","version":1,"debugenabled":false,"service_domain":"zwave_js","service":"set_config_parameter","entityId":"light.office","data":"{\"bitmask\":\"{{bitmask}}\",\"parameter\":\"{{parameter}}\",\"value\":\"{{value}}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1112,"y":486,"wires":[[]]},{"id":"f1cd0abc.330a98","type":"change","z":"dc1548ad.4a9b68","name":"Set brightness","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0xff00","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"10","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":521,"y":234,"wires":[["85478289.2e904","41ffe538.85c91c"]]},{"id":"b729bce5.58fe5","type":"change","z":"dc1548ad.4a9b68","name":"Set duration","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0xff0000","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"255","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":521,"y":297,"wires":[["85478289.2e904","20de4124.ffb99e"]]},{"id":"4935c84d.ec2718","type":"change","z":"dc1548ad.4a9b68","name":"Set color","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"255","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"85","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":501,"y":540,"wires":[["85478289.2e904","890ccb26.a26228"]]},{"id":"119ca5df.efc02a","type":"change","z":"dc1548ad.4a9b68","name":"Set effect","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0x7f000000","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":756,"wires":[["85478289.2e904"]]},{"id":"b5aae5da.519d48","type":"inject","z":"dc1548ad.4a9b68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":304,"y":540,"wires":[["4935c84d.ec2718"]]},{"id":"b55e0823.1ad618","type":"change","z":"dc1548ad.4a9b68","name":"Set brightness","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0xff00","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":521,"y":612,"wires":[["85478289.2e904","368ec422.543bec"]]},{"id":"af47795f.b7e268","type":"change","z":"dc1548ad.4a9b68","name":"Set duration","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"},{"t":"set","p":"parameter","pt":"msg","to":"16","tot":"num"},{"t":"set","p":"bitmask","pt":"msg","to":"0xff0000","tot":"str"},{"t":"set","p":"value","pt":"msg","to":"255","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":521,"y":684,"wires":[["85478289.2e904","ec92a8a6.355e28"]]},{"id":"890ccb26.a26228","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":576,"wires":[["b55e0823.1ad618"]]},{"id":"368ec422.543bec","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":648,"wires":[["af47795f.b7e268"]]},{"id":"ec92a8a6.355e28","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":720,"wires":[["119ca5df.efc02a"]]},{"id":"41ffe538.85c91c","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":270,"wires":[["b729bce5.58fe5"]]},{"id":"f331b6bc.c62958","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":198,"wires":[["f1cd0abc.330a98"]]},{"id":"20de4124.ffb99e","type":"trigger","z":"dc1548ad.4a9b68","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"500","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":521,"y":333,"wires":[["eb86bdc1.1794a"]]},{"id":"21ade9e5.634116","type":"comment","z":"dc1548ad.4a9b68","name":"Red, 100%, indefinite, fast blink","info":"","x":576,"y":126,"wires":[]},{"id":"bf68757c.785198","type":"comment","z":"dc1548ad.4a9b68","name":"Green, 20%, indefinite, pulse","info":"","x":553,"y":504,"wires":[]},{"id":"456659de.370498","type":"server","name":"AvilaSmartHome","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
I used this page, which I just found out about and really helps with parameters.
https://devices.zwave-js.io/?jumpTo=0x0086:0x0003:0x003e:0.0#
